IMS failures--is the Cayman/Boxster 987 exempt?
Results 1 to 20 of 22
Thread: IMS failures--is the Cayman/Boxster 987 exempt?
    Aug 2006
    1,341
    190
    There's been quite a bit of chatter recently on Pete's Boxster board regarding failures of the Intermediate Shafticon assembly (bearing/bolt failure) which usually takes the engine out when it fails. More often than not, the 2000-2004 models cars are mentioned, both the 2.7l and 3.2l models are affected.
    Does anyone one know if the this assembly was redesigned when the 987 model was released?
    34,078
    1627
    3078
    5369
    273
    There is a larger bolt used in the Intermediate Shafticon that Porsche believes prevents or helps to prevent an IMS failure. When my engine was apart I inquired and was told mine already had the beefier bolt. Since mine was 2006 I assumed all after were fine, but actually was told that some later cars still have the problem because they phased in the beefier bolt over time.
    Jul 2006
    CT
    350
    All engines and Reman's since late 2005 or MY 2006 have been getting the newer style 3.8 IS bearing and cover. This is the larger nut that you would find. This though is all being replaced or should I say eliminated in the new 987 DFI Boxster and Cayman variant in Jan 2009 that the states will see in a March release. No more Intermediate Shafticon and a design that I would have liked 10 years ago.
    Best,
    Scott Slauson
    Aug 2006
    1,341
    190
    Thanks for the replies
    Scott--good to see you on the board. My '06' 987 is a October 2005 build. Is it fair to say that it should have the beefier bolt?
    K -Man: the comment your dealer made about the phasing in of the fix seems mind boggling; if Porsche knew they had a problem with this part, why wouldn't they just replace the component altogether? I'm sure they don't like junking parts but if the design isn't what it needs to be, they risk a $10K warranty charge if it happens in the first 4 years.
    34,078
    1627
    3078
    5369
    273
    Quote Originally Posted by Mike_in OH View Post
    I think they meant by phasing in just what PCA-TECH said that if a motor came in for remanufacturing that had the problem it went out with the new bigger nut/bolt combo to try and stop the problem. On the assembly line there were probably motors that slipped out that didn't have the fix yet if they had a surplus of motors left over from the year before, in other words Porsche didn't tear down their whole inventory of motors and implement the fix, they simply started fixing new motors and some point and the rest of the "old" motors (even though brand new) still continued to go into cars.
    Jan 2006
    CT
    726
    IMS failures - early '06 model
    These comments concern me. I just read an article on truth about cars about M96 IMSicon failures. My 2006 was an earlier '06. I believe #621 from VIN. Any way to check by engine serial number? My warranty is done in 1.3 years. Your helpful suggestions appreciated.
    http://www.thetruthaboutcars.com/wil...gine-failures/
    Oct 2008
    Oxfordshire
    81
    Re: IMS failures - early '06 model
    We have been rebuilding Porsche engines in the UK with IMS failures for some time now.
    Here's some info that may prove useful to you:
    Autofarm Intermediate Shaft Tech
    In our experience, since the upgraded M97 (997, 987, 987C) engine replaced the M96 (996, 986) there has been minimal issues with IMS failures.
    This may also be due to the fact that the majority of these cars are still within the dealer network under warranty, but we have heard no problems on the grapevine.
    Oct 2008
    Oxfordshire
    81
    [QUOTE=zedd06;309467] My 2006 was an earlier '06. I believe #621 from VIN. Any way to check by engine serial number? My warranty is done in 1.3 years. Your helpful suggestions appreciated. QUOTE]
    All caymans have an engine no. starting M97 (M97/21 for an S and M97/20 for a 2.7). The majority of failures concern engines starting M96.
    The Cayman is a much more reliable motor.
    2 years later, is it a fairly safe to buy a used 2005 987S? I'd hate to have to deal with an engine going kablooey down the line...
    trenton nj
    582
    [QUOTE=Autofarm;314325]
    Quote Originally Posted by zedd06 View Post
    iirc there is an after market bearing kit maker that stopped selling/sending based on VIN ...they want bearing in hand
    Jan 2010
    Colorado
    77
    Re: IMS failures--is the Cayman/Boxster 987 exempt?
    Just to be clear, do all MY06-MY08 Caymans have the beefier IMSicon parts or do some of the early MY06 cars still use the older parts?
    Jan 2006
    CT
    726
    Quote Originally Posted by Point2Point View Post
    Be careful. I bought a very early build 2006 new in May '06. It was built in July 2005.
    I was told by my mechanic that I have a M96 motor with a small bolt.
    Oh well, I will change oil often per recommendation of mechanic and enjoy the car! If it blows then good excuse to invest in an engine swap.
    My german athletes (gone but not forgotten) included ...
    '76 912E (blue)
    '00 Jetta (black)
    My hot rods included ....
    '71 Vette convertible (white w/ bent frame)
    '67 Galaxy 500 hot rod (powder blue)
    '67 Mustang hot rod (black)
    My most loved late daily driver ....
    '99 Subaru wagen (9/15/2003 - 5/27/2010 w/ 218K miles)
    Jun 2010
    Fl
    196
    Coincidentally, I was at my dealership last week and their mechanic was in the process of rebuilding the engine of a 07 Boxster because of a IMSicon failure. He said it was his first of this series. He also stated that the sound was a bit different than the earlier models. Instead of a rattling sound as the notice of impending failure; the IMS in the 07 Boxster made a sound that at first they thought it was coming from the belts. I guess you can say more of a high pitch whirling noise.
    From what I have read it would pay to run your car more often. The garage queens are prone to failure. Move up a click to 5-40 oil (regardless of what Porsche states). Change out the oil every 6 months (regardless what Porsche states). Get your RPM's above 3500 more frequently (no problem here). Track cars have less of a problem.
    The location of the IMS puts it in an area that if there is water in the case, it gets it first. Hence, the more frequent oil changes. I would also get away from the Mobil 1 stuff but that is another story.
    Jan 2006
    CT
    726
    Quote Originally Posted by Zip View Post
    interesting advice. my mechanic recommended oil chnages every 6 months. unfortunately my car is a garage queen at 15500 after ~5 years.
    '76 912E (blue)
    '00 Jetta (black)
    Jan 2010
    I got you beat, my garage Queen, 2006 Boxster S (3.2L engine) , purchased new in Fall of 2005, has 10,000 miles on it. Not purely because of "worship", but I've always had extra cars, and I work in a bad neighborhood.
    BC
    4,167
    930
    1013
    Although not my car, I was at the dealership the other day and they have a 2008 Boxster S with 113 KM on it, for those fluent in miles, 70!
    2016 BGTS delivered Sept 8th! Previous rides:
    2013 Boxster 981-S
    2006 Boxster Base
    Oct 2015
    Ontario
    66
    Just bought a garage queen!
    2006 Cayman S
    19,738 KM's=12,264 miles
    Car has only ever seen the sun!
    Porsche mech did first minor service and said I bought a new car! Very happy with it!
    Cheers
    B
    Mar 2014
    AZ
    895
    186
    Congrats!
    Post a pic or 6.
    Eddie
    Quote Originally Posted by KMS Racing View Post
    2006 Cayman S
    Cheers
    B
    Oct 2015
    Ontario
    66
    Here she is!
    Oct 2015
    OR
    745
    313
    285
    Looks great, congrats!
    May I ask what kind of booster seat that is, and about how much your child weighs? Thanks!
  1. How well built is the Cayman?
    By MotoFanatic in forum 987 Cayman and Boxster Chat
    Last Post: 11-11-2006, 05:19 PM
  2. AWE Tuning Cayman/Boxster 987 exhaust now shipping
    By Mike/A.W.E. in forum 987 Cayman and Boxster Modifications
    Last Post: 10-10-2006, 06:19 AM
  3. OMG is it me or is the Cayman Club site slooooow?
    By TCinOC in forum Website Info and Feedback
    Last Post: 09-08-2006, 09:09 PM
  4. Is the Cayman shell Laser weilded?
    By Mega in forum 987 Cayman and Boxster Chat
    Last Post: 07-07-2006, 04:14 PM
  5. What really is the Cayman Short Shifter???
    By daedton in forum 987 Cayman and Boxster Chat
    Last Post: 11-14-2005, 05:04 PM
