03-19-2009, 03:37 PM
Tail Pipe Soot w/ DFI
There are several instances reported of significant tail pipe soot w/ the 997.2. The amount of soot reported varies from covering the garage floor to staining of the tailpipes. Both standard and S models have reported the finding. Increased oil consumption has been reported but this also seems variable given that use of these cars varies widely. One owner stated he had the dealer look into the engine but found nothing. It's really difficult to say at this stage whether this is a) not a problem; b) a real issue w/o long term serious consequences; or c) a new RMS in the making. Neither the fact that Porsche has not responded to individual owners, nor the high emotion some owners have expressed means anything at this stage. Something to watch over time. If I come across any hard information I will post it.
03-23-2009, 03:28 PM
Newbie
Re: Tail Pipe Soot w/ DFI
Having owned 2 Direct injection cars, the soot at the exhaust is completely normal and unfortunately a side effect of direct injection.
I would image that since the distance the exhaust travels is much shorter than cars with the motor up front (my 2006 mazdaspeed6 and the Wife's Acura RDX), that is why the soot is more severe on a 911.
I am sure the 09 cayman S guys/gals will see the same thing.
03-31-2009, 04:42 AM
Do not forget excessive carbon depositins on valves. Audi is already having nightmares with their FSI cars. Your best bet is to get a performance flash like Softronic. For emission reasons our cars are setup to run too rich.
Tomasz
04-10-2009, 05:43 PM
Will that make it difficult or impossible to pass a smog test?
04-27-2009, 08:31 AM
My 09 C4S is consuming a tremendous amount of oil. My dealer and several others I have called continually state it is normal. I am constantly keeping an eye on the oil level and adding oil. the dealers all insist the oil consumption will slow down. However, the oil consumption just seems excessive. I'm at 3000 miles and I am now on to adding my 5th quart of new oil. This is additional to the original oil! Any suggestions on cleaning the soot on the tailpipes by any chance?
2010 911 Turbo
2009 911 Carrera 4S
04-27-2009, 05:19 PM
It may be some time before we know if the oil consumption on the DFI engines is going to lead to bigger problems. I think the best course is to add oil as necessary but never overfill. Keep the dealer in the loop. I always change the oil at 5K but maybe a change at 3K at the dealer, despite the cost, documents that you are meticulous in case there are problems down the road for which we need "good will" from Porsche. I know for a fact w/ the RMS issue that some owners received more support from Porsche than others, even substantially past the warranty period. We've got 4 years to sort this out. Like RMS, if there is a defect and a fix is available, it will likely be made available to us "early adopters".
DFI
04-27-2009, 05:33 PM
Insider
I must be one of the luckier owners. Our 09 Carrera C2 has only used one quart total in 4000 miles. I havent added any in the last 1500 miles and the gauge still shows 2 bars. Soot hasn't been that much of an issue either (knock on wood).
04-27-2009, 06:05 PM
Guys. Contact APR and Softronic. Ask them if their software will help with this issue. It may.
Tomasz
Tomasz
02-06-2010, 02:21 AM
i agree, complete side effect of DFI. why i chose to buy a non- dfi car this time around, my a3 2.0T put out soot like you wouldnt even believe! well actually you would...you prob have it worse than i did with that big 3.8 L engine!
DFI
02-06-2010, 02:44 AM
I ended up purchasing a 2010 S and my car uses no oil or has sooty tailpipes. The same with 3 other '09 S cars I am familiar with.
02-24-2010, 10:36 PM
Porsche Idealist
My DFI Cayman S does suffer from the sooty tailpipes, but that's to be expected. I'm concerned to hear jamcay has used 5 quarts of oil in his C4S!
My bosses AMG C63 chewed the oil until the car reached 20,000km then it pretty much stopped. If the C4S continues to go through oil after 15,000kms then the piston rings may need replacing.
DFI
987.2 Cayman S
Arctic Silver : Mechanical Diff Lock : 6MT Sports Shifter : Heated Sports Seats : PCM 3.0 : BOSE : Embossed Crests : Aluminium II lever/gear : Wheel Centre Set
Softronic
02-25-2010, 02:16 AM
Our C63 uses some oil but not too much.
2010 Cayman S, special build.
02-26-2010, 08:04 PM
My 2009 uses no oil at 8K miles, but I've changed it every 4k and it was not low even one bar each time. However, the tail pipes are sooty and the engine runs a bit rich for the 1st minute when temps. are below 50 F. There is lots of whitish smoke and louder than normal exhaust during that time. This is not to be confused with the occasional white puff of smoke which all H6 engines seem to experience.
Gary
2009 2.9L Guards Red Cayman PDK: Fabspeed
mufflers, Evoms V-Flow filter, 18" Cayman S wheels,
50% tint. Traded in a 2004 BMW 3.0L Z4. Wifey
wants a 356!
