Aluminum Porsche pedals
Results 1 to 16 of 16
Thread: Aluminum Porsche pedals
    Jul 2009
    TX Dallas
    166
    Hello guys,
    after 3 hours I installed, the aluminum porsche pedals from Suncoasticon, it was a little hard for me, because the space is tight and also I was not able to drill the brake since its just metal.. finally they are all in. does any one has done the installation using this pedals? the screws on the gas and the footrest are all the way inside but they dont get tight since theres no way to use a nut on the screw, does any one had the same thing.
    here is a pic , hope you guys like the pedals
    Dec 2008
    UT
    241
    Re: Aluminum Porsche pedals
    I did the pedals a few weeks ago and I think they're a great fit as well as looking and working great too. I like the larger size of the brake and clutch pedals. Drilling through the metal of the brake pedal was a pain, especially for the bottom screw, and because of the brake arm I wasn't able to get the nut on the bottom screw either. I'm monitoring the attachment and if necessary I'll go back in and grind out enough space to fit the nut.
    BW
    Jul 2009
    TX Dallas
    166
    it was super hard on the brake, but the screw is in there fine, no shaving at all.. did you drill on your gas pedal? I did on mine, but I was reading an old thread about a guy that had a problem with his gas pedal, because he actually hit a cable behind the gas pedal, now I am a little worried, I didnt check yesterday, so today as soon as I get home I will start the car..
    Feb 2009
    Tennessee
    I had a difficult time with the brake pedal as well. On the installation I found that a high speed dremel tool worked well with the metal penetration and opening the space behind the brake pedal at the arm to allow space for the washer and nut. Included with my gas pedal were self taping screws that worked great with a pilot hole. Not included with the kit were screws for the dead pedal used similar self taping screws found at local hardware store, I followed same mounting procedure as gas pedal. All pedals are very secure and have solid feel. Very pleased with finished result.
    Mar 2009
    IL
    340
    48
    The screws on the dead pedal and gas pedal are a different size. You should have used a different size drill bit on those screw holes. Mine tightened fine, but I didn't over tighten as that would have stripped the threading in the plastic.
    I also found the brake pedal hole at the bottom to be a pain - I broke 3 drill bits trying to get through it. I was able to get the nut on the back of the screw (just barely).
    Pedals are very nice for the money and so far, I've been very pleased with the results.
    2006 Guards Red Cayman S / TPC Stage 2 Turbo / TPC and Accumoto Track Packs / Mantis Deep Sump / Mantis Underdrive Pulley / X51 LWFW and Clutch / 19" Champion RS-98 Rims / LED Spars w/ Radiator Guards / Boothe Chrome Lug Bolts / B&M Short Shifter / HIP Engine Cover / PCM 2.1 / Chrono / Sport Seats /
    Jul 2009
    TX Dallas
    166
    I am having the problem on the gas as you are saying I probably stripped the threading.. I can push one of the screws from the back of the pedal out, I was thinking maybe using some silicone to hold the pedal and also the screw.. that way I will have the screw covering the hole.
    Quote Originally Posted by k_kush View Post
    May 2011
    Bucks County, PA
    177
    47
    72
    Rather than start a new thread, I figured I would just tack onto this one. Here's pic of my aluminum pedals purchased at AWE. I had them installed so I can't comment on the difficulty.
    Rather than start a new thread, I figured I would just tack onto this one.  Here's pic of my aluminum pedals purchased at AWE (http://www.awe-tuning.com/products/porsche/boxster/987-all/awe-aweporschepedal.html).  I had them installed so I can't comment on the difficulty.
    Mar 2011
    Mississippi
    69
    The dead pedal, clutch and gas are plastic. Instead of the bolts that came with mine, I went to lowes and got stainless woods screws with a washer and put through the plastic after a small pilot hole. Been solid for 2 months. As for the brake, I did not have the equipment to drill the rounded metal. Going to find auto/machine shop to do.
    Good luck!
    JoeBama
    "Roll Tide Roll"
    May 2011
    Bucks County, PA
    177
    47
    72
    Now that I sold the Boxster (shown in pic above) and replaced it with the Cayman it was time to install another set of pedals, this time on a PDK car. I bought this set at Rennline. It was more expensive than Suncoasticon but I was very happy with the quality of the set. I did break a couple of drill bits trying to drill pilot holes for the brake pedal. All in all though the install went smoothly. Here's the results:
    Now that I sold the Boxster (shown in pic above) and replaced it with the Cayman it was time to install another set of pedals, this time on a PDK car.  I bought this set at Rennline.  It was more expensive than Suncoast but I was very happy with the quality of the set.  I did break a couple of drill bits trying to drill pilot holes for the brake pedal.  All in all though the install went smoothly.  Here's the results:
    Thanks, CO
    '13 BS Agate, Agate/Pebble Full Leather, GTS tails, diffuser, Fabspeed Tips
    SOLD '09 CS Guards Red, Mods: Black headlight/stripe, logo, techart mirror inserts, grill mesh, satin black sports exhaust tip, aluminum pedals
    SOLD '05 BS
    Aug 2012
    Hudson Valley, New York
    620
    885
    92
    Quote Originally Posted by CornerOffice View Post
    Those look sweet. I've been thinking of this myself and how hard it would be to do it myself.
    Sent from my Galaxy Nexus using Tapatalk 2
    2007 Cayman S, MT, Atlas Grey Metallic/Terracotta.
    May 2011
    Bucks County, PA
    177
    47
    72
    ^^^ If I can do it, you can do it! The Rennline kit had great instructions. As mentioned, the toughest part was drilling two holes for brake pedal mounting, everything else was a piece of cake...
    Thanks, CO
    SOLD '05 BS
    Jul 2011
    Washington
    1,288
    64
    229
    I posted an article on this Aluminum sports pedals - Articles
    It's not that hard to do, but the Suncoasticon instructions were pretty vague so I re-wrote them.
    5-speed MT, 19" Carrera S wheels, Bi-Xenon Headlamps, Self-Dim Mirrors & Rain Sensor, Automatic Climate Control. Pioneer AVIC-X930BT NAV/CD/DVD/Bluetooth/Back Up Camera/HD Radio, Infinity Reference speakers, JL Audio 10" subwoofer, JL Audio Xd600/6 amplifier, Escort 9500ci detector/jammer, Porsche Mesh, Schild Frunk protector, LLoyds frunk mat, aluminum sport pedals, LED Spars, OEM SSK, Sprint Booster, BMC Air Filter, GT Exhaust
    Aug 2012
    620
    885
    92
    Quote Originally Posted by hack View Post
    I saw that article a while back - thanks for the write up!
    Nov 2012
    North Carolina
    Porsche Logo Re: Aluminum Porsche pedals
    I just installed set of Rennline covers with no problems. The new covers can be used as a drill template guide by using a small c-clamp to position the covers exactly where you want them and then drill through the screw holes in the new covers. I think that this should work with all the different brands of covers. Wedging the pedals with a piece of wood also helps. Make sure that you have a sharp and correct size drill bit and that the drill is not in reverse!
    Apr 2006
    5,832
    116
    967
    45
    Quote Originally Posted by Track Out View Post
    I strongly advise against using the pedals themselves as a template. There is way too much potential for damage caused by the spinning drill bit.
    Instead, position the pedals where you want them and stick a silver sharpie through the screw holes to mark the position of the screw holes. Then use an auto center punch to create indentations in the metal where the markings are before drilling (this is key).
    // Interpol / 2014 981 Cayman S / White
    // PDK / PASM / PTV / SC+ / PCM / PDLS / LDP
    // Borla cat-back exhaust / TiKORE titanium lug bolts
    // 2009 987.2 Cayman S / Carrara White / PDK / traded in 06.2013
    // 2006 987.1 Cayman S / Speed Yellow / 6MT / traded in 08.2009
    Nov 2012
    North Carolina
    Excellent point. I did use an auto center punch while the new pedal cover was c-clampped to the pedal.
  19. Remove Advertisements
  1. Porsche Pedals Mod
    By 987CS SPDYEL in forum 987 Cayman and Boxster Modifications
    Last Post: 08-18-2011, 01:10 PM
  2. Aluminum Sport Pedal Set Porsche 996/997/987 99+
    By vividracing in forum Site Vendors & Sponsors
    Last Post: 04-02-2010, 07:54 AM
  3. Aluminum dead pedal installation?
    By ccollins in forum 987 Cayman and Boxster Modifications
    Last Post: 07-14-2009, 11:18 PM
  4. Aluminum Porsche Sills
    By cycaza in forum 987 Cayman and Boxster Modifications
    Last Post: 11-17-2007, 06:47 PM
  5. Just Received Rennline Aluminum Mats/Pedals (Pics)
    By Helo Driver in forum 987 Cayman and Boxster Chat
    Last Post: 05-12-2006, 05:58 PM
