question PSE
Results 1 to 3 of 3
Thread: question PSE
    SoCal
    49
    question PSE
    is PSE actully bigger piping than the regular exhaust or only with control valve to make it quiter when not flooring it?
    when the valve is close, is it as loud as the regular ones? ( which means the regular exhaust stay in more free flow condition than the sports? )
    Oct 2008
    Belgium
    Re: question PSE
    When the valve is closed, the PSE sounds just like a stock exhaust.
    All diameters of piping are the same.
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Re: question PSE
    The PSE simply has some small bypass pipes in the rear boxes and when the valves are closed the systems is identical in operation and sound to the standard system.
    Once the valves open a (very) small amount of exhaust gas is allowed to bypass part of the muffler system, which provides the slightly louder exhaust note.
    Porsche state that there is no performance increase. Looking closely at the construction one could conclude that there maybe be a tiny performance gain, but there is no evidence to support that and would most likely not be something that would show up on a dyno due to the variations on seperate runs anyway.
  1. Another exhaust question: PSE vs Carnewal for Cayman R
    By djm68 in forum 987 Cayman and Boxster Modifications
    Last Post: 07-07-2014, 06:43 AM
  2. 987 PSE Question
    By harryo2b in forum 987 Cayman and Boxster Modifications
    Last Post: 12-23-2009, 08:37 PM
  3. Question on Sport Exhaust (PSE)
    By Redbear in forum 987 Cayman and Boxster Chat
    Last Post: 10-15-2009, 09:16 PM
  4. PSE owners question
    By Dunebasher in forum 987 Cayman and Boxster Modifications
    Last Post: 05-27-2009, 07:37 AM
  5. newb question: how to tell the difference between PSE and tips
    By mwy23 in forum 987 Cayman and Boxster Chat
    Last Post: 03-12-2009, 05:13 AM
