P2187 P2189 error codes posible causes
Results 1 to 4 of 4
Thread: P2187 P2189 error codes posible causes
    Apr 2006
    Puerto Rico
    1,620
    83
    I had the P2187 (bank 1) and P2189 (bank 2) error codes come up several times after I reset them with durametrics. I was in Pin and Needles for a while. You allways think of the worst.
    My searches resulted in this post from a fellow at Renntech forum with the handle Loren:
    CEL fault code p2187 - RennTech.org Forums
    (quote)P2187 Oxygen Sensing Adaptation, Idle Range, Bank 1 (RKAT1) - Above Limit
    Possible fault cause
    - Incorrect main charge signal
    - Intake air system leaking
    - Fuel pressure too low
    - Volume supply of fuel pump too low
    - Mechanical fault in injection valves
    - PCV valve leaks
    - Cap of oil filler neck leaking
    - Leaks in exhaust system
    - EVAP canister purge valve mechanically faulty (hangs open)
    - EVAP canister purge valve output stage faults
    Chances are it was the gas cap.
    Don't worry about unless it comes back on. Then check the other possible causes.(end quote)
    In my particular case it turned out to be the oil filler cap was not fully closed.
    In the mean time I cleaned the mass air flow sensor, (Scott Slausons suggestion). I had a mechanic tell me my alternator was starting to fail, I would had to change the mass air flow sensor, the catalitic was failing, I had a leak in the exhaust. The world was comming to an end.
    Thank goodness it was just the oil cap. The renntech info was the best I could find on this particular error codes. I hope this post saves someone some of the anguish and grief I went through.
    Having fun in Puerto Rico
    trenton nj
    582
    Re: P2187 P2189 error codes posible causes
    tanks for sharing
    Thanks for sharing. You solved my problem!
    JD
    Mar 2009
    Left Coast Florida
    259
    167
    34
    Thanks for the TShoot findings! How did you narrow it down to the oil cap since the code seem to focus on the fuel intake side?
    Clinically proven to be smarter than you're!
    Amateur Writer, Closed Reply, Do Not Attempt.
    Before replying, check with your doctor to see if your heart is heathy enough for reply.
    Do not reply if you want to become pregnant or you're pregnant!
    This is Autocutter, and I approve this reply.
  7. Remove Advertisements
  1. Help~error code P2187
    By liren in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 05-23-2012, 09:29 PM
  2. Error Code P2187 and P2189
    By docsalvage in forum 987 Cayman and Boxster Service and Tech
    Last Post: 09-21-2009, 08:30 PM
  3. Exhaust CEL Error Code Fix?
    By advantyper in forum 987 Cayman and Boxster Modifications
    Last Post: 09-30-2008, 10:57 AM
  4. CEL error code P2196, any suggestion on fix?
    Last Post: 09-30-2008, 10:55 AM
  5. Error Code P0461 P2196 - Anybody?
    By Morefun in forum 987 Cayman and Boxster Service and Tech
    Last Post: 09-15-2007, 07:25 PM
