Measuring oil level
Results 1 to 6 of 6
Thread: Measuring oil level
    Jan 2010
    Measuring oil level
    I know the car checks the oil each time I am about to start the car. Most of the time it says 6 seconds. Sometimes, it's 3-4 minutes. This usually occurs after I have stopped the car less than five minutes and want to restart. That is a slight nuisance but I'm willing to wait 4 minutes, as I have gathered that I should not interrupt the process and start the car (I think that's what the manual said). But today, it said 20 minutes! I had just stopped the car to put air in my tires and when I was about to start it it wanted to measure the oil level but take 20 minutes. I couldn't wait there for 20 minutes so I played around with the computer and think I cancelled it. Any thoughts on what I should do next time?
    11,671
    178
    308
    5270
    79
    Re: Measuring oil level
    Why is the car checking the oil every time you start? Unless you specifically want to check the oil, turn the key all the way so that the engine starts.
    If you stop the key before the engine kicks over, it go into the oil check mode and if you have just stopped the engine, yes it will take a long time to check.
    Even if you get into the oil check mode accidentally, just keep turning the key to start the engine. You're not going to hurt anything by canceling the check.
    Now if you start the engine and it's still checking the oil level, something else is going on, unless you have a GT3 or twin turbo engine in the car (those require the engine to be running to check the oil level).
    Pete
    2016 Agate Grey GT4
    Jan 2010
    I just acquired the car so I just assumed it automatically checked the oil level before starting the car. It does it automatically. I do not initiate it. Maybe I or the previous owner set it to check the oil every time? If so, how would I turn this function off?
    DFW TX
    3,909
    45
    445
    170
    Quote Originally Posted by 987S8DTT View Post
    As Pistol Pete suggested, it sounds like you are just pausing at the ON position when you turn the key, long enough to see the Checking Oil message - this will happen anytime you turn the key to the ON position. If you just turn the key all the way to START the engine, it will start without checking the level, or if it starts checking the level, but you don't want to wait the time it indicates, then you can go ahead and start the engine - you won't be hurting anything.
    2011 Macan S: Wifey's DD
    Jan 2010
    Since Driver's Ed, I was taught to turn the ignition to on before actually starting the car. That explains why it is measuring the oil level. In the future, I'll just ignore it if it takes too long. 6 seconds - no problem but 20 minutes, no way! Thanks to both of you.
    11,671
    178
    308
    5270
    79
    Now it makes sense why you kept seeing the oil measurement!
    Pete
    2016 Agate Grey GT4
  9. Remove Advertisements
  1. Oil Level Measurement--what am I missing?
    By ecdysiast in forum 987 Cayman and Boxster Chat
    Last Post: 02-22-2010, 01:40 AM
  2. oil level guage slow
    By Greg Merril in forum 987 Cayman and Boxster Service and Tech
    Last Post: 02-23-2007, 05:44 PM
  3. Oil Level for track
    By Chris R. in forum 987 Cayman and Boxster Competition
    Last Post: 09-08-2006, 11:39 AM
  4. Oil level high
    By michael young in forum 987 Cayman and Boxster Chat
    Last Post: 06-18-2006, 07:34 PM
  5. Oil Level Check
    By RCayR in forum 987 Cayman and Boxster Chat
    Last Post: 04-21-2006, 09:29 AM
