Temp gage blinking light
Results 1 to 4 of 4
Thread: Temp gage blinking light
    Dec 2008
    NC
    136
    This morning we had 17* in Charlotte and right after cranking the car the red light on the temp gage blinked for about 5 minutes and after that it went away. All normal. I guess the cold 17* reduce the amount of coolant enough to register "low coolant level".
    What do you think?
    Oct 2006
    Silver Spring, MD
    1,076
    80
    27
    Re: Temp gage blinking light
    Might be worth checking the level when your car cools off. It's pretty low if a temp drop made the low-coolant warning light up.
    Sep 2005
    New Mexico
    10,001
    Two possibilities. Your coolant is low as BillC suggested or your gauge is faulty. I'd discount the temp theory.
    Dec 2008
    NC
    136
    Amazing.
    I checked the coolant level and it was a tad low... put some in (may be 4oz) and everything went away.
    I believe it was boderline and with the temp drop it was enough to indicate the fault.
    Good deal. Thanks
  7. Remove Advertisements
  1. Temp gage pegged when starting on 17f morning
    By Greg W in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 11-27-2014, 04:10 PM
  2. Blinking Side Marker Lights
    By old dude in forum 987 Cayman and Boxster Electronics
    Last Post: 10-21-2014, 04:11 PM
  3. Blinking Center Brake Light
    By andover in forum 987 Cayman and Boxster Modifications
    Last Post: 10-06-2010, 09:33 AM
  4. water temp flashing light ! !
    By duncan in forum 987 Cayman and Boxster Chat
    Last Post: 06-22-2007, 01:46 PM
  5. Temp Gage failure
    By Donelonpc in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 03-08-2007, 07:43 PM
