Preventing Oil System Related Engine Failures
Page 1 of 7 123 ... LastLast
Results 1 to 20 of 139
Thread: Preventing Oil System Related Engine Failures
    Jul 2009
    395
    39
    I started to post this as a reply in the "Causes of M97.21 Engine Failure?" thread, but that thread is pretty long in the tooth, and is (was?) really focused on discussing the causes of engine failures. There is information about various modifications sprinkled through it, but I thought it would be useful to assemble people's experience with different solutions in one place. So...
    For new readers on this topic: the issue is lubrication related engine failures in Cayman/Boxter gen 1 engines, brought on by high lateral g conditions. This usually (but not always) means a modified car (suspension, sticky tires) on a track, and is particularly problematic with sustained high g left hand turns. The "Long Version" is available at the thread referenced above. Causes of M97.21 Engine Failure?
    I'm getting ready to move to R compound tires, and I think it would be naive to do so without trying to make the engine more reliable under high g conditions. The question is, what modification to make???
    I'm taking a pragmatic approach to the problem: I don't need to solve the design issue (though it might be an interesting exercise). Rather my goal is to solve my immediate problem: this engine model seems to have an history of failure under conditions to which I may very well subject the car. So my goal it to find the best way to reduce the risk of engine failure, and I really only care about effectiveness and cost. I think most members are probably of the same mindset.
    Of course, understanding the underlying problem would help significantly in assessing modifications. This is my frustration with Porsche, since they are by far in the best position to provide meaningful data about the failure mechanism. I don't mind spending some money to upgrade the reliability of the car for track use, but some guidance on effective modifications would be nice. Alas, Porsche has made their position clear and we get no help.
    So it seems there are a few known options out there people have tried:
    Accusump
    As far as I can tell, this is a remote accumulator that will theoretically help maintain pressure in the oil pump discharge line. If properly configured, it should probably be able to cover for brief periods when the oil pump is not maintaining pressure (perhaps due to no oil at the pickup, or highly aerated oil at the pickup). I would need to work through a diagram of the oil system and how the accusump connects to be sure.
    • Probably $1500-$2000 depending on the installation
    • Straightforward install but need to find a location for the canister
    TTP Oilsafe
    Auxiliary scavenging pump that appears to draw oil from the front of the right side cylinder head and return it to the sump. Theory seems to be that oil accumulates here, particularly during left hand turns, and the stock scavenge pickup is not effective in removing it (because it's too far to the rear? doesn't have sufficient capacity?). Again, it would help to better understand the oiling system to assess this approach. Some people have reported great success with this system, including people who race the cars in Europe. Also I believe Porsche has offered a similar modification kit for some engines in the past.
    • Very Expensive: probably $3000+ to install
    • Porsche will immediately void your warranty if this is installed (which is a risk anyway if the car is tracked)
    Deep Sump / Windage Tray
    I'll put these together since the setup I think looks most likely to be effective is the Mantis extended sump / windage tray combo. Seems like it should help in two flow directions since the tray is mostly closed: (1) oil below the tray (and at the oil pickup) should be less aerated since the heavier, better flowing liquid will drain down through the tray and baffle trap doors more readily than froth, and (2) the limited open area should act to dampen the lateral shifting of oil in transient high g turns. [In a sustained skid pad session eventually the oil would reach an equilibrium angle in the sump and it would not help, but in typical road course transients it seems it should slow the migration of oil side to side. I do wonder whether any science or testing went into the area and location of the holes in the windage tray, or if they just guessed...]
    This probably only delays the onset of the problem, but may be sufficient for typical road course transient conditions. Seems it should help at any rate. Wish I had a good way to test it....
    • Simple install; probably a 2 hour job
    • Relatively low cost (<$1000)
    Has anyone tried other modifications with any success?
    What about people's experience (success/failure) with these?
    Cheers,
    Walter
    DC
    2,248
    36
    Re: Preventing Oil System Related Engine Failures
    The TTP Kit is the best currently available... However it is quite expensive.
    We will be making an announcement on a lesser priced fully inclusive product in the next few months.
    Casey Parkin : Washington, DC
    DFW TX
    3,909
    45
    445
    170
    There is already another recent, long thread on this topic you might have missed which pretty much addresses the same question and fixes: http://www.planet-9.com/cayman-boxst...und-tires.html
    I am looking forward to the TPCicon Racing solution.
    2011 Macan S: Wifey's DD
    Apr 2006
    Puerto Rico
    1,620
    39
    83
    Casey I am looking into some improvement for the oiling problem in Gen 1 cars. I hope TPCicon has something in the next two months. Please send me a PM if you come out with something.
    Maybe I will get really excited and add the first Cayman S turbo in Puerto Rico
    Having fun in Puerto Rico
    DC
    2,248
    36
    We will debut it here when we are done...
    Sep 2006
    SoCal
    1,944
    133
    162
    46
    I am not sure we need yet another thread on this, but..
    One important modification is the retrofit of an older 996 oil separator / defoamer / swirl pot (many names) in place of the 997 part installed. This modification should help remove the air that is trapped in the oil (foam) as the oil returns from the heads. Note: this is not the same as the AOS fix descibed elsewhere.
    The part in the orginal PET catalog is a 996 part (996 107 080 54) and looks just like the part in the drawing. The as built though is a 997 part (on the left) that looks much different. The more recent PET shows the 997 part.
    If these pots are installed in conjuntion with the Mantis windage tray (5 more minutes to the job) then the tray must be modfied to allow the pots to pass through. Not a big deal.
    See photo:
    See photo:
    Here is the "as built" sump (courtesy K-Man S):
    And here is an photo of how the car was specficed in the original PET (Boxster engine shown courtesy Pelican Parts):
    Also, if you actually want to fix the problem, and not just band aid in a solution then you need to modify the crank and rods:
    My car has raced for over a year with the above modifications, but without an accusump or TPP kit without isssue. YMMV.
    Cheers,
    www.caymanspec.com
    Vision Motorsports - Fikse - JRZ - Tarett - MantisSport - Yokohama/Trackside Performance
    Oct 2008
    Germany
    282
    Gamertag: Cay27
    Just curious, does this problem affect the 2.7 engines?
    May 2008
    IN
    2,383
    40
    So Porsche subsituted spraying the oil against the sump wall for an actual separator. Do these just bolt in other then needing to mod aftermarket windage trays?
    For curiosities sake what's the mod to the crank and rods?
    Les
    Sep 2006
    SoCal
    1,944
    133
    162
    46
    Quote Originally Posted by Greywolf View Post
    Yes, it appears so.
    The swirl pots just bolt in, no issue.
    Crank - grooved the main journals (improve oiling), straightened, hardened, polished. Rods - forged Carrillo.
    Cheers,
    www.caymanspec.com
    Apr 2007
    So. Cal
    506
    33
    Quote Originally Posted by Krokodil View Post
    Yes, it appears so.
    Cheers,
    Hello Krok,
    Does this means that you install (2) each of the 996 P/N (996 107 080 54), on at each side of the oil pick up suction tube?
    Sep 2006
    SoCal
    1,944
    133
    162
    46
    Quote Originally Posted by Gilles View Post
    Hello Krok,
    Yes. Easy job with the sump plate off. A bit more involved if you are installing a deep sump and windage tray as the tray needs to be modified to allow the swirl pot to pass through (need to cut a hole).
    Cheers,
    www.caymanspec.com
    Oct 2008
    56
    Well i am all over this thread to see what TPCicon will come up with .
    I can't track the car anymore without solving this and ttp asked 1600e for the pumps and 900 for the extension pan without tax & shipping WoW
    Soz i better go sailing .....
    Comon TPC
    1,766
    42
    42
    40
    How much for two 996 107 080 54?
    Tomasz
    Sep 2006
    SoCal
    1,944
    133
    162
    46
    Quote Originally Posted by Tomasz View Post
    Pelican Parts says $35 each, but I think Suncoasticon sells them for less. Either way, not an expensive part. Your local dealer should also be able to source.
    Easy to install when the sump cover is off (e.g., while doing a deep sump install).
    Cheers,
    www.caymanspec.com
    1,766
    42
    42
    40
    Thanks. I should have checked Pelican, I posted at 10PM, so I could not call.
    Tomasz
    1,766
    42
    42
    40
    This is definitely a couch tuning question as I do not even come close to understanding all these systems. But all engine failures seem to have occurred WITHOUT the oil pressure light coming on. Therefore, will the Accusump help at all? Will it discharge oil since there is no detectable oil pressure drop? Does the Accusump "measure" oil pressure differently than the oil pressure sensor?
    Tomasz
    Apr 2007
    So. Cal
    506
    33
    Tomasz;
    I believe that the Accusumo does not have any meassuring device, it works by pressure differential, (is just a hydraulic accumulator)
    For example if your engine normal operating oil pressure is @ 45 psi, this pressure fills the Accusump with oil (against an internal rubber bladder) @ 45 psi, and whenever the oil pressure drops below 45 psi the Accusump will push back the oil into the engine immediately by the pressurized rubber bladder.
    The theory is really simple, the trick is to ensure that you have a proper installation (leak free) and to determine how do you want to trigger the signal to open the electric valve solenoid on the accusump, unless you want the accusump next to your seat (like a race car) with a manual operated valve...
    34,004
    1609
    3061
    5368
    273
    No, check Suncoasticon, they are a sponsor, Pelican is not.
    MD
    691
    36
    "Well i am all over this thread to see what TPCicon will come up with .
    Comon TPC"
    Wow! That is quite pricey TPC...
    1,766
    42
    42
    40
    Suncoasticon is the place I shop. They have a bunch of my money... alcantara interior, RS60 tips...
    Tomasz
  1. Engine Failures With Oiling Mods
    By diverdog in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-04-2013, 12:36 PM
  2. Causes of M97.21 Engine Failure?
    By Krokodil in forum 987 Cayman and Boxster Service and Tech
    Last Post: 09-14-2012, 11:11 AM
  3. how to prevent CS engine failure - what is your experience?
    By got1 in forum 987 Cayman and Boxster Chat
    Last Post: 02-17-2012, 12:49 PM
  4. Preventing Oil System Related Engine Failures
    By wgn in forum 911 Modifications
    Last Post: 05-08-2010, 11:23 AM
