Engine problems started with loud screeching sound + white smoke
Results 1 to 19 of 19
Thread: Engine problems started with loud screeching sound + white smoke
    132
    Hello fellow fellow Porsche and Cayman lovers.
    Over the years my 06 Cayman S has been the most wonderful driving experience ever, minus the fact that it is a little bit underpowered as I had a supped up Twin Turbo Z in the past with serious power, but regardless it has been very reliable until this happened.
    I was driving to work yesterday, I was going pretty fast until I hit a stop and go spot. That's where I started hearing a loud screeching noise coming from the engine bay. It was kind of embarrassing while sitting in traffic. When the car picked up speed the sound disappeared, and when I put it in neutral at highway speed the screeching would come back.
    This sound is exactly like a loose drive belt that you hear on a normal car when cold that goes away when the car warms up. Since I did replace my drive belt and spark plugs + coils a year ago, I thought maybe it was just loose and I was starting to plan to tighten it.
    I park the car at work, come back 10 hours later, start the car and a big cloud of white smoke comes out from the exhaust !! That's when I realized I had a bigger problem !! The smoke goes away and does not come back unless I leave the car in idle for a few minutes and push on the gas to see some white smoke coming out !!
    The car drives fine with no signs of the problem other than that the RPM jumps to 2000 when I come to a stop and goes down to sit higher than normal at 900-1000 !!
    I get home let it sleep, check the oil next day in the morning, and it was unusually down to the middle mark, I put oil and start the car and it seems to idle normally this time!!
    What do you guys think the problem is !? I know this does not look cheap to fix !!
    Thanks a bunch
    11,671
    178
    308
    5270
    79
    Re: Engine problems started with loud screeching sound + white smoke
    Pete
    2016 Agate Grey GT4
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Quote Originally Posted by PistolPete View Post
    Just what I was thinking
    And fits the symptoms in this case as well....so hopefully a reasonably cheap fix.
    2008 997 GT3
    PTS RS Orange
    132
    It's funny that after I posted this .. I saw the post of Kman-Went that was posted 4 days ago !! Same story .. but I don't get white smoke until I park it for a while or leave it at idle .. I assume maybe a lesser level of failure !!
    Jun 2011
    Central Kentucky
    158
    It sounds like the VOS and I hope so since it's a (relatively) inexpensive fix. However I'm concerned as oil burns as blue smoke, not white. Is your coolant level okay?
    132
    Quote Originally Posted by printzone View Post
    Are you thinking head gasket ? I have not checked coolant level, you have to remove the engine cover to do that, correct !!?
    I have been watching the temperature and I did not notice the needle move outside it's normal position !! Most others described white smoke with the VOS issue !
    11,671
    178
    308
    5270
    79
    You can check the coolant level be removing the blue cap located next to the black oil cap in the rear truck.
    However, let the engine cool down overnight before attempting to remove that cap! Look down the opening and you should see a "MIN" indicator that normally will be immersed in coolant if the level is normal.
    Pete
    2016 Agate Grey GT4
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    The only thing I would say here is that most people when they look in their rear view mirror cannot determine white from blue (grey) smoke, so this may be a factor.
    The symptoms fit, and when you leave the car and start again that initial vacuum could be enough to suck oil through the VOS into the intake....but it could also fit in with what Printzone said on coolant, and a cracked head, blown head gasket etc. could explain leakage into the cylinder of coolant whilst the car is sat.
    I doubt you'll be able to tell anything from the levels, because a little of either fluid is enough to cause copious amounts of smoke.
    If you stand behind the car when you start it you should be able to notice the difference between burnt coolant and oil easily. If it really is coolant then you should not start the car again as you could cause a hydraulic lock up if too much coolant were to accumulate in the cylinders, and then you'd be talking big bucks to fix a broken block etc.
    My money is still on the VOS.
    2008 997 GT3
    PTS RS Orange
    132
    I have had a car with a blown head gasket before and I can tell you that is smoke and not steam.. Plus the coolant level will go down pretty fast and the " smoke" should be constant!
    I'll put in a new VOS tomorrow and we'll go from there..
    Anyone knows a dealer in LA/OC that offers discounted parts !?
    132
    I just took the engine cover off and took the hoses that connects the oil separator to the intake on both sides.. guess what, they were soaking with oil !!
    That pretty much explains it !!
    Now I need to get the part from the dealer and replace it .. very very easy. The crankcase hose and the intake hose, snaps right on, you just squeeze it on the sides. The oil return line will be slightly harder to remove since it uses a clamp and is buried down the engine.. will keep you posted !!
    Ohh also I need to get a tool to remove the star bolts .. anyone knows the size !?
    Jun 2011
    Central Kentucky
    158
    Good to hear! I don't know the size of the bolts but you might want to consider just getting complete set of Torx as they're used everywhere on our cars. Get from T10 to T40 or so.
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Actually you need the external torx bits for the VOS, more specifically the E10 external Torx bit.
    However it is worth getting the Torx bits as well for jobs you might do later on the car
    2008 997 GT3
    PTS RS Orange
    132
    All done .. car purrs like a kitten with an idle smoother than when it was new !!
    I took lots of pictures and will create a write up later.
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Quote Originally Posted by serrym View Post
    I take it the smoke has gone as well, right?
    2008 997 GT3
    PTS RS Orange
    11,671
    178
    308
    5270
    79
    Great news! Looking forward to the photos.
    Pete
    2016 Agate Grey GT4
    Feb 2011
    Hawaii
    121
    Your photos and description of the process will be a big asset to other 987 owners.
    2010 Cayman S, PDK, LSD, Sport Chrono
    132
    I created an article for your pleasure >>>
    Oil Separator Article
    33,871
    1570
    3026
    5365
    273
    Kudos on the article it will appear in our next newsletter. It would be nice if there was some simple guaranteed test an owner could do to test their membrane in the unit.
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Maybe put your lips around it and suck...yuck
    2008 997 GT3
    PTS RS Orange
  22. Remove Advertisements
  1. Survey for those with the Bose sound system
    By K-Man-sculpture.net in forum 987 Cayman and Boxster Chat
    Last Post: 02-07-2013, 08:10 PM
  2. Possible Engine Problem.. pls help..
    By matt in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 10-19-2007, 10:26 AM
  3. Loud fan sound 10 minutes after turning engine off
    By Toona333 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 02-18-2007, 12:07 PM
  4. Engine wouldnt start
    By rami in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 12-14-2006, 05:01 PM
  5. LOUD CLUNKY SOUND COMING FROM......
    By mrcohanian in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 03-20-2006, 06:47 AM
