'04 Boxster S - Battery Replacement
Results 1 to 4 of 4
Thread: '04 Boxster S - Battery Replacement
    Dec 2009
    BC
    64
    I'm having to replace the battery in my Boxster and know from experience there's a trick to it. If you don't do it right, you'll cause code havoc. Anyone know the trick?
    Alameda CA
    168
    Re: '04 Boxster S - Battery Replacement
    Quote Originally Posted by KerryLange View Post
    I would keep a battery tender plugged in to the cig lighter socket while changing batteries. The radio "safe code" will not be activated. Is this what you are refering to?
    Jun 2008
    Dubai
    3,010
    126
    185
    139
    Gamertag: Gambba
    Not sure on a 04 Boxster but on the Coxster the only issue which comes up is the PSM error. The book says to simply to turn the wheel several times, but I've found it will only clear once you start driving, so go easy to start with.
    If you do not leave the battery off for hours or days then there should be no problem at all, and only the PSM warning so come up and clear afterwards.
    Dec 2009
    BC
    64
    Thanks for the replies!
    I got it to work. I found some instructions that pointed out that radio codes apply only to 94 through '02 Boxsters. Swapped the battery out and all is well.
    The part I wasn't sure about was the positive connection to the battery through the fuse box. I wasn't sure how to do that until I found some instructions that explained how the positive connection is made through the red "button" with the open hood marked on it. You pull it out to provide a connection to the battery and ground the negative to the door latch.
    So, no code problems and I've got my new battery in.
  7. Remove Advertisements
  1. Battery replacement
    By rxsevn89 in forum 987 Cayman and Boxster Chat
    Last Post: 10-29-2016, 08:49 PM
  2. Optima battery replacement option for Cayman
    By jsdone in forum 987 Cayman and Boxster Electronics
    Last Post: 02-28-2012, 05:30 PM
  3. 986 Boxster roof transmaission replacement
    By tuizner in forum 987 Cayman and Boxster Service and Tech
    Last Post: 07-02-2010, 05:48 AM
  4. Battery Replacement Check Engine Light
    By Speedychevy in forum 987 Cayman and Boxster Chat
    Last Post: 12-08-2009, 05:44 PM
  5. Optima battery replacement
    By Caydoc in forum 987 Cayman and Boxster Service and Tech
    Last Post: 03-01-2007, 05:33 PM
