Easy Rattle Fix - Passenger Dashboard/Vent
Results 1 to 11 of 11
Thread: Easy Rattle Fix - Passenger Dashboard/Vent
    Aug 2009
    VA
    230
    Gamertag: FunkyJunk
    I finally fixed the rattle that's been aggravating me for the past several weeks. User SaveChief found the source of the rattle in a previous post, but didn't update his thread with a how-to or any postmortem. I'll do that here.
    The fix is really easy (requires no tools at all), and I wasted a lot of time messing around with the passenger-side vent and the cupholder assembly trying to find the source. The rattle is indeed where SaveChief thought it was, where the plastic vent tube leading from the passenger-side vent connects to the ventilation system. The tubes become disconnected, and the vent-side tube rattles against fixtures behind the glovebox.
    To get to the rattle, open the passenger door and pull on the bottom of the trim piece to the right of the glovebox. The piece will pull out fairly easily - it's only held in by some tension clips.
    Once you've pulled that piece out, pull out the the plastic trim piece to the right of the piece you just removed. It attaches by two tabs that slot in behind the rubber door seal, and a tension clip at the front of the item. Pull it out of the tension clip, and pull toward the back of the car. Again, this item pulls out fairly easily.
    Now you'll be able to see the source of the problem. The black plastic vent tubes that connect to each other right behind the aluminum support brace will probably have come loose from each other. Simply push the vent tube on the right into the one on the left securely. Then use some duct tape or other solution to seal them up so they won't come loose again.
    At this point, I also wrapped some felt tape around the wire that hangs in front of the vent tubes, as I felt (ha!) that it would also help prevent any potential rattles. You can just pull the wire out a bit in order to get the tape on it.
    So that's it! Just snap the two trim pieces back into place in the reverse order you removed them, and you're done. So far, my rattles in this area are gone and I'm much relieved. Also, I know that if I hear the rattle again I can get to it on the spot with no tools needed.
    2006 Cayman S
    1982 911 SC
    Jun 2007
    SC
    116
    Re: Easy Rattle Fix - Passenger Dashboard/Vent
    Great job. That would seem like going down the rabbit hole to me. When I hear rattles I figure you would have to dismantle half of the car to get to get to it. Nice work.
    Nov 2008
    178
    I've taken my whole dash apart searching for rattles. Thanks for the write up. I would also suggest putting some felt tape or dynomat type material on the back of the metal panel mounting clip receivers. I found that there were a few rattles as a result of those shifting around. In addition, the metal knee supports behind the glovebox was dynomatted in mine as that metal was vibrating.
    Now I am rattle free (in that section).
    Jun 2010
    London
    348
    58
    76
    First apologies for the bump. I've got the rattle behind the air vent too, same side but RHD car. Kind of stops for a bit if I hold the dash top vent firmly but then it comes back. My Q - how to remove the lower dash section on the drivers side. Its one long piece so does it just pull down and out or is it more complicated than that? I'm a bit anxious about giving it a big tug and breaking a fastening or something.
    Apr 2012
    47
    Has anyone determined why our Caymans rattle so much? Is it because the chassis is so torsionally stiff, it shakes the interior loose? Does Porsche not know how to put a modern interior together? Or- Maybe we're just an overly anal-retentive bunch?
    I wish I knew because these rattles drive me as mad as the rest of you
    2006 CS | 8/06 Build, GT Silver, Natural Brown Full Leather, 6MT, Sport Chrono, Heated Seats, Harman Kardon drive+play, Radar hardwire, Pilot Super Sports
    Dec 2006
    Georgia
    1,318
    230
    Been there, done that (yes the tube had pulled apart), still had the rattle.
    Went back in and pulled out the glove box to do a more thorough job duct taping the tube, including felt, cable ties on misc. things, etc., even put felt on top of the drink holder unit...........
    Still have the occasional rattle, that seems to be more tied to the resonance of the exhaust (Remus) as to hitting bumps in the road.....
    In2Esses
    2006 CaymanS - Black/Black
    2010 BMW 135
    2012 Mercedes GLK 350 4Matic
    Aug 2014
    Ca
    I appreciate you writing this up & posting pictures. Had a similar rattle in same area of my '11 987. Opened up the same area & found the little metal clip that holds the wire to the side of the panel, shown in picture 3, was cockeyed & causing one end of the metal clip to vibrate against the panel like a mouth organ. The vent tubes were connected but loose, so I realigned the clip & snapped it in properly, as well as tightened up the vent tubes with some cable ties. All is well now, just wanted to let you now I appreciate your help with the excellent post. If you've never heard a mouth organ before, it makes one heck of an annoying rattle.
    2014 Cayman S, Dark Blue Metallic - Sports Chrono, PDK, PASM, PSE, PCCB, PTV, PADM, Full Leather Luxor Beige/Black, Park Assist, Bi-Xenon w/DCL Retractable Mirrors, 2-way Sport Seats, Bose, Sports Steering Wheel, 20" Carrera Classics
    Mods: WeatherTech Digifit, LED Side Markers, DIY Grills, Wheel Locks, Tint, V1 w/Savvy
    Jan 2014
    568
    78
    106
    Quote Originally Posted by tampaCS View Post
    As long as the thread has been brought back...
    1) overly anal-retentive: yes
    2) I think it's 2 things together: (a) snap-together plastic pieces which are cheap and easy to manufacture and assemble, and (b) stiff suspension that transmits more shocks to the interior.
    But anyway I appreciate the post, this is a great how-to!
    Aug 2014
    141
    283
    I have the rattle! Very annoying. Pics have disappeared for the fix which would be very helpful if someone has a way to access or repost them. Thanks!
    Recreation Researcher with a black '08 Cayman 2.7 (manual) aka "Raven"
    PCA Member, First Settlers Region
    Apr 2013
    Oklahoma
    64
    My '08 CS suffered from this rattle, and although I don't have the original photos, here are some I took while applying the fix. The bad boy is the black duct I'm pointing at in #3.
    Easy Rattle Fix - Passenger Dashboard/Vent-1-1024x768-jpgEasy Rattle Fix - Passenger Dashboard/Vent-2-768x1024-jpgEasy Rattle Fix - Passenger Dashboard/Vent-3-768x1024-jpg
    In order to insure that the duct stayed in place I choose to add two small sheet metal screws, one at each end. Unfortunately this also meant I had to remove the glove box, etc. to reach it, but hey, at least I got some clear photos... Hope this helps.
    Easy Rattle Fix - Passenger Dashboard/Vent-4-1024x768-jpg
    Aug 2014
    141
    283
    Thank you! Looks like I'll be pulling the glove box.
  14. Remove Advertisements
  1. 3rd brake light rattle fix
    By igor in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 05-13-2013, 12:44 PM
  2. Easy rattle fix - passenger-side vent/dash
    Last Post: 12-15-2012, 05:53 PM
  3. Rear rattle Fixed!! after 5000km
    By proy in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-11-2012, 10:42 AM
  4. rattle in passenger side
    By drradin in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 07-10-2010, 09:25 AM
  5. cayman S grinding noise passenger side vent!!! help
    By CaymanS07 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 03-27-2010, 06:31 PM
