problem with engine! limping at 4K
Results 1 to 15 of 15
Thread: problem with engine! limping at 4K
    May 2008
    306
    17
    Hi guys,
    my cars seems to have broken today! to further explain, i am unable to rev past 4K, it hesitates and starts to choke around 3.5K
    i have no CEL lights and this problem jsut started today. i have had Softronicicon 4.1 (SRPicon) for about a year as well as FVD exhaust. durametrics shows the following error codes below.
    my friend suggested a bad tank of gas? i am not sure this is the case though... i am thinking i might clean out the maf sensor and see if that helps? anyone have any ideas on the error code? thanks alot
    http://www.planet-9.com/gallery/files/9/3/8/9/error.jpg
    06 Carrara White S - SRP 4.1 / FVD Exhaust / Techart Springs / 19" Carrera Classics
    May 2008
    306
    17
    Re: problem with engine! limping at 4K
    update, just cleaned out the maf sensor and noticed there was quite a bit of oil pooling up in the intake hoses. however, the actual maf sensor didn't look that dirty. i cleared the fault codes with durametrics and went for a drive.
    no luck, same problem persists with the engine "choking" and cutting poewr a little after 3000K rpm. the check engine light went flashing for about 30 secs before it disappeared. i checked durametrics and no codes came up? (not even the one i had before)
    i am out of ideas so if anyone could chime in that'd be great. would failed cats do this? i'm also thinking it's possible my friend was right with the bad tank of gas?
    34,004
    1609
    3061
    5368
    273
    Do you have headers with cats? If so which model header/cats? Failed ones usually result in misfires due to the backpressure of a clogged pipe. Probably time to take it to the dealer.
    May 2008
    306
    17
    oem headers, just the FVD exhaust after the cats.
    do oem cats fail easily?
    Sep 2008
    USA
    798
    72
    Your second screen shot shows your oxygen sensors have failed. That's probably what is putting your engine into "limp home mode." This issue certainly needs to be diagnosed/remedied. Perhaps a mechanic with a better diagnostic tool can tell which of the sensors have failed, or read more error codes.
    ’08 Cayman S, 6MT, PASM, Sport Chrono, Sport Seats & Steering Wheel, 19” Carrera Sport Wheels, PCM, Bose, Xenon, plus some other stuff not worth mentioning
    May 2008
    306
    17
    Quote Originally Posted by downshift View Post
    but according to this thread, that is normal?
    http://www.planet-9.com/cayman-boxst...urametric.html
    34,004
    1609
    3061
    5368
    273
    I thought P2188 meant that the system was running too rich on bank 1? If that's truly the case they you'd have to look at things that control how lean or rich the mixture is. Certainly the MAF does, but other things do as well. An ECU flash could cause you to run too rich depending on its settings. I suppose a bad coil or a non-firing plug would do so too, although if a coil were faulty I would think that would trip an entirely different code, but a fouled spark plug I could see being a contributing factor. We can all sit here at our computers and "guess" at the problem, but I really think you ought to take it into your local dealer and have them check it out. They have a PIWIS machine that will give them lots of information, and they have a library of troubleshooting experience and will likely be able to quickly identify and resolve the problem. If your car is under warranty then great, if not then it will cost you something to diagnose and/or fix the problem. It looks like you've done about all you can do at this point. I'm not buying the "bad gas" suggestion from a friend, the oil and gas industry is so regulated these days that the odds of getting bad gas are pretty remote, especially gas so bad that it could cause the symptoms as you've described.
    May 2008
    306
    17
    diagnosis from the dealer was a bad MAF, and not covered under warrenty because of my SRPicon mod.
    my question is, would this be from all the oil that was acumulated inside the intake pipes? if so, why do our engines have so much oil leak out? i remember reading another post where a fellow was i think cleaning his MAF and also found the intake tubes covered with oil? is this a byproduct of SRP or all m97 engines?
    thanks
    frustrated.
    34,004
    1609
    3061
    5368
    273
    All M97 engines have oil in the intake, those with failing or failed VOS's have a LOT
    HOWEVER, oil should NOT go backwards and foul the MAF, if the MAF was fouled it is typically by something ahead of the MAF like an aftermarket air filter that was over oiled.
    May 2008
    306
    17
    my air filter is the oem paper one which was also changed last year. if the oil doesn't go back and **** it out, what would cause this?
    34,004
    1609
    3061
    5368
    273
    Sometimes MAF sensors just go bad. If it was foulded it could be cleaned and reinstalled, if it went bad, then again it should be covered IMHO, unless you are out of warranty anyway. If oil was able to make its way all the way back to the MAF (means turning some corners and going against the air flow) then I think you'd have bigger problems. Ask them to show you exactly how the SRPicon caused the MAF to go bad, I think they are blowing smoke up you know where..
    May 2008
    306
    17
    well my car is 1 month over warrenty so that's why they are not covering it...
    well i hope they are right with a bad MAF and not the o2 sensors as suggested by another forum member....
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    06cs, based on your initial post of hesitation at the rpm you mention I certainly say the first place to start would be the MAF.
    Fouling is beleived to be a common cause of MAF failure when aftermarket filters are installed, and in theory if too mutch oil is put on an aftermarket filter it could cause the MAF heated sensors to overheat, but there are lots of different opinions on this aspect.
    MAF's as with any other solid state component can fail, just because it wants to, not because of any external factors necessarily. I have a lot of expierience of MAF failures in my job as a technical manager for an industrial vehicle manufacturer and also from dealing with VAG 1.8T engines quite a bit.
    May 2008
    306
    17
    Quote Originally Posted by Dunebasher View Post
    sigh, just not happy with the $1100 they are charging me for a $280 part i can buy online from Suncoasticon....
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Quote Originally Posted by 06cs View Post
    Now that is bad! Sounds way too overpriced to me.
  18. Remove Advertisements
  1. Replies: 0
    Last Post: 12-04-2012, 07:00 AM
  2. Nasty Engine Clatter at Start Up
    By Sully in forum 987 Cayman and Boxster Chat
    Last Post: 04-10-2010, 10:36 PM
  3. Sensor problem with engine firing?
    By Bodhii in forum 987 Cayman and Boxster Competition
    Last Post: 08-24-2009, 09:48 PM
  4. Problem with Clear Bra?
    By eyeguy in forum Porsche Care and Detailing
    Last Post: 04-30-2008, 06:30 AM
  5. Engine troubles at ButtonWillow
    By johnw3d in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 05-07-2007, 02:11 PM
