5 speed vs. 6 speed gearbox comparison (pics)
Results 1 to 18 of 18
Thread: 5 speed vs. 6 speed gearbox comparison (pics)
    Mar 2006
    536
    72
    OK I've found some 5 speed gearbox pics but I still can't find any 6 speed gearbox pics yet but I'm still trying
    So which manufacturer do you think this 5 speed is made by?
    http://www.caymanclub.net/gallery/files/1/2/3/3/01.jpg
    http://www.caymanclub.net/gallery/files/1/2/3/3/02.jpg
    http://www.caymanclub.net/gallery/files/1/2/3/3/03.jpg
    Oct 2006
    Connecticut
    7,322
    720
    172
    I'd say it's made by Getrag, just like the 6 speed. If fact, I am pretty sure that's the case.
    Aug 2006
    The Kingdom of Fife
    518
    I seem to recall reading that the 5 speed box is sourced from Volkswagen.
    JH
    Oct 2006
    5,642
    460
    640
    Gamertag: CaymanGT
    Incidentally....a read of the manual shows that the 6-speed's gear ratios for 1st and 2nd are DIFFERENT when in the 2.7 versus the 3.4, which I find interesting.
    (3.67 and 2.05 for the 2.7, but 3.31 and 1.95 for the 3.4)
    3rd through 6th are the same.
    Also, the final drive ratio of .82:1 for 6th gear isn't that much taller than the .84 in the 5-speed.
    I liked the 5 speed in my 2.7, by the way.
    "Carpe Cayman"
    DC
    2,248
    36
    Quote Originally Posted by John H View Post
    JH
    audi more specifically.
    Casey Parkin : Washington, DC
    Oct 2006
    Connecticut
    7,322
    720
    172
    JH
    I've got a little surprise for you. VW and/or Audi don't make transmissions. They source them out just like everyone else. That's sort of a specialty part. And they have also been known to use Getrags.
    I had once heard that they were made by VW, and another time that they were Japanese. I asked the Guru, Scott Slauson, and he had this to say:
    Quote Originally Posted by PCA-TECH View Post
    The G86.01 that was used in the 986 is much the same as the G87.01 that is used in the Boxster and Cayman. These are made by Getrag and are 5spd transmissions.
    The Aisin Seiki is used in the 997.
    Apr 2007
    Maryland
    1,600
    297
    84
    Gamertag: Porsche 987 S
    Quote Originally Posted by DaveN007 View Post
    So what do these ratios signify? Also what's a 'good' or 'bad' gear ratio...
    -Chad-
    2006 Black Cayman S
    2014 Fiesta ST (hilarious fun)
    Mar 2006
    708
    There are not many companies out there manufacturing transmissions. I say Getrag or ZF. A real dark horse would be the people in California "Butfoy" that make gear boxes for lambos, Vectors and others based on the old series SD-2 ZF.
    formerly cebotech1
    Oct 2006
    5,642
    460
    640
    Gamertag: CaymanGT
    Quote Originally Posted by golfguy11800 View Post
    Gear ratio - Wikipedia, the free encyclopedia
    The gear ratios will contribute to how quickly a car can accelerate and/or how fast it's top speed will be. My understanding is that the gear ratios in a Cayman S vary from those of a 911 in a way that makes the Cayman a bit slower to 60mph than it could be, with different gear ratios to avoid the problem of having a Cayman be too close for comfort to the 911.
    The new Nissan GT-R is a great example of creative gearing. It is geared to accelerate very quickly to 60...and REDLINES at 186 mph. They do this to keep up with the 911 Turbo which has the same amount of HP but 400 pounds less weight. The GT-R probably NEEDS the auto/manual clutch gizmo to shift quickly enough to take advantage of the gearing. My brother's 997 TT is very hard to nail in first gear without banging against the rev limiter.
    "Carpe Cayman"
    1,558
    golfguy: From the gear ratios reported above, the 2.7 Cayman has "lower" ratios (higher number = lower ratio) for the first two gears, giving it more grunt (applied torque) in those gears. This may be partly why some who've driven both back-to-back reported being surprised that the 2.7 was so quick up to 60 mph or so.
    When the '06 CS came out, it not only had higher gearing in the first two gears than the 997, but it also had higher gearing than the '06 Boxster S, which had 280 hp at that time.
    One way to increase acceleration of the CS would be to lower the gearing some, but that doesn't seem very simple. I've not understood why the gearing of the CS is as it is (the two top gears are both over-drives, for example), unless it was to help maintain the separation between the CS and the 997.
    Austria,Lower
    42
    Hi from Austria !
    You have stolen my pics ! This is my old gearbox in my garage ! Now you have to buy it !
    Greetings !
    Mar 2006
    536
    72
    Quote Originally Posted by mugenseiki View Post
    Hi from Austria !
    Greetings !
    LOL! Welcome aboard.
    Hey, is it Getrag?
    Austria,Lower
    42
    Hi again !
    There is nothing to find except "made in Germany", "VW" and "Audi" on the 5-speed-gearbox.I did a conversion to 6-speed from a Boxster S `07 and the 6-speed-gearbox is definitely made by Getrag.But the 6-speed-gearbox has a very big disadvantage - the weight !
    Best regards !
    Dec 2006
    wiltshire
    135
    gearbox looks identical to passat /a4 platform.
    ive had a few of these out.
    vag group make most of there gearboxes in house.
    engines grygor hungary plant / gearboxes kassel plant.
    (plus others of course, but these are the biggest.)
    Dec 2006
    wiltshire
    135
    i wonder if the bellhousing is the same bolt pattern as v.a.g ?
    it looks it !
    possible 1.8t / other v.a.g engine's in the future !
    even the old water cooled flat four (i used to rebuild these when i was a apprentice !).
    thats another thing - is the porsche bottom end similar to the vag water boxer ?.
    i know they share a lot of stuff !
    Mar 2006
    536
    72
    Do you have any pics of your 6-speed gearbox?
    Jun 2007
    420
    I swore the 5 speed in my cayman said aisin on it...
    Austria,Lower
    42
    Sorry - I didn`t take pictures before I installed it !
  21. Remove Advertisements
  1. Bentley GT Speed vs. Boxster S up the mountain - Who won? Pictures!
    By 981WC in forum 981 Cayman and Boxster Comparisons
    Last Post: 04-18-2013, 03:13 AM
  2. Subaru S204 6 speed vs cayman s triptronic
    By Rex in forum 987 Cayman and Boxster Comparisons
    Last Post: 10-10-2011, 05:54 AM
  3. Indicated Spedometer Speed vs Real Speed
    By jonnydeep in forum 987 Cayman and Boxster Chat
    Last Post: 09-14-2006, 01:38 PM
  4. Need input on CS 6 Speed vs Tiptronic
    By smjc_99 in forum 987 Cayman and Boxster Chat
    Last Post: 09-12-2006, 12:28 PM
  5. Best Motoring 911 vs Cayman direct comparison
    By eecsdude in forum 987 Cayman and Boxster Comparisons
    Last Post: 03-30-2006, 12:21 AM
