Odd power outlet behavior - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Odd power outlet behavior
  1. #21
    Aug 2013
    3,359
    1566
    1110
    Re: Odd power outlet behavior
    Quote Originally Posted by rchaas View Post
    Battery checks out. Took out the smart top, cause they can't check the gateway computer with it installed (it evidently shows up). So back again next week for another round of testing.
    So I guess what's needed is a plug into ports 42 and 34 that can receive either the native leads or the smart top leads?
    It's been long enough since I built mind that I'll have to get it tomorrow and post a picture. It is a connector that is basically the same as what's on the smarttop and jumpers the right leads, but I can't confirm your specifics from memory.
    Sent from my iPhone using Tapatalk Pro
    '71 914 1.7L. '14 Boxster S (Silver & Black) w/ PDK, PTV, PASM, MFSW, heated SW, headed/vented seats, auto-dimming mirrors, rain sensor, ACC/PAS, light-design pkg, 14-way power seats w/ memory, climate control, Bose PCM & NAV, 20" Carrera classic wheels, PDLS, leather pkg, aftermarket backup camera & grills
  3. #22
    Aug 2013
    3,359
    1566
    1110
    Here are some pictures of the two jumpers I've built. One used a wire wrap socket, the other used a socket intended for soldering, but I tried wire wrapping it. I think the wire wrapped one is the one I stuck with.
    Odd power outlet behavior-img_3001-jpgOdd power outlet behavior-img_3004-jpg
    I might be able to dig up where I ordered the parts from.
  4. #23
    Nov 2015
    Oklahoma
    81
    I'm not savvy enough to sort out how that fits...mind providing a bit more detail?
    Appreciate the effort!
    I was thinking more along the lines of just building a connector from the blue block that could fit either the native leads from the car, or the smart top leads, and then the car leads would connect as per the instructions, using the same little plastic connectors. Clearly a more simplistic approach, but would work well enough, no more fiddling with the Tyco pins.
    2013 Boxster S
  6. #24
    Aug 2013
    3,359
    1566
    1110
    To use my stub, I would unplug the wire from the Smarttop, and plug that wire into my stub. Don't recall enough to follow your idea, sorry.
  7. Remove Advertisements
  1. 981 power outlets questions
    By gedwin in forum 981 Cayman and Boxster Electronics
    Last Post: 08-30-2015, 01:08 AM
  2. power outlet in 981 armrest
    By cabriolet in forum 981 Cayman and Boxster Electronics
    Last Post: 03-17-2014, 09:05 AM
  3. Why does the ac power outlets stay on even ater the car is off and locked?
    By Globespy in forum 987 Cayman and Boxster Electronics
    Last Post: 09-02-2013, 09:12 AM
  4. Odd cold weather behavior
    By bwass24 in forum 987 Cayman and Boxster Service and Tech
    Last Post: 01-16-2009, 08:20 PM
  5. Odd door window behavior?
    By BillC in forum 987 Cayman and Boxster Chat
    Last Post: 11-09-2006, 11:26 AM
