996TT rear brake ducts
Results 1 to 19 of 19
Thread: 996TT rear brake ducts
    I have been having bad problems this year with overheating my rear brakes at tight tracks like Gingerman and Autobahn. After about 25 minutes of driving, (with PSM off) I would get a completely squishy brake pedal, requiring pumping to get any braking done.
    Strangely enough, the problem seemed to be with the back brakes. The calipers have turned a dark brown/purple color, much more so than the fronts. I was having to bleed the brakes at the beginning of each day, and the back calipers always seemed to have the air bubbles in them.
    What could be causing this? I think it most likely was the "Active Brake Differential" feature, which apparently is on even when PSM is off. So, I recently went "mod crazy" and had the Guard 50/80 LSD installed, along with the Softronicicon ECU flash and Agency Power exhaust. I also found these brake ducts, which are Porsche OEM parts, from Vivid Racing:
    Porsche OEM 996 C2/C4/TT Rear Brake Ducts 99-05 Image2
    The Porsche PNs are 996-331-127-90 and 996-331-128-90, for the left and right duct respectively.
    We had to trim the ends off a bit to get the ducts to fit around the cross braces, but they did attach to the control arms quite snugly:
    http://www.planet-9.com/gallery/users/4592/1-1.jpg
    The shields behind the rotors were also removed.
    I tried all this stuff out at Gingerman this last weekend, and my brake pedal was solid the whole time. I attribute this mostly to the LSD, as the "brake diff" feature was no longer necessary. I tried running one session with PSM on with dry pavement, and it really cut in much less than usual. Turns 2 and 3 at this track usually cause a lot of "chatter" from PSM, but with this new LSD it apparently didnt have to intervene.
    I cant really quantify how much these brake ducts helped my problem, but I figure its never a bad thing to get more air channeled towards your brake rotors.
    Ohio
    1,212
    42
    Re: 996TT rear brake ducts
    I wore out a set of rears on my 09 CS As well. Thanks for the information.
    DFW TX
    3,909
    46
    445
    170
    Quote Originally Posted by astoddard View Post
    I have been having bad problems this year with overheating my rear brakes at tight tracks like Gingerman and Autobahn. . .
    What kind of pads do you run on the track? With Pagid yellows front and rear, my brakes seem to be pretty much front biased.
    Thanks for posting up the novel cooling solution.
    2011 Macan S: Wifey's DD
    Pagid yellow or black. I was running black for a while then started having this problem. I experimented with a set of orange in the back on the theory that the black created too much friction, therefore too much heat. I dont think it helped much. The car really needs an LSD to stop the electronic wizard from applying the back brakes to counter the wheelspin from the open diff.
    Mar 2008
    NV
    2,485
    80
    300
    This looked like such an elegant solution I decided to add it to my car. With the turbo I want to keep the rear brakes & hubs as cool as possible. I added a little improvement by bending the plastic to close off the cut end of the duct.
    Here are some shots of the cutting & shaping process. The plastic material cuts nicely with snips. It will hold a new shape if you bend it carefully. Don't bend it more than once though or it will crack. The pic with the through hole for the bolt is in the wrong place. It should be equidistant from where it is now and the big existing hole. I used a 3" 10/32 screw & stop nut to mount as the supplied clips will interfere with my TPCicon roll bar links. There is a conveniently supplied hole it the control arm it jut the right spot! With stock links the clips will work fine.
    I'm sure some of you eagle eyes viewers noticed that this is the second ducting I have on the rear brakes. The deflectors shown in the wider wheel well shot where installed by TPC. They came from their junk pile of old race car parts.
    Attached Thumbnails Attached Thumbnails 996TT rear brake ducts-car-wide-jpg
    2007 4.0L Twin Turbo Cayman S Race Car
    2013 Boxter S PDK Daily Driver
    Jun 2007
    Kirkland, WA
    2,367
    45
    GREAT advice here! Smart modification, the rears are often overlooked...you ought to see what happens with a *997 GT3 with PSM left on* ...OMG the rears wear TWICE AS FAST AS THE FRONTS*
    CRAIG: 425-765-1090, www.Rennstore.com --assistance & discussion for your pad selection welcomed. E-MAIL OR CALL - IMMKEDIATE REPLIES - SAME DAY!
    PAGID & Performance Friction BRAKE PADSCOMBINED, THE CHOICE OF NEARLY EVERY PRO TEAM - all compounds ready to ship!
    GIRODISC ROTOR SETS NOW AVAILABLE - SPECIAL PRICING - floating rotor sets 100% made in USA - no offshore mystery metal - the best of the best
    Nov 2005
    RI
    2,673
    62
    Nicely done! Mind if I copy your homework? I've had a set of the rear Turbo ducts sitting in the basement since November, just waiting for some better weather here in the Northeast...
    BTW the GT2 front ducts are going back on. While the GT2 fronts are easily torn off on the street, the GT3 front ducts just dont get the job done on my NA CS.
    Mar 2008
    NV
    2,485
    80
    300
    Mark, glad I can help you out for a change. You do know it was you that started my down the slipery slope of mods?
    I think GT2 ducts will be my last mod this season. Any mods necessary to add them to a CS?
    Nov 2005
    RI
    2,673
    62
    Smile Re: 996TT rear brake ducts
    Hey Bruce! The Gt2 fronts are easy installs, just some small snips in the pan to open a slot to fit the longer leading edge of the scoop... Alternately you could remove material from the scoop itself but that's going backwards!
    Sunnyvale CA, Fort Collins CO, Osaka JPN
    737
    227
    72
    Just updating this thread a bit, had a set of 996 TT rear brake ducts that I had purchased from Suncoasticon sitting in the garage and decided to install them on the car.
    As per diverdog's modification, ended up sealing the end of the duct closer to the diagonal brace/skid pate and added a bit of a lip on the exit of the duct to help direct the air upwards towards the rotor.
    Used alternating layers of duct tape along with aluminum HVAC tape to form the various shapes as well as reusing bits of plastic to form the lip at the exit of the duct.
    Also had to do a bit more trimming at the end to clear the longer bolt used to attach the RSS Tarmac LCA to the rear upright.
    Still using the stock swaybar with some aftermarket droplinks so was able to use the stock 996 bracket along with some zipties to hold the duct in place.
    Wasn't too happy with the performance of the hacked 996TT ducts so ended up ordering a set of 997 GT3 rear brake ducts from Suncoast along with the RSS LCA specific brackets from RSS to see if they could be modified to work on the 987 platform.
    Sadly after receiving the GT3 rear ducts and doing a quick check it became obvious that they would not work. The duct won't clear the diagonal brace of the skid plate nor will it clear the ends of the rear sway bar, given it's shape it won't work on a 987 at all.
    Currently pursuing a lead on a custom rear brake duct solution, hoping that it will pan out.
    Mar 2008
    NV
    2,485
    80
    300
    I like the NACA ducts the Interseries cars use.
    You can see that the bigger Girodisks I have on my rears get a more direct hit from the ducts
    Sep 2007
    Boston-ish, MA
    3,685
    137
    172
    Quote Originally Posted by 2slow2speed View Post
    I had looked into the GT3 ducts myself but had read that they're a no go for the 987 before pulling the trigger.
    I do have the 996TT ducts awaiting 987 fitment surgery though. What didn't you like about their performance? Did you take temp measurements? Also, did you trim the rotor backing plate?
    737
    227
    72
    Quote Originally Posted by rubber_ducky View Post
    The only post that I could find about the GT3 rear ducts was from Krokodril over at rennlist without any definitive conclusions so I just gave it a quick try. The folks over at Suncoasticon and RSS were very accommodating with the test fitting experiment.
    As far as the modified Turbo ducts, temps on the rear rotors only went down about 50-70 degrees F vs running without having the ducts. Ended up removing the entire heat shield (rotor backing plate) since there are no rubber bushings in that area of my modified R's suspension.
    The rear rotor still runs about 200 degrees hotter than the fronts at Laguna Seca so trying to get a better handle on temps to make it easier with pad selection as well as pad/rotor longevity.
    Diverdog's post pretty much reflects the direction that I am pursuing with a couple of shops, trying to source the correct parts from the shops as a kit instead of having to order multiple sets of NACA ducts and hoses to see what will work.
    737
    227
    72
    So dropped by the local Porsche dealer again this afternoon, while looking a bit more on the 981 a friend pointed out that the rear wheel well area of the car seems to be a bit more open to allow for more engine/tranny cooling on the 981.
    I happened to notice that there is now a rear brake duct on the 981, makes sense considering that PTV uses the rear brakes to help rotate the car.
    Maybe Suncoasticon can check and see if the part will be plug and play compatible with the 987's rear suspension bits. From what I could tell the 981 rear suspension did not seem to be that much different from the 981's, but then again that was with only a cursory examination of the car on the showroom floor and not on a lift.
    Sep 2011
    PA
    1,731
    179
    229
    Any update on the 981 solution?
    PCA National Instructor
    1995 Spec Miata
    2011 Boxster Spyder - 6MT, GT2 sport buckets
    2008 Suzuki GSX-R600
    Jun 2012
    NE
    410
    161
    58
    please, update on the 981 solution, I'm interested as well.
    Current:
    16 Cayman GT4|CWM|918 CF SEATS|LED SIDE MARKERS| NO NIPPLES NO HUMP
    Parts to be installed: FABSPEED SPORTS HEADERS|VORSTEINER WING EXT|PORSCHE MOTORSPORT SIDE DECALS|PORSCHE WING DECAL| GO FAST STICKERS
    10' BMW X5d
    PAST: 93 Accord|98 Camry|04 TSX SC|06 E46 M3|06 AUDI A4|05 Civic Si|05 Imprezza|05 S2000|08 TOYOTA FJ|09 Cayman S|09 Audi Q5 3.2|14 981 Cayman S DBM|
    RIP:08 M.Coupe SMB #102/248 #1669/1815
    Jan 2012
    Chicago Burbs
    911
    206
    179
    Quote Originally Posted by sho-one View Post
    2006 Basalt Black Cayman S
    2003 Titanium Miata
    Mar 2009
    Left Coast Florida
    273
    167
    34
    Couldn't get the 981 part number from Porsche yet, so I just did the 996tt ducts-small easy fab work to get them on. Took 45 minutes to complete. Only had to cut 2.5 inches off the engine end of the duct and Viola it was like it was made for the Cayman, all the holes lined up perfectly. I spent more time with the wheels and jack than the ducts.
    Amateur Writer, Closed Reply, Do Not Attempt.
    Before replying, check with your doctor to see if your heart is heathy enough for reply.
    This is Autocutter, and I approve this reply.
    Mar 2009
    Left Coast Florida
    273
    167
    34
    I saw the 2014 Cayman/S Brake Duct yesterday at the St Pete Autocross event. The rear ducts were clearly visible, but IMO I don't think the would be as effective at cooling than the 966TT mod-awesome looking car tho
  22. Remove Advertisements
  1. Rear brake ducts for 987s
    By the_vetman in forum 987 Cayman and Boxster Competition
    Last Post: 02-18-2015, 12:35 AM
  2. 981 brake ducts revisited - 987 rear brake ducts upgrade?
    By STLPCA in forum 981 Cayman and Boxster Modifications
    Last Post: 04-18-2014, 03:44 PM
  3. 997 REAR Brake Ducts (non-GT3)
    By Matt at Dunlop in forum 987 Cayman and Boxster Competition
    Last Post: 05-06-2013, 07:43 PM
  4. 2010 GT3 RS Rear Brake Ducts
    Last Post: 09-22-2010, 05:00 PM
  5. For the 997 GT3 - Rear Brake Duct Spoilers
    By suncoastric in forum 911 Modifications
    Last Post: 09-01-2010, 02:29 PM
