Jack Pads
Results 1 to 7 of 7
Thread: Jack Pads
    Jack Pads
    Permanently installed jack pads from Audi will fit the Cayman and keep the jacking points from being scratched up. They also fit into the cups of many hydraulic jacks and offer some protection from the vehicle slipping off the jack.
    See Parts4vws.com and Parts4Audis.com - MKIV/B5/B5.5 Jack Pad Set for the parts and VWvortex Forums: The Official Jack Pad Install Write Up, for those who wanted it. for instructions. You may need to cut one of the wedges vertically for the rear jackpoints (it will be obvious when you feel inside the jack point how to cut the wedge) but they sure come in handy if you change wheels a lot.
    1,293
    60
    163
    Thanks for the post. Can you post pictures of this mod on your Cayman? How much ground clearance is left after installing the pads? Approximately how much weight is added?
    Jan 2006
    2,533
    33
    After installation of those pads on a Cayman, it reduces clearance for jack access, making a super low-profile jack a necessity. And having that pad in place will prevent jack stands being located at that point.
    It may work great on a Jetta; but I wouldn't recommend it for the Cayman. YMMV.
    - 2006 Cayman S
    - 2003 Dakota SXT
    LL
    Oct 2006
    Silver Spring, MD
    1,076
    80
    27
    If you are concerned about damage to your jack points but don't want to install something on the car, there are companies that sell urethane pads that fit over the end of the jack. I bought one for my small jack, which has a 2" cup, that works very nicely. On my large jack, which has a 5" cup, I just use a block of wood inside the cup, and found that to be equally effective. Another option that has been suggested on this board is to drop a hockey puck into the cup.
    Sep 2005
    New Mexico
    10,001
    Also check what our sponsor Boothe has to offer; Boothe Designs, Porsche parts and accessories, No-Turn Technology. Cheap and effective.
    Jun 2007
    Md
    330
    86
    NC/CA
    5,473
    1171
    1616
    I wax my wheels and sometimes change between the 17” and 18” wheels so I needed some kind of jack pad. Here’s what I found –
    I found a hard plastic drain cover at Lowe’s. (I am not talking about a drain plug! This is a drain cover.) The cover had two nipples – one on each side. I shortened the nipple on one side and ground off the nipple on the other side. The flat side rests on the jack. The short nipple fits in the hole on the jacking point.
    The drain cover is a perfect fit for the Sears Craftsman low profile jack that I have. Because the drain cover is perforated I can still use the L.E.D. light that is a feature of this particular jack.
  10. Remove Advertisements
  1. Easy DIY Jack Pad under $5
    By danieldolin in forum Automotive Off Topic
    Last Post: 10-01-2011, 07:31 PM
  2. Jack Pad (Alloy)
    By kareldeeley in forum United Kingdom, Ireland Region
    Last Post: 03-17-2009, 07:36 AM
  3. Jack Pads
    By skramk in forum Porsche Care and Detailing
    Last Post: 03-09-2008, 01:29 PM
  4. Jack Pad
    By fmarshall in forum 987 Cayman and Boxster Chat
    Last Post: 09-19-2007, 03:16 PM
  5. Porsche jack pads?
    By ARCuhTEK in forum 987 Cayman and Boxster Chat
    Last Post: 07-06-2007, 03:00 PM
