Boxster S Bose wiring diagram
Results 1 to 4 of 4
Thread: Bose wiring diagram
    Jun 2013
    Bose wiring diagram
    I have a 2005 Boxster S with PCM 2.1 and Bose Surround Sound. The previous owner had cut out and removed the bassbox from the rear deck. I have acquired a bassbox but I don't have the matching plug from the Bose wiring harness. Does anyone have a wiring diagram or can provide a picture of the plug from the harness side?
    Here is a pic of the Bose harness.
    Attachment 32166
    Thanks for your help.
    Les
    Jun 2013
    Re: Bose wiring diagram
    I am getting there. I found this diagram on this site that explains the pin out wiring from the amp. I now know what are the wires leading to the bassbox.
    Bose wiring diagram-boseamppinoutdiagram-jpg
    Now I need to find out how they map to the bassbox
    Attachment 32200
    Can someone take a picture and post it of the male 12-pin plug (harness side)? Thanks.
    Apr 2013
    DE
    202
    WOW! I can't believe someone would cut wiring on a Porsche like that! Hopefully the rest of the vehicle was treated much better.
    Jun 2013
    Well, working with a friend who is smart on stereos, I was able to get my bassbox reconnected. I ended up making a custom connector using a 9-pin connector for computer hardware plus a couple of spade connectors for the power wires. I had to take the box apart to trace all the wires to verify how it all wires together. We also used a simple test speaker to verify the + and - speaker feeds.
    In the end it worked pretty good, other than once when I accidently touched the two power leads and blew a fuse. The custom 9-pin connector is a little fragile and care will be needed when disconnecting the bassbox.
    For future reference, here is the pin out arrangement for the Bose subwoofer wiring harness:
    1 - Amp power +
    2 - Amp power -
    3 - Subwoofer remote
    4 - Subwoofer +
    5 - Subwoofer -
    8 - Rear Right -
    9 - Rear Right +
    10 - Rear Left +
    11 - Rear Right -
  7. Remove Advertisements
  1. Wiring diagrams for Cayman s...anybody have one?
    By autobahnparts in forum 987 Cayman and Boxster Service and Tech
    Last Post: 09-30-2010, 04:02 AM
  2. 2006 wiring diagram?
    By peasteve in forum 987 Cayman and Boxster Electronics
    Last Post: 07-04-2010, 04:17 PM
  3. CDR24 (Bose) Wiring diagram
    By stevewen1 in forum 987 Cayman and Boxster Electronics
    Last Post: 02-12-2010, 10:19 PM
  4. Wiring Diagram for Sound Package Plus Amplifier
    By Jay H in forum 987 Cayman and Boxster Electronics
    Last Post: 01-01-2010, 06:11 PM
  5. 07 Wiring Diagrams ( attached )
    By FrankinCayman in forum 987 Cayman and Boxster Modifications
    Last Post: 05-21-2009, 09:13 AM
