TPM - Clear dash icons...?
Results 1 to 20 of 22
Thread: TPM - Clear dash icons...?
    Apr 2013
    -- experienced an odd problem with the TPM option on the Cayman S yesterday and seeking a little advice:
    -- got the 'flat tyre' warning & symbols showing on the dash - got concerned so checked all tires w/manual gauge - no significant pressure problems - all tires good - TPM sensors replaced pst year...
    -- so a day later, all tire pressures still holding - but still can't get the on-board computer to clear the the faulty symbol icons.
    -- reviewed owner's manual for possible reasons and only remotely applicable cause appears to be 'too many wireless transmitters' (as TPM system apparently operates via radio signal)...?
    -- since no add'l wireless transmission from this end - stumped...
    -- any suggestions welcome from those with similiar problem.
    CFraulino
    PdR
    Oct 2012
    GA
    161
    91
    Re: TPM - Clear dash icons...?
    Quote Originally Posted by cfa341 View Post
    CFraulino
    PdR
    Do you keep the TPM display visible for a long period of time? Like always? If so, you've probably drained the batteries in the wheel unit radio transmitters. At least that's what I learned on my 2011 911 when it started doing this. I was told to never leave the TPM display visible; when it's shown the transmitters are using battery power.
    White Base Cayman, 20" Carrera S, PDK, Bose, Front/Rear Parking Sensors, PASM, 14 Way Ventilated Seats, Multi-Function Steering Wheel, Smoking Pkg., Model Deletion, Sport Exhaust Tips. 8th Porsche.
    Aug 2012
    Hudson Valley, New York
    620
    885
    92
    I had a similar situation recently. I made the tpms "relearn" the tire pressures by doing a reset through the stalk on the steering column and now everything seems fine.
    2007 Cayman S, MT, Atlas Grey Metallic/Terracotta.
    Oct 2007
    Calif.
    787
    186
    I have a question I cannot find the answer to. When I check how much pressure to add or decrease when the car is stationary it sometimes displays for the some of the wheel (mainly on the driver side) some prompt that looks like "Req". Ultimately the pressures needed appear but I am curious to this display.
    Also is it really true you drain the battery leaving the TPMS in the display as the norm?
    Oct 2007
    Calif.
    787
    186
    Sorry I forgot to add my right rear wheel takes a lot longer to display than the rest. The need pressure readout is there but the normal display takes about a minute or more. The tire has a plug but does not leak at all. Finally, do the tires have to be rotating to display the readings or just the ignition turned on?
    Oct 2012
    1,579
    1083
    984
    Quote Originally Posted by cease View Post
    Weird. You're saying there's a two-way radio link involved? I would think the TPM sensors would just send data in periodic bursts whenever they sense that the car is moving. If they have to listen constantly for HAL to ping them, that would seem to require even more battery power.
    Mar 2009
    1,724
    643
    463
    Not displaying the tire pressures does NOT stop the tire pressure sensors from working. If the car is running the tire pressure sensors are sending data whether you are looking at it or not. Who ever told you that is misinformed. I've had the pressure sensors in my car, a 2008 Cayman, now for 6 years and ALWAYS show tire pressure on my dash when I'm driving. Why? Because it's the only thing that shows that one can actually do something about if there is a tire problem. Radio station info and averages aren't worth much when you are motoring down the highway. And the sensors are still working fine. I suspect I'll need to change them in another year or two but that's just because that would be the normal life span.
    PS. There is regular outside interference with the radio signal of these sensors that cause them to change from psi to dashes but they will return to psi after a couple miles. It could be your local fire house, another car passing using the same frequency, etc. At least that's my 6 year experience.
    Apr 2013
    -- Seems like a number of glitches with TPM sensors (w/other makes as well): Don't believe that the sensors are continually 'streaming' tire pressure data - only upon start-up or stand-still when requested (or re-set) via steering stalk; Some tires do take longer for sensor(s) to 'learn' the pressure (shown by '--'); Once a problem surfaces - many faulty readings accompanied by the 'flat tyre' symbol and red '!' on dash - which remained for (2) days until finally clearing itself (w/pressure readings returning to normal) while vehicle was parked overnight...
    -- and lastly, may be just a coincidence - but noticed that my mobile phone seized up & became unusable at the same time the TPM problem began...?
    CFarc
    PdR
    Apr 2013
    Quote Originally Posted by Budman View Post
    -- do you think the TPM data is set for real-time continual updates - even if not requested via steering stalk...? have noticed that average mph/mpg readings require 'reset' request from time to time...
    Mar 2009
    1,724
    643
    463
    My experience and information has them sending data to the receiving unit on a regular, every couple minute basis, regardless of whether or not the results are displayed. It is stored there and available for viewing whenever you like. And because I drive with it showing on my dash, the values change constantly based on outside temperature, tire temperature and/or air loss.
    Comparing them to average speed or miles isn't really valid either. Averages also compute constantly whether displayed or not. The reset is justified, not because they stop working but because the averages become less useful when allowed to just accumulate and average forever. The averages won't change much when the accumulated data becomes so large that the averaged results using those large numbers become insignificant. That result could make it look like it stopped working but it didn't.
    Jul 2014
    Warwickshire
    71
    Gents, after washing my car the tyre press system showed up in the cluster with a warning of 0.3 bar air fill required on rear left tyre. I checked the pressure when driving and it was regular, with progress increase after warming up the car (from 2.3 to 2.5 bar), as usual.
    How can I clear the warning icon in the cluster? It seems a malfunctioning, as it never showed up in the winter, with very low temperature.
    RBT - Cayman GTS, PDK, sport suspensions, Carmine red int's, carbon seats.
    Feb 2007
    Atlanta, GA
    571
    65
    260
    Gamertag: Boxster981S
    I managed to clear mine by switching into and out of comfort mode.
    Andy
    DBM '13 981S / Sports Suspension / PTV / PSE / SC
    Jul 2014
    Warwickshire
    71
    Thanks for letting me know, I'll try over the weekend.
    Mar 2009
    1,724
    643
    463
    I"ve heard this before and I'm sorry, I don't believe it. The TPMS units in the tires are essentially dumb units powered by batteries. They transmit to a "smart receiver unit" which displays the dash readings. Not displaying the dash message DOES NOT stop the units from transmitting to the receiver and there is no way to stop the battery operated units from transmitting, even when parked in your garage. They do this full time. Whether the receiver unit catures the tranmission of info is something else. I've run my dash display for 7 years, every time I drive the car and for 36,000 miles before the wheel unit batteries went dead. I have fellow club members who never run with the display showing and their batteries went dead at approximately the same time. This is one of those internet info items that people believe are true because it's on the internet. It's not true.
    May 2008
    IN
    2,389
    40
    I'm with Budman on this. For the system to meet the regs it has to be sending pressure data to the car as long as it's moving in order to warn of a flat/low tire. This function is always there whether or not you're monitoring the display.
    I don't get why they didn't set the things to turn off when the car isn't moving after 20 minutes or so. Battery probably would have lasted well beyond the tires then.
    Les
    Mar 2009
    1,724
    643
    463
    Quote Originally Posted by Greywolf View Post
    Actually it sends the data without the car moving also. When I first start my car in the garage, I typically wait the minute or so to make sure my tire reading come up OK. Then I back out of the garage and roll out. This is not disimilar from those who got caught with their old TPMS units in the glove box after swaping them out. Guess what. They transmit from the glove box and confuse the receiver because there are too many units transmitting. Another demonstration that they NEVER stop transmitting until the batteries are so weak or dead and displaying the results has absolutely nothing to do with battery life.
    May 2008
    IN
    2,389
    40
    Right on.
    Guess I wasn't clear though. Simply meant that while they could shut off while not moving and still meet the regs, at least as I read them, they don't. They stay on all the time, which seems like a good way to sell the things plus all the work involved. Designed in extra service work. Pure gravy. Given the current state of electronics having them shut off when stationary would have been trivial. Sorry for the confusion.
    Les
    Aug 2013
    3,400
    1585
    1127
    CFarc
    PdR
    I thought maybe your tires were trying to call you...
    '71 914 1.7L. '14 Boxster S (Silver & Black) w/ PDK, PTV, PASM, MFSW, heated SW, headed/vented seats, auto-dimming mirrors, rain sensor, ACC/PAS, light-design pkg, 14-way power seats w/ memory, climate control, Bose PCM & NAV, 20" Carrera classic wheels, PDLS, leather pkg, aftermarket backup camera & grills
    Jul 2014
    Warwickshire
    71
    Quote Originally Posted by AndyE1976 View Post
    It worked for me too. Unfortunately the warning appeared once again after hrs of driving, after switching off the engine (with tyre pressure at 2.5 bar, absolutely as standard). It seems an issue with TPMS....
    Jul 2014
    Warwickshire
    71
    So gents, the warning is still there almost everytime I switch the engine off. Then it disappears as soon as I swap settings from comfort to normal and viceversa.
    Now I am going to tell you something else: sometimes when I switch off the engine, rotating the ignition key, wipers move suddenly, just a bit.
    Honestly, I am thinking I have some electrical issues on the car, as something wrong appears when I switch the engine off. :-/
  1. TPMS dash light
    By Johneecatt in forum 981 Cayman and Boxster Service and Tech
    Last Post: 06-26-2014, 02:25 PM
  2. TPMS Inactive! Replaced Sensor But Still Have Dash Warning
    By Nice Rumble in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-14-2014, 04:40 PM
  3. Cayman S TPM problem - clear dash icons...?
    By cfa341 in forum 987 Cayman and Boxster Electronics
    Last Post: 08-10-2013, 06:10 PM
  4. Clearing TPMS error messages
    By winchester21 in forum Porsche Tires & Wheels
    Last Post: 09-11-2007, 10:45 AM
  5. Clear Bra Install Party
    By hvdcman in forum 987 Cayman and Boxster Modifications
    Last Post: 12-30-2005, 08:43 AM
