Squeaky Clutch
Results 1 to 16 of 16
Thread: Squeaky Clutch
    Oct 2011
    Belfast
    Squeaky Clutch
    When I depress my clutch pedal I can hear a slight squeak.
    It's not audible if the radio is on, or when on the move, it's only on start up that it's noticeable.
    Is there a simple fix, as opposed to taking it to my local dealer? The car has Porsche warranty but I doubt a squeaky clutch will be covered!
    Jun 2010
    Maryland
    216
    Re: Squeaky Clutch
    Quote Originally Posted by Woodcutter View Post
    I have the same issue! With the car off and listening with my door open, it seems like the sound is coming from underneath the car someplace when I move the pedal. I might get underneath and have someone move the pedal while I listen. Might be an easy fix...
    Brian
    2007 Cayman S
    ohio
    723
    149
    Re: Squeaky Clutch
    Quote Originally Posted by moto-ufo View Post
    Probably nothing more than the spring... needs a drop of oil where it attaches to the clutch pedal.
    MD
    465
    129
    Re: Squeaky Clutch
    I have this as well. It sounds like it is coming from the front but it is actually coming from the rear. I do not know the correct terminology so bear with me.
    It is the arm that is at the transmission end of the clutch cable. This is found on the drivers-side of the trans. You can see it from the rear of the vehicle. I have tried spray silicone but that does not stop it.
    Jun 2010
    Maryland
    216
    Re: Squeaky Clutch
    Quote Originally Posted by j_copeland View Post
    In my case at least, the sqeaking isn't coming from the pedal area. When I move the pedal with my hand while listening to the underside of the car I can tell that it's definitely underneath there someplace.
    Brian
    2007 Cayman S
    Aug 2011
    161
    Re: Squeaky Clutch
    I noticed a squeak with my pedal as well, but it doesn't do it all the time. I've had other vehicles as well that had the identical problem. I just spray a little lube on it, and it usually goes away.
    Jun 2007
    GA
    380
    Re: Squeaky Clutch
    If it's not at the pedal, be advised that you may have an issue with your clutch which is hydraulically connectted, i.e., there isn't a mechanical connection involving a squeaky spring or rubber grommet. I had this issue early on and it resulted in a warranty replacement of something internal in the clutch. Can't remember exactly what it was, but it ain't good. Get the to a mech quickly.
    '12 Audi Q5, Moonlight Blue Metallic/Cinnamon, Premium Plus, 2.0 Turbo, 8 spd., MMI Nav, Bluetooth, B&O Stereo w/iPhone, SD card media, Xenons, LEDs, leather, 19" 5-arm Structure wheels
    '06 CLS 500, white, beige
    '04 Black Ranger Edge
    Jul 2009
    SF Bay Area (was: S. Florida)
    1,064
    86
    Re: Squeaky Clutch
    Any chance you guys are using aftermarket brake fluid? The squeek is fairly common for folks who have switched fluid, often reported by folks using the ATE super blue. I have Motul and notice it squeeks when I press in clutch.
    Chris
    2008 Boxster S : Speed Yellow : FVD tuned : Fabspeed headers & race cats : Remus race exhaust : Eibach springs : 19" Champion RG5 : Laser Interceptor + V1 : PFC 08/06 for DE
    Tracks : Mt Tremblant : Sebring : Lime Rock Park : Watkins Glen : Thunderhill-West : Homestead Miami : PBIR
    Backroads : Carmel Valley Rd (G16): Blue Ridge Parkway : Diamondback (226A) : Tail of the Dragon
    Jun 2010
    Maryland
    216
    Re: Squeaky Clutch
    Quote Originally Posted by lithium1330 View Post
    No aftermarket fluid here. Guess I should take the CS to my dealership for a checkup...
    Brian
    2007 Cayman S
    Sep 2010
    Re: Squeaky Clutch
    I have a 2008 Cayman S with the same issue. I sprayed the clutch pedal from inside with white lithium grease but the sound is comming from underneath the car. I'll look under the car this weekend. Anyone find the exact location of the squeak?
    Jun 2010
    Maryland
    216
    Re: Squeaky Clutch
    Hope you have luck finding the cause.
    It's no longer a concern as I've traded the CS for a Mini Cooper S for mostly economic reasons. Having a blast in the MCS so far though!
    Brian
    2007 Cayman S
    Sep 2011
    Attached to the scarp slope of the North Yorks Moors
    207
    Re: Squeaky Clutch
    Never mind mot you will get over it. IF you were really serious about it you would have bought a 1275 Mini Cooper. A proper car.
    Notice the non-use of capital letters in the word Mini. That is important.
    The secret of life, is enjoying the passage of time.........
    Jun 2010
    Maryland
    216
    Re: Squeaky Clutch
    Quote Originally Posted by Bennachie View Post
    Yeah, yeah ... !
    Brian
    2007 Cayman S
    Oct 2011
    Re: Squeaky Clutch
    I have this same issue.
    2 squeaks total, 1 from the clutch pedal and the other was from under the car.
    Long story short, took my car to the dealer and CPO warranty fixed the issue, it was a defective throwout bearing.
    The under car squeak is gone and the clutch is a little lighter now.
    MD
    465
    129
    Re: Squeaky Clutch
    Interesting that the dealer fixed your clutch with the CPO. I am the original owner and my car is still under warranty. The dealer told me - "It is probably the throwout bearing but squeaks are not covered." If we tear down the transmission and its not the throwout but just needs grease you have to pay for it."
    It's always been this way though from this dealer - never want to fix or pay for anything.
    Oct 2011
    Re: Squeaky Clutch
    Guess you need to head to another dealership with a nice service advisor.
    and also replaced all my TPMS.
    *they also gave me a free rental
  19. Remove Advertisements
  1. 07 CS CPO clutch squeaky sound
    By socalcaymans in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 12-09-2011, 04:43 PM
  2. Clutch/ Shifting/ Gearbox Problems
    By RedRocket in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 08-06-2010, 01:24 PM
  3. Squeaky window and clutch
    By S1MMA in forum United Kingdom, Ireland Region
    Last Post: 09-03-2008, 06:46 AM
  4. Any such thing as clutch adjustment?
    By chrismillion in forum 987 Cayman and Boxster Chat
    Last Post: 04-07-2006, 05:45 PM
  5. Twin-clutch transmission delayed
    Last Post: 12-30-2005, 07:06 PM
