Results 1 to 10 of 10
Like Tree3Likes
  • 2 Post By cease
  • 1 Post By Noah Fect
Thread: TPM - Clear dash icons...?
    cfa341 is offline Porsche Person
    Apr 2013
    -- experienced an odd problem with the TPM option on the Cayman S yesterday and seeking a little advice:
    -- got the 'flat tyre' warning & symbols showing on the dash - got concerned so checked all tires w/manual gauge - no significant pressure problems - all tires good - TPM sensors replaced pst year...
    -- so a day later, all tire pressures still holding - but still can't get the on-board computer to clear the the faulty symbol icons.
    -- reviewed owner's manual for possible reasons and only remotely applicable cause appears to be 'too many wireless transmitters' (as TPM system apparently operates via radio signal)...?
    -- since no add'l wireless transmission from this end - stumped...
    -- any suggestions welcome from those with similiar problem.
    CFraulino
    PdR
    cease's Avatar
    cease is offline Porsche Enthusiast
    Oct 2012
    GA
    161
    Re: TPM - Clear dash icons...?
    Quote Originally Posted by cfa341 View Post
    CFraulino
    PdR
    Do you keep the TPM display visible for a long period of time? Like always? If so, you've probably drained the batteries in the wheel unit radio transmitters. At least that's what I learned on my 2011 911 when it started doing this. I was told to never leave the TPM display visible; when it's shown the transmitters are using battery power.
    pmonkey and neal981 like this.
    White Base Cayman, 20" Carrera S, PDK, Bose, Front/Rear Parking Sensors, PASM, 14 Way Ventilated Seats, Multi-Function Steering Wheel, Smoking Pkg., Model Deletion, Sport Exhaust Tips. 8th Porsche.
    pmonkey's Avatar
    pmonkey is offline Porsche Specialist
    Aug 2012
    Hudson Valley, New York
    593
    I had a similar situation recently. I made the tpms "relearn" the tire pressures by doing a reset through the stalk on the steering column and now everything seems fine.
    2007 Cayman S, MT, Atlas Grey Metallic/Terracotta.
    Cantrax's Avatar
    Cantrax is offline Porsche Specialist 500 post club
    Oct 2007
    Calif.
    694
    I have a question I cannot find the answer to. When I check how much pressure to add or decrease when the car is stationary it sometimes displays for the some of the wheel (mainly on the driver side) some prompt that looks like "Req". Ultimately the pressures needed appear but I am curious to this display.
    Also is it really true you drain the battery leaving the TPMS in the display as the norm?
    Cantrax's Avatar
    Oct 2007
    Calif.
    694
    Sorry I forgot to add my right rear wheel takes a lot longer to display than the rest. The need pressure readout is there but the normal display takes about a minute or more. The tire has a plug but does not leak at all. Finally, do the tires have to be rotating to display the readings or just the ignition turned on?
    Noah Fect is offline Site Upgrade Donor
    Oct 2012
    1,003
    Quote Originally Posted by cease View Post
    Weird. You're saying there's a two-way radio link involved? I would think the TPM sensors would just send data in periodic bursts whenever they sense that the car is moving. If they have to listen constantly for HAL to ping them, that would seem to require even more battery power.
    BJR likes this.
    Budman's Avatar
    Budman is offline Site Upgrade Donor
    Mar 2009
    PA & FL
    1,431
    Not displaying the tire pressures does NOT stop the tire pressure sensors from working. If the car is running the tire pressure sensors are sending data whether you are looking at it or not. Who ever told you that is misinformed. I've had the pressure sensors in my car, a 2008 Cayman, now for 6 years and ALWAYS show tire pressure on my dash when I'm driving. Why? Because it's the only thing that shows that one can actually do something about if there is a tire problem. Radio station info and averages aren't worth much when you are motoring down the highway. And the sensors are still working fine. I suspect I'll need to change them in another year or two but that's just because that would be the normal life span.
    PS. There is regular outside interference with the radio signal of these sensors that cause them to change from psi to dashes but they will return to psi after a couple miles. It could be your local fire house, another car passing using the same frequency, etc. At least that's my 6 year experience.
    Apr 2013
    -- Seems like a number of glitches with TPM sensors (w/other makes as well): Don't believe that the sensors are continually 'streaming' tire pressure data - only upon start-up or stand-still when requested (or re-set) via steering stalk; Some tires do take longer for sensor(s) to 'learn' the pressure (shown by '--'); Once a problem surfaces - many faulty readings accompanied by the 'flat tyre' symbol and red '!' on dash - which remained for (2) days until finally clearing itself (w/pressure readings returning to normal) while vehicle was parked overnight...
    -- and lastly, may be just a coincidence - but noticed that my mobile phone seized up & became unusable at the same time the TPM problem began...?
    CFarc
    PdR
    Apr 2013
    Quote Originally Posted by Budman View Post
    -- do you think the TPM data is set for real-time continual updates - even if not requested via steering stalk...? have noticed that average mph/mpg readings require 'reset' request from time to time...
    Budman's Avatar
    Mar 2009
    PA & FL
    1,431
    My experience and information has them sending data to the receiving unit on a regular, every couple minute basis, regardless of whether or not the results are displayed. It is stored there and available for viewing whenever you like. And because I drive with it showing on my dash, the values change constantly based on outside temperature, tire temperature and/or air loss.
    Comparing them to average speed or miles isn't really valid either. Averages also compute constantly whether displayed or not. The reset is justified, not because they stop working but because the averages become less useful when allowed to just accumulate and average forever. The averages won't change much when the accumulated data becomes so large that the averaged results using those large numbers become insignificant. That result could make it look like it stopped working but it didn't.
  1. TPMS dash light
    By Johneecatt in forum 981 Cayman and Boxster Service and Tech
    Last Post: 06-26-2014, 02:25 PM
  2. TPMS Inactive! Replaced Sensor But Still Have Dash Warning
    By Nice Rumble in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-14-2014, 04:40 PM
  3. Cayman S TPM problem - clear dash icons...?
    By cfa341 in forum 987 Cayman and Boxster Electronics
    Last Post: 08-10-2013, 06:10 PM
  4. Clearing TPMS error messages
    By winchester21 in forum Porsche Tires & Wheels
    Last Post: 09-11-2007, 10:45 AM
  5. Clear Bra Install Party
    By hvdcman in forum 987 Cayman and Boxster Modifications
    Last Post: 12-30-2005, 09:43 AM
