mobile 1 0w-40 vs 0w-30
Results 1 to 15 of 15
Thread: mobile 1 0w-40 vs 0w-30
    Sep 2006
    Los Angeles, Cali
    806
    what is the diffrence between the two. I am only able to find 0w-30 and i want to know what kind of effect it will have if i use it.
    HP is irrelevant
    May 2006
    MA
    236
    Porsche does not approve 0-30 motor oils. Check it out at Pelican Parts:
    http://forums.pelicanparts.com/showthread.php?t=393996
    May 2006
    MA
    236
    WalMart carries Mobil 1 0-40. Look for the "European Car Formula"
    Sep 2005
    MO
    2,870
    455
    105
    The difference is the hot viscosity (thickness/flow). The 40 means that the oil will not thin out as much as a 30 when its hot. You need the 0 for cold operation to insure good oil supply to the lifters and other tight passages when heavier weight oils won't flow as well. You need the 40 to insure good lubrication when the oil is hot. If it thins too much it may not adequately coat surfaces. The oil also serves an important engine cooling function which may be diminished with too thin an oil.
    Bottom line: Porsche's rec of 0W40 is not random, but results from extensive testing. Don't second guess on your engine's life blood.
    Dan
    National PCA DE Instructor
    2016 Rhodium Silver GT4
    357
    43
    Kragen carries the European Formula Mobil 1 too.
    '07 CS Speed Yellow
    2,214
    Quote Originally Posted by STLPCA View Post
    Just on the side,......when I went to hunt down the oil for my first oil change I couldn't remember what the exact spec it was. I knew it was a 0w-something, but couldn't remember the second number. So I looked it up in a few parts counter books and they all listed two specs.....the 0w-40 and 5w-40 I believe. The 0w-40 is specified for temps that fall below -13 degree F, where the 5w-40 is listed for everything above those extreme cold temps. As STLPCA states, the second number (40) is the most important number here. So if you live in a warm climate, the 5w-40 will be fine (and seems to be a bit more common), but if your in a colder northern climate the 0w-40 is for you. I live in the south and still went with the 0w-40 as I found it quite easily.
    May 2006
    MO
    304
    Re: mobile 1 0w-40 vs 0w-30
    I am about to change my oil and wanted to look into Mobile 1 Racing Oil. Looking on the Mobil 1 site I discovered that Mobile 1 0W-30 is different from 0WS-40 in more than just the viscosity (see link below). In fact, 0W-40 has more zinc and phosphorus than 0W-30. 0W-40 is about halfway between 0W-30 and Mobil 1 Racing Oil in zinc and phosphorus. The values for 0W-30 is the same for all "low-performance" vehicles, and the numbers go up for performance vehicles, so I would go with 0W-40 for sure. What does anyone know about Mobil 1 Racing Oil on the track? Does it offer more protection under the oil starvation conditions we can run into under severe (and rare) g-loads on the track?
    http://www.mobil.com/USA-English/Mot...duct_Guide.pdf
    Charles (arcticsilver)
    MotorSport VOS, Mantis sump extension, Quaife TBD, GT3 lower arms, PSS9s, Tarett sways, SRP, Capristo, Hayden OC-1676 power steering cooler.
    Apr 2006
    Puerto Rico
    1,620
    39
    83
    Articsilver you touched one very important point the antiwear additives are different for Mobil 1 0W-40. I have been told to stick to that weight if using Mobil 1. For others I have been told to look for the european formula and like Atlas_Croc says you can use 5W-40. Mike at TPCicon uses Red line 5W-40 because of the additive package.
    Having fun in Puerto Rico
    Oregon
    1,847
    Quote Originally Posted by roadmaster View Post
    I found out the hard way that not all Walmarts carry 0W-40, of any brand. My wife's Boxster decided it needed a quart of oil in central Oregon, and the only store nearby, a Walmart, did not carry any 0W-40. I bought a quart of M1 5W-30 instead, which won't do any harm. I had thought about sticking an extra quart in the trunk before we left, but forgot. I won't next time.
    May 2006
    MO
    304
    I just found a GREAT deal on 0W-40 Mobil 1 at Advance Auto. $26 for 5 quarts and they include a free Mobil 1 oil filter! While Mobil 1 does not have a filter for my Cayman, I got a free one for my Jeep Wrangler and my Yukon with the 10 quarts I just bought. Get it at this price while you can!
    Feb 2007
    Alberta
    4,167
    242
    342
    Thank heaven. I was starting to suffer from oil thread withdrawal!
    2014 Accord Sport
    1980 Honda CBX - 3
    1990 944 Turbo
    GT4 - on waiting list
    Jan 2006
    2,533
    33
    Quote Originally Posted by arcticsilver View Post
    Race oils have different additives and different properties than non-race oils. For instance, better sheer strength, but less able to deal with the contaminants from daily driving. As a result, race oils are usually not recommended for use in street cars.
    You may wish to consult with Porsche service and/or the oil manufacturer.
    - 2006 Cayman S
    - 2003 Dakota SXT
    LL
    Alameda CA
    168
    Quote Originally Posted by gtscayman View Post
    Lol, you must be a quart low.
    Feb 2007
    Alberta
    4,167
    242
    342
    Quote Originally Posted by Cayman Cabriolet View Post
    And usually people only call me a brick shy!
    2014 Accord Sport
    1980 Honda CBX - 3
    1990 944 Turbo
    Dec 2006
    207
    Please read....from the f-car chat...
    Motor Oil - All Chapters, Inclusive -Copy and Save This - FerrariChat.com
    I have been using 0w-30 all the time on all my cars. It seems to be quieter.
    06 cayman s
    pasm
    sports chrono
    remus catback
    de-snork
    997 GT3 82 mm TB
    IPD Competition plenum
    EVOMSit Flash for RS350
    02 CLK55 H&R Springs / KONIs
    03 EVO8 V390
    07 X5 3.0
  18. Remove Advertisements
  1. 55K Oil Change - Lubro Molly 5W-40 instead of 0W-40 in FL ok?
    By iqwertyi in forum 987 Cayman and Boxster Service and Tech
    Last Post: 02-18-2013, 09:15 AM
  2. Free mobil 1 oil bag and quart of 0w-40
    By JKman in forum Automotive Off Topic
    Last Post: 03-03-2010, 07:26 AM
  3. Tire fitment question: 265/40 vs. 275/35/18
    By Mike_in OH in forum Porsche Tires & Wheels
    Last Post: 05-13-2008, 01:35 PM
  4. Car care tips & Mobil 0-40 oil
    By old dude in forum Porsche Care and Detailing
    Last Post: 03-15-2007, 11:09 AM
  5. 255/40 vs. 265/40 rear winter tires
    By K-Man-sculpture.net in forum Porsche Tires & Wheels
    Last Post: 12-08-2006, 06:08 AM
