in-mirror display for backup camera - thoughts and questions
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: in-mirror display for backup camera - thoughts and questions
    MI
    5,665
    405
    1554
    I just pulled the trigger on the backup camera and mirror display for my Boxster. I first wanted to install backup sensors with GTS diffuser, but the more I was thinking about it - the more I realized that if I do it - I better go all the way and do the camera install. I have kids, dog, bikes left in the driveway, and all that... blind backing up out of the garage is a leap of faith every time... Camera is really way to go. And since I currently have my bumper off for http://www.planet-9.com/981-cayman-b...hlight=refresh
    I ordered this
    Amazon.com : Boyo VTM35M 3.5" OEM Style replacement mirror monitor : Vehicle Backup Cameras : Car Electronics
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    The mirror is 1 inch wider, but it's no problem. I have no doubt that it's NOT going to fit on the 981 mirror mount, but by looking at it - I hope I can switch just mirrors if the ball is the same size, or came up with some adapter...
    My main three questions are
    1. What is the best way to setup the camera. There is two possibilities - tap the backup lights for power, so display will come up automatically every time I backup. That's how it's done on OEM installs. But I can also make a switch - so I can switch it on any time I want. Not sure how usefull that is. Or I can do a combo of both and tap backup light AND have a switch. But in this case I'm afraid my backup light will come up when I turn the switch on?
    2. Is it possible to tap backup light somewhere in the cabin instead of going all the way back to the rear bumper? Like fuse box?
    3. And then there is a puzzle of routing the wire from the rear of the boxster to the cabin. Do I go under the car? Do I go from trunk and through the engine compartment?
    Phone Mount
    Over 200 happy customers here on P9
    Memory Module
    Sunglass Holster, Tablet Mount and more at
    33,952
    1582
    3040
    5366
    273
    Re: in-mirror display for backup camera - thoughts and questions
    See my escorticon install in the articles section where I put in the sensor above the license plate and wired it into the the car and ran the wire up to near the fusebox. I recommend bringing the wire in through a grommet in the trunk.
    When you do this PLEASE take lots of photos and do a DIY article for our members! Thanks in advance!
    MI
    5,665
    405
    1554
    Sure I'll make an article.
    The thing is I have a Boxster, and bumper off so coming into the trunk is the easy part. Routing around the engine is the puzzle for now.
    Phone Mount
    Memory Module
    Feb 2014
    Pennsylvania
    338
    94
    You will also lose your rain sensor (if equipped) if you have to swap out the mirror mount.
    Oct 2006
    1,691
    115
    You should try changing the mirror first before doing the wiring. I had to replace my mirror because some of the retaining ring plastic trim pieces that held the ball joint in place were broken and the mirror wouldn't stay up in place. I had to get the whole mirror assembly that included the slide clamp to the windshield. Unless they changed the way it was put together I'm not sure if the mirror ball can be released to use a different mirror.
    2014 991 Turbo
    2013 958 Turbo Diesel
    2006 987 Turbo CS
    MI
    5,665
    405
    1554
    Quote Originally Posted by tach miami View Post
    Of course. From looking at it there is a ring there that holds the tabs that hold the ball. If I manage to remove that ring - I should be able to take mirror off the ball. Then it's the question if it's the same ball diameter with new one
    Do you still have your bad mirror on hand?
    Phone Mount
    Memory Module
    Oct 2006
    1,691
    115
    Can't measure it since I pitched it after I epoxied the loose plastic tabs back into place and it still didn't hold the mirror in place.
    2014 991 Turbo
    2006 987 Turbo CS
    MI
    5,665
    405
    1554
    Whoohoo - it worked! The transplantation surgery is done! I removed the Porsche mirror, took out the post/ball part, then opened the display-mirror and transplanted porsche post/ball into it! Even the wires went nicely inside the post, so nothing is visible from outside.
    I also ripped off one of the complex video connectors in the process, so had to spend two hours with soldering iron looking into the loop glass and into microscope(!) I borrowed from my daughter. Felt really like a brain surgeon. After that surgery, only one video inputs is working, but thankfully that's all I need!
    I assembled camera and mirror together with 12v battery and it all worked like a charm!!!! I'm in business. Now I just need to route the video line all the way to the back...
    Phone Mount
    Memory Module
    MI
    5,665
    405
    1554
    Installed the mirror and lead the wire into the fuse box. It took some time. Porsche trim is so tight and difficult to remove... But now that part is done. New mirror looks stock and if you don't know you'll never guess:
    Size is pretty similar actually. I was afraid Porsche mirror is much smaller, but it isn't.
    (Don't look at colors. My crappy phone flash makes everything look different, but in reality it's all just black)
    My baby is all opened up and vulnerable at the moment. But I actually enjoy my little project. Keeps me from being bored, and I get to know my car better in the process. Porsche engineering is seriously awesome. And I actually can see where the engine is now:
    Phone Mount
    Memory Module
    MI
    5,665
    405
    1554
    Okay, the video cable from the rear has reached the fuse box today! It was actually not that hard at all. Much easier than I anticipated. It's totally stealth on the whole length.
    Need to find wiring diagram for the rear backup light.
    Oh, and did you guys know that there is second fuse box in the trunk?
    Phone Mount
    Memory Module
    Apr 2013
    Luxembourg
    42
    Quote Originally Posted by T-Design View Post
    Hi T-Design,
    I would be happy to see a few pics how you managed to get the video cable to the rear, and of course the wiring diagram
    I wanna buy the same mirror, but I am not sure if I can do it by my own
    MI
    5,665
    405
    1554
    Quote Originally Posted by paddler77 View Post
    Hi T-Design,
    The cable part was not difficult at all. Can be done in one night, with a few beers in between.
    I entered the trunk through passenger side ventilation opening. The plastic vents frame with rubber flaps comes out easily and the wire can go in on the side and then plastic frames snaps back in. Or there are a couple of holes/rubber plugs that can be used. Going on the side of the vent is just easiest.
    Then once you remove the trunk liner; put soft top in service position and bend out passenger side of engine lid liner - it all becomes pretty obvious. There are huge rectangular vents between trunk and the cabin. Look just above the yellow oil cap on the right
    So the wire hugs the right side (in the picture above), goes into vent, then again hugs the right side, around the top lift mechanism and into the cabin, then down and under the door sill. I will go into more details in the article I'm going to write.
    The transplantation surgery for a mirror post is a bitch! New mirror does not open easy, but breaks very easy And then it took me about two hours to snap the extra super tight spring ring back around the petals around the ball... Then I ripped the video cable when trying to squeeze it through the opening in the post. So it was not for the faint of heart... But I know how to do it now. And thinking about doing it for other people if there is interest. But it won't be cheap.
    But having the real camera in the back is priceless:
    Quality of picture is surprisingly excellent for not so expensive mirror. You can almost read the labels:
    Phone Mount
    Memory Module
    MI
    5,665
    405
    1554
    Better picture from another member here
    Phone Mount
    Memory Module
    Jul 2013
    3,502
    98
    777
    i think that a better place to stick in.. in the rear mirror.. because its the natural place that we look at.. when we back up..
    awesome job.vlad..
    lemon
    your one stop shop for car care, parts and racing equipment for your porsche
    Feb 2013
    Alberta
    326
    93
    46
    Nice! Someday they will allow us to have the all of the rear view by camera instead of mirror.
    2014 Cayman S
    2007 Cayman
    2000 Boxster S (Boxster owner since 1997)
    PCA National DE Instructor
    BMW CCA Instructor
    Apr 2013
    Luxembourg
    42
    Thanks T-Design, so you did know option 1? (tap the backup lights for power, so display will come up automatically every time I backup)
    MI
    5,665
    405
    1554
    Yes, that's what I did. The displays cames up automatically as soon as you put car in reverse gear. I'm still looking in the mirror when backing up, but now I actually can see what's going on behind me
    Phone Mount
    Memory Module
    Dec 2013
    165
    43
    I would just like to replace the mirror with an auto dimming piece. Is there power wires that I can splice into for 12V in the overhead map light area? Thanks
    2015 Carmine Red Cayman GTS- For sale pending PM if interested only 6500 miles
    996 GT3 front calipers, AP racing 350mm x 33mm disc PFC-11 pads front and rear Nitto NT01 235/40/18 front
    275/40/18 rear onVolk Racing TE37 Mercury Silver
    2016 Racing yellow GT4 with LWB!!! ordered... waiting for delivery
    MI
    5,665
    405
    1554
    Yes, there are some power there, including, I think wiring for autodimming mirror. But I routed the wires to the fuse box, just to be sure.
    Phone Mount
    Memory Module
    Aug 2010
    Auto dimming wiring is not in mine. Remove dome light panel to verify (simply snaps out), there should be a yellow connector above it with nothing connected to it if there is.
  1. Replies: 0
    Last Post: 01-06-2015, 01:20 PM
  2. Replies: 1
    Last Post: 03-25-2012, 09:30 AM
  3. backup camera solutions for PCM3?
    By s2ktaxi in forum 987 Cayman and Boxster Electronics
    Last Post: 01-11-2011, 04:44 PM
  4. Looking for good car wash and detailing in Dallas area
    By galael in forum Porsche Care and Detailing
    Last Post: 08-26-2010, 07:05 PM
  5. Innovative In-Vehicle Electronics for Current and Future Cars
    By RSS_feed_bot in forum The Polk Blog
    Last Post: 06-11-2010, 06:10 AM
