Results 1 to 20 of 32
Like Tree4Likes
Thread: Open trunk without keys?
    mkiv808's Avatar
    mkiv808 is offline Porsche Specialist 500 post club
    Jun 2008
    CT
    596
    I can't find my only set of keys for my Cayman.
    I have a sneaking suspicion I locked them in the trunk.
    The windows are open, but the doors are locked. Is there any way to open the trunk in this scenario?
    2009 BMW M3
    2001 Jeep Wrangler
    mitch48's Avatar
    mitch48 is offline Insider
    Sep 2009
    AL
    289
    Re: Open trunk without keys?
    Can't you reach in the driver's side window and pop the trunk? I do that all the time, the trunk and 'frunk' releases are accessible with the door closed.
    mkiv808's Avatar
    Jun 2008
    CT
    596
    Quote Originally Posted by mitch48 View Post
    I tried and nothing happened. Is it disabled when the car is locked? Maybe I need to hold it longer.
    2009 BMW M3
    2001 Jeep Wrangler
    K-Man S's Avatar
    31,478
    4656
    264
    121
    Quote Originally Posted by mkiv808 View Post
    Might be one of those items that powers down when the car goes into sleep mode, if you wake up the car by lifting the door handle, etc. then maybe the switch inside will work. In an emergency you can always pull the front trunk release cable in the front wheel well to mechanically release/open the front trunk.
    RSchwerer's Avatar
    RSchwerer is offline Site Upgrade Donor
    Jan 2010
    1,980
    54
    So, the door is locked? Since the window is open, can't you reach in and unlock it using the handle? Since your key is supposed to be in the trunk, you could not of locked the door with the remote - or key. So how could this happen?
    I think the only time the car auto-locks is when you open either trunk via remote, and never open a passenger door. After about 5 minutes (est) it will re-lock itself and presumably re-arm the alarm.
    So, by opening the door manually, you may set-off the alarm. Just be quick about finding your key. Also, wouldn't hurt to have a 10mm wrench handy in case you need to disconnect the battery to stop the alarm (in case the key isn't there after-all).
    One more thing. Are you sure your battery isn't dead?
    Belleair Beach, Florida - 2010 Cayman
    mkiv808's Avatar
    Jun 2008
    CT
    596
    Battery is definitely good.
    I'm thinking I locked the car with the remote, went back to the car, used the remote to open the trunk, and then left the keys in there. Is that possible?
    I tried holding the trunk release longer. Nothing. Security feature?
    I'll try opening the door from the inside. The alarm will certainly go off, but we'll see if I can open the trunk from there.
    2009 BMW M3
    2001 Jeep Wrangler
    Justinfranke78's Avatar
    Justinfranke78 is offline Porsche Specialist
    Dec 2011
    539
    Sorry not meaning to be a jerk but this just blew my mind.
    Your windows are open?
    Step one - find small child
    Step two - throw child through window
    Step three - tell child to get keys from trunk
    Step four - pay child with ice cream or dollar bills
    Step five - drive it like you stole it!
    Artrem's Avatar
    Artrem is offline Insider
    Mar 2011
    Maryland-DC metro USA
    228
    Quote Originally Posted by Justinfranke78 View Post
    ... maybe he is referring to the frunk? In which case, maybe the spare battery trick is in order, although I can't imagine why it won't open with the switch.
    mkiv808's Avatar
    Jun 2008
    CT
    596
    Neither will open with the switch. Opened car from inside and alarm just sounds.
    I'm going to have to climb back there with a flashlight.
    I guess the burning question is: am I wasting my time on this hunch? When you open the trunk with the remote when the car is locked, does the car stay locked?
    2009 BMW M3
    2001 Jeep Wrangler
    Owen Birch's Avatar
    Owen Birch is offline Porsche Activist
    Mar 2009
    494
    i believe if you use the remote to open the trunk and then close the trunk, the doors will re-lock after 30 seconds or so.... Good luck, hope you find them
    RSchwerer's Avatar
    Jan 2010
    1,980
    54
    On a Gen 2 (at least), if the car was already locked and you use the remote to open either trunk, the doors unlock too. However, if you don't open a door after a period of time, the doors re-lock. That is probably what happened to you. Still doesn't say where you left your key. Did you open the front or rear trunk?
    K-Man S's Avatar
    31,478
    4656
    264
    121
    why or why do people not have their SECOND key handy? In the house somewhere, etc.?
    Yes if car is locked and you open trunk the doors unlock as well but will relock if the doors were not physically opened.
    As mentioned earlier you can always pull the physical release cable inside the front wheel well to open the trunk.
    mkiv808's Avatar
    Jun 2008
    CT
    596
    Car bought used and only came with one key. My bad for never ordering a 2nd. Maybe if they were cheaper I would have.
    2009 BMW M3
    2001 Jeep Wrangler
    mkiv808's Avatar
    Jun 2008
    CT
    596
    Quote Originally Posted by RSchwerer View Post
    It's Gen 1, I wonder if it's the same.
    My car does not autolock if you simply leave it unlocked after a drive.
    2009 BMW M3
    2001 Jeep Wrangler
    K-Man S's Avatar
    31,478
    4656
    264
    121
    That's not what he's saying about auto-relock. That only happens if you have locked the car, then with the keyfob pressed the trunk unlock button, opened the trunk, say tossed some keys in there, then closed the trunk and walk away. The car doors which unlocked when you pressed the keyfob to unlock the trunk will auto-relock because your doors were never opened.
    doors don't lock themselves otherwise... unless set to lock upon driving 5mph but that's not the case here...
    Sorry to hear you only got one key when you got the car, I'd make the SELLER pay for the 2nd key, you should have it.
    lithium1330's Avatar
    lithium1330 is offline PCA Member
    Jul 2009
    SF Bay Area (was: S. Florida)
    1,059
    I'll let others finish debating the autolock If your key is in the front trunk, you'll need to remove the driver side wheel liner and look for the wire cable to unlatch the front trunk. Check the picture half page down on this URL: Worst Case Scenario
    BTW, while you're at it, you should take a picture and post it.. so others can learn from this and know what to look for.
    Chris
    2008 Boxster S : Speed Yellow : FVD tuned : Fabspeed headers & race cats : Remus race exhaust : Eibach springs : 19" Champion RG5 : Laser Interceptor + V1 : PFC 08/06 for DE
    Tracks : Mt Tremblant : Sebring : Lime Rock Park : Watkins Glen : Thunderhill-West : Homestead Miami : PBIR
    Backroads : Carmel Valley Rd (G16): Blue Ridge Parkway : Diamondback (226A) : Tail of the Dragon
  17. #17
    LokiV7's Avatar
    LokiV7 is offline Porsche Chatter
    Jan 2012
    IL
    34
    Quote Originally Posted by lithium1330 View Post
    It still sounds like this is the rear-hatch lid that's locked, not the front trunk (frunk). Did you have that cloth privacy shield in place? (is it blocking you from getting back there?) With everything closed, for some reason I thought there wasn't much (if any) clearance between the glass of the hatch and the rear-portion of the engine-cover .. not even sure you'll be able to crawl back there.
  18. #18
    Owen Birch's Avatar
    Mar 2009
    494
    I tried that cable this weekend for test (never used before), and it quickly and easily stretched and broke (without opening the frunk)....
    It's plastic. I trust this is not an easy replacement?
  19. #19
    pnug's Avatar
    pnug is offline Site Donor
    Jun 2007
    275
    118
    You actually have a 3rd key, wallet/valet key. The dealers don't really talk about them when you buy the car and it's in the glove box with all the other documentation that come with a new car. I've heard that new car get broken into with the thought it might still be there and the thief can use it to drive away in the car. So, might be worth a shot to look to see if it's there, thin black flat thing that of course probably won't unlock the storage areas.
    Secondly why would you buy a car that might have a keys somewhere out there. It would be like buying a house and not changing the locks before you move in?
  20. #20
    scottschoe's Avatar
    scottschoe is offline Porsche Idealist
    Sep 2009
    Bay Area, CA
    983
    I don't know if the Cayman is set up differently than a general car, but just ask any tow truck driver standing around and he'll open your door in about 30 seconds with a wedge tool and some other stuff. Give him a few bucks for the trouble. Or maybe I didn't read the details of the situation that closely...
  1. Keys do not unlock / open trunk sometimes
    By black_box in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 12-05-2013, 05:53 PM
  2. Key Fob and trunks opening
    By bmaupin in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 03-15-2008, 12:44 PM
  3. Boxster solution to open trunk/Cayman?
    By Santa Fe in forum 987 Cayman and Boxster Modifications
    Last Post: 11-03-2007, 12:39 PM
  4. key opens trunk and hood all the time!!! :(
    By SIcayman in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 10-09-2007, 03:11 PM
  5. Fix for the key opening the trunk by mistake
    By barrydevlin in forum 987 Cayman and Boxster Chat
    Last Post: 03-30-2006, 11:55 PM
