Just picked up my car from the Body shop and IMO It does not get any better then this !! I am really happy with the results .
I chose to do the legs in Silver to match the rest of the silver my car has in various parts .
A big thanks to Neal/Nestor at NR auto Acessories for all they do :thanks:
Here is some quick pictures I will take some better ones when the sun is out in a few days and at a better location .Hope you like them !!
Thanks for the nice compliments guys !!
Suhkoi- I do not think there was any support piece needed ,I saw all the parts before Installation and did not see what you describe .
Its pretty strong and durable ,The 2 silver support legs are solid and strong .
The wing is adjustable from height to a tilting forward angle so this weekend I might try all of the adjustments available to make sure I have the one I want
I have 3 sets of Side vents already. The Motor Lux CF ,Black stock and a Silver set. I Have the motor Lux ones on currently and they are Soliconed In . maybe Silver Just on the outer part of the side vents would look cool
I already have the lower part of the Outside Mirrors Silver ,Black with a CF Insert and the motor Lux Rear diffueser in CF silver . I dont think I want to do anything to the front end at all in silver .I paid quite a bit for a absolute PERFECT paint job and the Running lights have a Silver look to them already .
Thanks for the Ideas
Thanks Law
After seeing your Gt wing post it actually changed my mind from another wing I already had ready to Install.
NR was really cool about the whole thing though -You see what you did:thanks:
My only Issue is when I hit 70 MPH even when the activation light is Off i get a spoiler failure warning light on in my dash ? what did you do to fix this ?
Will You guy know the different of the 2 wings? Techart and NR, besides the prices, they look alike tho. right?? I was told that there are only 1 set of screw for the attachment of wing to each base, which Techart have 2 set of screws for each base to wing..... if that is the case , will the screw able to hold down the wing on high speed downforce??
wow very nice indeed.... make me really wanna get the same mods done too
May i know what is the material of the GT3 look front bumper and hows the fit? Much shaping and cutting required? how many additional holes are required to be drilled on the rear to hold the base of the wing?
In regards to the front bumper there was NO cutting necessary to make it fit correctly ,If there was it was very small trimming just to get the Seams to match all around equally .Any body shop that has experience should not have a problem installing the GT-3 front bumper .It came with all the necessary hardware ,Gt-front grille,and mesh grills.The quality appears to be holding up nicely even after some misshaps I have encountered .The lower urethene bottom piece takes all the blunt if you happen to pull in to a parking stall too close or bottom out (My car is Lowered) the front lower piece is pretty inexpensive and easy to replace for $200.00 to $300.00.
The Rear wing is a combination of Fiberglass and Metal .
There are metal plates in the bottom base part for added stability and strength that the legs screw in to that hold the top wing part on.(As pictured )there are 3 big screws that screw in to a metal plate that is inside the base .
there are 2 metal brackets mounted underneath the top wing part that are fully adjustable to suit you desired heighth and angle.(As pictured )
My rear wing appears to be stable and solid
Thanks Dave appreciate the nice compliment and I must agree that this is the way I always wanted my Cayman to look like.
I see that you have caught the modification addiction lately ,Please keep us posted with your thoughts as you enjoy the Borla ,SRP and flash :thanks:
A big thanks to Neal/Nestor at NR auto Accessories for all they do :thanks:
Did you have to make some holes or some working on the car to mount that wing??
Im just not getting the idea how to mount it. I mean it looks it stays in the two holes of the small stock wing, but it's at the same time over the rear hatch. So where exactly is the wing fixed and how??
Would be nice if you can tell us some information about that!:kiss:
