Cayman 2.7 engine vibration
Results 1 to 6 of 6
Thread: Cayman 2.7 engine vibration
    Oct 2010
    MA
    60
    Question Cayman 2.7 engine vibration
    Hi - new to Porsche experience with a 2008 base Cayman and cant get enough. As I get to know the car I'm noticing what feels like engine vibration or some harmonics at around 3000RPM in any gear. I can feel it through the steering wheel so its hard to pinpoint the source. Also cannot get more than 23MPG ( although I am driving fast and high revs mostly) Appreciate any feedback. Will get it to dealer soon
    1,029
    228
    43
    Re: Cayman 2.7 engine vibration
    My 2.7 is a 2007 vintage... sorry, but I don't get such a vibration... pretty smooth up though the whole rpm range... (done so at DE's..).
    W/r to fuel economy.. my "normal" driving with some city, mostly freeway gets about 27 to 28 mpg.. the 30+ mpg only when being gentle at freeway only speeds. For reference... running pretty much all on at Laguna Seca gets about 11 to 12 mpg.. so, aggressive pushing high rpm's will drive down fuel economy.. Just to confirm the thesis, try a tank without spinning past 5000... even short shifting while on the freeway -- e.g. below 4000... see what you get.
    D
    1,289
    58
    163
    Fuel efficiency seems normal, so I doubt your engine is misfiring. Since the vibration happens at a given RPM regardless of road speed, it sounds to me like something is out of balance on the engine side of the clutch...perhaps the dual-mass flywheel?
    Oct 2010
    MA
    60
    Folks - thanks for your insights...vibration is sporadic, can yet pinpoint or correlate but working that and will post when I get to the root. Will likely need dealer help ( 17K miles with lots of warranty left on the certified 6/100K ). Other than that, car is a complete blast..all positive writeups about this car are true and then some: power, steeing precision, handling, engine sound..the S would be nice but honestly, for road only, you would be hard pressed to actually utilize the extra horses. Handling is par. Cant keep cont of the compliments about this car.
    Missouri
    127
    84
    That's interesting, I feel a slight sporatic vibration at idle through my seat but not at the steering wheel. I'd like to know what this is before my warranty expires in Feb. Car is an 07 CS, 23K mi.
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Does it do it in neutral as well as in gear?
    If you have an MT how does the clutch feel i.e. Bite point and is it smooth?
    As Croc'ed said the flywheel could be one possible culprit and they do fail, sometimes at low hours.
    It's best though to let the dealer check it, so you can get back to driving it
  9. Remove Advertisements
  1. Engine Vibration around 1900 RPM
    By Rainer in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 04-18-2015, 09:57 AM
  2. If a cylinder not firing on the Cayman, any Check engine light?
    By caySman in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-26-2008, 06:49 AM
  3. My Cayman was exposed! (engine cover removal)
    By PistolPete in forum U.S. Northeast (Nor'Easters) Region
    Last Post: 06-03-2008, 08:15 AM
  4. Engine Vibration When Cold
    By Ollie 987S in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 05-27-2008, 07:51 AM
  5. Pictures of sony Cayman from sema (engine pics)
    By 6speedcayman in forum 987 Cayman and Boxster Modifications
    Last Post: 11-15-2006, 12:07 PM
