Camshaft actuator solenoid???
Results 1 to 20 of 28
Thread: Camshaft actuator solenoid???
    Jul 2008
    241
    46
    My CS is about 6 months old with ~2500 miles on him. Last weekend after driving at highway speed for around an hour I exited and immediately got a CEL and the car was idling very rough. I parked the car a few minutes later and went to work for the night. When I went back to my car around 10 hours later it started right up and felt fine but the CEL was still on. I drove home with the light on but everything seemed fine.
    On Monday I called the dealer and had them look at it on Thursday. Today I got it back and the dealer apparently replaced the camshaft solenoid valve and all of the parts surrounding it (part number 996 105 303 05--item #39 on illustration 103.00 in PET).
    Can someone explain what this part does? Thanks so much.
    Brett
    May 2008
    New York
    45
    Re: Camshaft actuator solenoid???
    Brett, There are two different types of cam solenoids on your engine. One controls valve lift and one controls valve timing. There is one of each for each bank. They are controlled by the DME computer and will operate at different conditions, cold start, mid range rpm and high rpm. The main purpose is to add more power and torque at mid range to higher rpm and then go back to normal operation when at idle. One solenoid will change the intake lobe on the cam from base lift to high lift to allow more fuel and air to enter the cylinder while the other solenoid will change the cam timing of the intake camshaft, to cause it to go into "overlap" (intake and exhaust valves are open at the same time) for higher rpm power and torque increase. The cam timing solenoid is the one that I have seen malfunction occasionally. If it sticks in the operating position it will cause the engine to idle like a 60's muscle car with a large cam. Terrible for emissions and idle quality. Not very common but does happen. Hope this answers your question.
    Thom
    Jul 2008
    241
    46
    Thanks very much for the very well explained answer to my question.
    So, if I understand correctly, what must have happened was that the solenoid stuck in the high speed condition after I had slowed down to the threshold where it should have switched back. And yes, a 60's muscle car was my exact thought when I stopped at the traffic light. It's really funny that you mentioned that.
    Is it common in modern engines to control things like this with solenoid valves? My experience with them in the medical equipment industry was that they had a tendency to fail if the state of the sensor controlling them was right at the threshold where they should switch for an extended time. They would chatter open and closed very fast and then the coils would fry. I would imagine the point where they switch to the faster mode is much higher than the point when switch back to slow mode--similar to the reaar wing control. Is that how they keep solenoids from frying?
    Brett
    May 2008
    New York
    45
    The solenoids used in this application is more of a oil flow control valve. When energized they allow oil to flow and that is what actually lets the components operate. So being that these are after the oil filter any little bit of dirt or metal debris can cause the solenoid to not allow oil to flow. In the operating position the oil is under pressure so there is usually not a problem, but when the solenoid is returning to rest position, it is trying to allow oil to return and this is where the slightest bit of dirt can cause a problem. Many manufactures are using these systems on their engines and automatic transmission as does Porsche.
    Oct 2006
    Fairfield, CT
    91
    Post Re: Camshaft actuator solenoid???
    I double checked the part number and it is indeed the cam phase solenoid. Luft911 is absolutely correct in his description of the operation of these solenoids. The solenoid is used as an oil control valve, the engine oil is used as a hydraulic fluid, the amount of oil passing through the solenoid detmerines the cam angle relative to the crank angle. (which is why thin Mobil 1 0w-40 is specificied and why it is important to keep the engine oil clean and relatively fresh.
    You can see several of the items in this picture of a late 986 2.7 cylinder head. On the right of the picture are the intake and exhaust cams. If you look at the chain sprocket on the intake cam you will see it is much larger. The phasing mechanism is housed inside. On the left upper section of the picture you can make out the electrical plug for the phase solenoid valve. On the lower left you can see the hole in the valve cover where the valve passes through the cover. This engine does not have variable lift.
    www.FairfieldCountyMotorsport.com
    190 Carter Henry Drive
    Fairfield, CT 06824
    203-256-9291
    Oct 2006
    Connecticut
    7,322
    720
    172
    Bwass24,
    That's a weird one. I've never seen this failure discussed on the club, which leads me to believe that you just had a bad part. Glad it was an easy fix.
    Oct 2006
    Fairfield, CT
    91
    Photos Re: Camshaft actuator solenoid???
    I think as time goes on we will see more of these. The parts have been in service in 996/997 cars for a while now. The failure is rare but we have done a few.
    We had one even stranger issue with a 996 Turbo where the oil control ring inside the cam phase adjuster on the nose of the cam had broken apart causing the cam to phase incorrectly. In the picture you can see a gloved finger pointing to the groove in the cam where the ring is supposed to be. The ring is sitting below the cam in 3 pieces. The part is a little different on the 996TT engine but it works the same way. I don't expect to see this failure again.
    In the other pictures you can see the intake valve lifters have two parts, one for the low lift (middle) and the other for the high lift (outer). You can also see the multi-lobe nature of the intake cam.
    Fairfield, CT 06824
    203-256-9291
    Oct 2006
    Connecticut
    7,322
    720
    172
    Hmmm....... I couldn't help but notice that only the intake cam has two lobes. Is this also the case in the M97 engines? Or is this just a Turbo attribute?
    Also... Wow.... Look a the difference between the mild and aggressive lobes. The mild lobes look round....
    Oct 2006
    Fairfield, CT
    91
    The variable lift is only on the intake cam in all cases. This makes sense since the intake cam is the one that lets the engine suck in air and therefore determines to a significant degree the engine power. (BMW uses a similar arrangement with their throttle less fully variable lift valvetronic system, which is also only on the intake cam) The low lift lobe is indeed very very small. When working with the standalone engine control in the 986 race car with the 987 3.4S transplant we were only able to make 80 rear wheel horsepower with the low lift cam. With the high lift cam and very conservative tuning Tony@EPL and I were able to reach close to 300 rear wheel horsepower on street fuel!
    Fairfield, CT 06824
    203-256-9291
    Oct 2006
    Connecticut
    7,322
    720
    172
    Quote Originally Posted by Drew@FCMotorsport View Post
    Wow... Only 80 HP on the mild cams....
    A very interesting project to say the least, and one that is likely to be a real learning experience. When you guys complete that car, you'll have to give us a full blow by blow.
    Jul 2008
    241
    46
    Thanks all...very interesting.
    I wasn't aware that they used the engine oil as hydraulic fluid but it makes sense now. So, if the solenoid sticks in the aggressive position the car stays in the aggressive timing mode which is why it was idling like a muscle car. I guess, by extension, if the solenoid stuck in the mild position, or if oil flow was restricted by a clogged oil screen at the valve, you might have trouble accelerating and would reach a plateau very quickly?
    Brett
    Oct 2006
    Fairfield, CT
    91
    bwass24,
    Yes that description is reasonably accurate.
    GatorBite,
    As soon as the car is complete I am planning to post pics of the car, dynos, and a blow by blow of the transplant process.
    Fairfield, CT 06824
    203-256-9291
    new jersey
    358
    Drew,
    Thanks for the very informative photos and explanations.
    Jul 2006
    CT
    350
    These solenoid valves have been known to malfunction . They can either fail in that the internal winding shorts or the spring breaks. These are the two most common in use.
    For a new car they often get stuck from an internal metal shaving that was still in the engine. This shaving lodges in the passageway of the oil side. The shavings are normal and are from any of the machining processes of the heads or block.
    Best,
    Scott Slauson
    Oct 2006
    Fairfield, CT
    91
    Best,
    Scott Slauson
    bwass24 - As Scott states these are the most likely failure modes. You will not likely experience any further problems. At least not on the same side of the engine.
    Someday - You're welcome. I'm glad I could help clarify the problem. I need to get a new photo editor and then I'll be able to put labels on the pics.
    Fairfield, CT 06824
    203-256-9291
    Jul 2006
    CT
    350
    Drew and Fairfield County Motorsports,
    I would like to say hello and welcome you. I think the photos are great !! I have to many to count yet not the time to post them so keep it up.
    Best Regards,
    Scott Slauson
    Oct 2006
    Fairfield, CT
    91
    Thumbs up Re: Camshaft actuator solenoid???
    Thanks Scott!
    I finally started cataloging all the photos. I'm sure we will have more to post as time goes on.
    Fairfield, CT 06824
    203-256-9291
    1,294
    60
    164
    Bruce:
    Aren't you glad that this club has such experts at its disposal? Thanks to PCA-TECH [Scott,] Drew@FCM, and Luft911 [Thom] (who just happens to be my Cayman's "personal" technician) for their lucid and thorough replies.
    -Dave
    1,294
    60
    164
    Sorry about that, Brett! D-OH!
    Oct 2006
    Connecticut
    7,322
    720
    172
    Quote Originally Posted by Croc'ed View Post
    Bruce:
    -Dave
    No kidding, huh....? That's a lot of Porsche knowledge. And all in our neck of the woods. We're a lucky group.
  1. 30k mi. Cayman S at Dealer with clutch actuation problem...
    By pcormier in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 11-16-2012, 11:05 AM
  2. PSE - Solenoid noisy
    By Rrunkle in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 11-20-2011, 07:29 PM
  3. Caman S Camshaft proble at 19k miles!!!
    By mashraf in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 04-14-2010, 03:47 PM
  4. Replies: 0
    Last Post: 04-13-2010, 08:20 PM
  5. Is the Cayman camshaft tuned too high?
    By Coupe-de-Gras in forum 987 Cayman and Boxster Service and Tech
    Last Post: 04-26-2008, 12:49 AM
