Page 1 of 7 123 ... LastLast
Results 1 to 20 of 130
Like Tree4Likes
Thread: CDR-24 w/Bose to Kenwood DNX6960 self install
    c-rizzle's Avatar
    c-rizzle is offline Porsche Orator 1,000 post club
    Louisiana
    1,606
    So the crappy CDR-24 had to go. I actually really liked the sound quality of the BOSE system, but I needed MP3 support, I just couldn't deal with only 20+- songs per disc!! Also, why not get Navigation, Bluetooth (a must for manual transmissions), and backup camera while at it!!
    ______________ BEFORE____________________________________________ _______ AFTER
    I picked out my parts:
    Kenwood DNX6960 - wanted a volume knob & disc slot - $800
    JL Audio G6600 - needed 6+ channels for all the speakers - $300 - newer model recommendation: JL Audio XD600/6
    Boyo back up camera - might as well for - $130
    double-din + Bose adapter kit - ebay - $275
    RCA wires, speaker wire, etc. - $50+
    Total approx: $1600
    This was a priceless resource: http://www.planet-9.com/cayman-boxster-electronics/28892-recent-dvd-navigation-install-avic-d3.html definitely print these instructions out, if you're going to install a radio yourself
    These 2 threads helped me run the back up camera: 500i, ZR3) tips:Back-up cam, power - Articles (scroll down to the license plate portion)
    AND http://www.planet-9.com/cayman-boxst...tml#post456049
    You should run the back up camera wire and the illumination & reverse wires all together! This I think should be your first step as it was one of the biggest pains in the butt getting the wires snaked around the motor area and keeping them clear of things all the way up to the front of the car. You could avoid the camera wire & reverse wire, if you don't install a back up camera. And you can also skip the illumination wire, b/c the Kenwood can auto-adjust the brightness based on the time of day/GPS time from the Garmin.
    When you're removing the interior door sill cover that supposedly just "snaps off" according to some guides. You should loosen the 2 allen head bolts. Look between the seat and the interior door sill cover, you will see 2 black plugs, pull them out and this will give you access to stick an allen wrench in, you'll have to test fit a few sizes since you can't really see in there well. I didn't know this tidbit and cracked a small piece b/c one of the bolts was really tight.
    If you buy the kit with the BOSE amp adapter, you will need to solder and heatshrink wires on to it like this:
    this is at the half way point, bottom row soldered & top row still bent up
    I did this in advance and labelled all the wires, then connected them to my amp. So when it came time to swap, all I had to do was drop in the new amp, unplug old plugs, plug in my giant bose adapter, then connect the remote wire, which I had run separately, and plug in the RCA cables. Do not use the ground from the BOSE harness for your amp's ground, it will give you terrible whine.
    The speaker channels were run as:
    Front L&R: dash & door highs
    Rear L&R: rear pillar speakers
    Subwoofer L: both door subs run in series, b/c each speaker is only 1 Ohm
    subwoofer R: passenger footwell sub - wire run directly from amp through firewalls, etc to speaker. Had to disconnect & remove small amp on the box, then wire to both pairs of wires for the sub. (dual voice coil?) Take the speaker off & be sure to match the wires correctly. I used the "battery test" to determine which was positive/negative.
    Next I ran the wires needed from the front trunk, which were:
    3 pairs of RCA cables (front, rear & subs)
    1 remote turn on wire
    1 speaker wire to passenger footwell
    1 ground wire for radio (extra)
    1 satellite antenna & wire
    I ran the RCA, remote & speaker wire up the passenger side of the trunk compartment, I had to remove a large plastic angle mounting bracket to access the large rubber grommet, then passed the wire across toward the windshield to where I had mounted the satelite antenna, then ran all of the wires underneath the wiperblade area across to the drivers side and then down & in to the drivers side grommet. You should also run an extra ground while running these.
    Nearly everything else is covered in the first link above by Truellionaire.
    installed w/ custom background:
    And here's the custom background that I made:
    Amp in trunk:
    SPEAKER SIZES: - compiled from other sources, I didn't measure or replace mine.
    Dashboard - 2 X 25mm neodym tweeters (or 19mm)
    Center - 1 X 70mm neodym mid range loudspeaker
    Door - 2 X 80mm (or 100mm) neodym loudspeakers, 2 X200mm Nd low range loudspeakers
    Rear Sides - 2 X80mm neodym (or 100mm) mid-range loudspeakers
    Subwoofer in footwell, one 102 X 153mm low range loudspeaker
    mouseyw and nicoli like this.
    c-rizzle's Avatar
    Louisiana
    1,606
    Porsche Logo Re: CDR-24 w/Bose to Kenwood DNX6960 self install
    Also, I had to dig around to find out how to change the BOOT SCREEN:
    While HU is on, hold down eject + SRC, then hit the reset button (this causes a reboot).. continue holding the eject+SRC down during this reboot, until a screen pops up saying "Kenwood" or "OEM" once this is displayed you can release it.
    Select OEM, select your USB drive, navigate to the file, select it, hit enter. (takes a while to load to memory)
    Then hit SRC to power down. I think I had to hit eject+SRC again for it to stop showing the option to pick other backgrounds.
    Here's the BOOT SCREEN: (used something different for boot, than normal operation)
    Some earlier models require 16-bit bitmap (.bmp) files. I found his out when helping someone with their custom Mercedes logo recently.
    Hi_Fi_Guy's Avatar
    Hi_Fi_Guy is offline Porsche Activist
    Sep 2009
    AZ
    350
    Thank you for sharing... I have to do this!
    c-rizzle's Avatar
    Louisiana
    1,606
    Various samples I made up. The blue looked best, especially with the blue/black button theme that I use. The other 2 themes: red & brushed aluminum for the buttons don't look right in my car.
    xelsbrot likes this.
    Jputt's Avatar
    Jputt is offline Porsche Enthusiast
    Dec 2008
    TX
    156
    Hi_Fi_Guy's Avatar
    Sep 2009
    AZ
    350
    Did you replace the Bose amp out of necessity or would it have worked with the -
    double-din + Bose adapter kit - you purchased?
    mrwonder's Avatar
    mrwonder is offline Porsche Enthusiast
    153
    39
    Very nice! This is very tempting, but the soldering part makes me nervous...
    c-rizzle's Avatar
    Louisiana
    1,606
    HiFi:
    The simple answer is YOU SHOULD REPLACE YOUR BOSE AMPLIFIER in the trunk.
    The small BOSE subwoofer amp inside the car can be used with an aftermarket headunit and line level outputs, however, thats just 1 of your 10 speakers!! However, I removed this amp, and wired the subwoofer to my 6-channel amp.
    The BOSE amplifier connects to the stock headunit via the MOST (optical) link. The MOST-HUR adapter supposedly can eliminate the need for an aftermarket amp, and allow you to use an aftermarket headunit with the rest of your system (amps/speakers) stock. But I believe the best sounding solution would be to go with an aftermarket amp.
    I was hesitant initially, and wanted to keep the BOSE amp as I was happy with the sound before. But I can tell you after doing it, the sound quality is even better now. It did take a little time tweaking the 3 different sound panels in the stereo: crossover level, equalizer levels, etc. (all on the stereo, I did not use the HP/LP filters on the amp at all)
    The highs are crisper, the lows hit harder and crisper too. Overall the sound quality is great.
    The double din adapter is great for fitting your headunit in to the stock Porsche rails and snapping perfectly in to place and filling the extra space with their faceplate adapter.
    However, the speaker portion of the wire harness they provide for the headunit only works if you have a non-bose system. If you have a BOSE system your speaker connections are all in the trunk at the BOSE amp, on that giant connector. Thats the extra $25 BOSE adapter ($275 kit) that you have to solder on if you want to use it. You can obviously just cut the Porsche harness off and hardwire everything if you want, and get the $250 kit. But I wanted it reversible and I liked how it makes my amp easily removeable.
    MrWonder:
    I have no prior experience with a soldering gun. I started out a little slow, but got good by the 2nd row of connectors.
    The double din adapter from ebay comes with a wiring diagram, so you will know what pins are what.
    As for the soldering process:
    -Take the white plastic piece off the pins on the adapter.
    -Then bend the top row of pins up & out of the way. (if you were experience you could probably skip this)
    -prepare all wires (strip them & put a piece of heatshrink on it for later)
    -solder the connections that you need.
    -then slide up the heatshrink and shrink it
    -I soldered the 2 power wires, and the 5 speaker channels. FL, FR, RL, RR, & center. (never hooked up center, but just in case)
    -then I put the white plastic piece back on just the top row, helps separate your rows
    - I cut the extra pins not needed off the 2nd row just to clean things up
    -solder the top row of connectors (2nd half of all the speakers)
    And your adapter is done!
    EDIT: ADDED this from another post I made, concerning questions and using a MOST HUR adapter. In my opion you should not use the adapter and go with an aftermarket amp, however, since there is that option, I'll include this for completeness of information:
    Your options if you have a BOSE system, when changing to an aftermarket headunit:
    1. use the MOST-HUR adapter. This allows the new radio to "talk" to the stock BOSE amp. The stock amp needs a fiberoptic input and presumably turns on & off by whether or not there's a signal.
    2. change BOSE amp in trunk to an aftermarket amp
    3. change BOSE amp in trunk to an aftermarket amp and bypass the subwoofer amp also.
    notes: center channel not pictured and door highs are part of the "dash" speakers
    2 & 3. will require you running RCA (purple wires in diagram) to the aftermarket amp. Also not pictured, but easy to run is a single 12v+ "turn on" (remote) wire. Most installers will probably run a new 12+ power wire to the amp also with a nice heavy gauge wire. I actually used the existing 12v+ rail to supply power to the amp, and use a nut close by for the ground. I've been contemplating running a new power wire since the battery is so close, but truthfully it sounds so good, I've put it off.
    Everyone who has heard my system cannot believe its stock speakers. Including 2 other Cayman owners who have stock BOSE systems.
    Part of making the system sound good is tweaking the crossover levels and input levels on the amp, sound levels, etc.
    3. shows how i have my 2 door woofers run on the same channel to increase the resistance on the amp (left subwoofer channel), then I have the subwoofer in the footwell run to the right subwoofer channel. <--<< RECOMMENDED CONFIGURATION
    robaz38's Avatar
    robaz38 is offline Porsche Enthusiast
    May 2008
    AZ
    223
    Nice job on the install! Looks awesome
    c-rizzle's Avatar
    Louisiana
    1,606
    I hooked up the subwoofer in the passenger footwell directly to my amp (bypassing the BOSE sub amp). I took both pairs of wires and joined them then connected them to the Right sub channel on my amp. (ie: the dual voice coils are run parallel) It sounds fine so I assume everything is kosher.
    But I was researching a little more on dual voice coil wiring here: JL Audio - Car Audio Systems
    And I don't know how many Ohms are on each voice coil, and if I should have run the 2 coils parallel like I did or in a series.
    edit: I just realized my voltometer has an Ohm setting, so next time I'm playing with things I'll test the subwoofer resistance.
    edit 2: I assumed b/c the speaker had 4 wires connected to it that it was dual voice coil, but I've been told its single coil and it just has extra wires. Still never got around to testing the Ohms.
    Sooner_Cayman's Avatar
    Sooner_Cayman is offline Porsche Chatter
    May 2010
    Man the install looks great. Mind sharing how you hooked the door subs in series? Did you have to run separate wire to the speakers, or were you able to do it at the connector in the trunk?
    engnr1's Avatar
    engnr1 is offline Middle-Aged Porsche Punk
    754
    234
    You did a beautiful, complete job, straight down to the OEM-looking cover plate and Cayman boot screen. I should replace my PCM 2.1 with your kit - that is incredible.
    Did you use the stock speakers that come with the Bose system? I had understood their impedence was very low and tied toward the Bose amplifier operation, so my understanding was they would need to have been replaced if you bypassed the Bose amp.
    Your car's color is great too.
    "He who dies with the most toys is, nonetheless, still dead."
    c-rizzle's Avatar
    Louisiana
    1,606
    The faceplate and mounting sides kit, is from Euromotor speed on ebay.
    $250-275.00 (depending on if you want the Bose amp adapter)
    Its not "my kit"!
    Most good amps are capable of handling the 2 Ohn loads fine. All of stock speakers are 2 Ohms, except for the door woofers. Those are only 1 Ohm so you either need to add a resistor (easy) or just put them both in a series on the same channel (even easier). If you read through my other posts you'll see its quite simple. The stock speakers sound good, so I plan on keeping them. Down the road I MAY change them for even higher grade speakers if I can find exact size replacements. If I do that then I'll probably disconnect the sub in the footwell and connect the door woofers to the individual left & right channels instead of both on the same channel.
    I'm gradually getting everything perfect. I've went back & pulled everything out and moved around wires, b/c I knew the wires were all bunched up back there & wanted to clean things up a little. There are a few more little tweaks I want to do to make sure "everything is perfect".
    I'm going to be redoing the way I have the amplifier mounted. I took the foam piece off the old cover and screwed it to the plastic, however everything is a little tight, and I'm concerned the plastic wiggles and isn't held in at the bottom, so I'll post back my "fix" for that later.
    You can see more pics here: Photo Album
    as I refine things.
    The original way I hid the amp using the stock piece of plastic:
    Hi_Fi_Guy's Avatar
    Sep 2009
    AZ
    350
    Thanks for the additional info... I really gotta do this!
    c-rizzle's Avatar
    Louisiana
    1,606
    Another note: originally I used the +12v and -12v power from the existing Bose amp wire harness, that should be ok for the 12v+, however, for the ground you should use a closer contact point.
    Or you may get some whine from a poor ground. I found a bolt under the carpet right next to the trunk light and attached a short 12gauge ground wire, with tinned (soldered dipped) ends!
    gaatr is offline Newbie
    Jun 2010
    C-rizzle - Nice install mate...!! very impressive
    Took advice from multiple forums myself to get around my 997 Bose MOST system - new head unit, AVIC-Z120BT and an alpine PDX-5 amp.
    My Bose is the 11 speaker setup = 3 Dash highs (L + R + Center) - 4 Door speakers (2 Woofers and 2 Mids) - 2 Rear Quarter Speakers (L + R) and Bose Bass Box behind the rear seats (2 x 5.25" Drivers inside bose box w/ small amp)
    Still trying to figure out the best way to configure the speakers to run off the Alpine PDX-5
    Any body know the true impedence of the 5.25" woofers in the BOSE bass box (4th pic) ?? - Anybody had experience hooking these drivers up to an aftermarket amp??
    Pics below
    BTW - This faceplate is from Europe - I love the stock look as this was very important to me PM me for part numbers
    Attached Thumbnails Attached Thumbnails CDR-24 w/Bose to Kenwood DNX6960 self install-img_0432.jpg   CDR-24 w/Bose to Kenwood DNX6960 self install-img_0434.jpg   CDR-24 w/Bose to Kenwood DNX6960 self install-img_0435.jpg   CDR-24 w/Bose to Kenwood DNX6960 self install-img_0425.jpg
    reyesda1 likes this.
  17. #17
    sajacr is offline Porsche Person
    Jun 2010
    PA
    Quote Originally Posted by Hi_Fi_Guy View Post
    Who did you purchase the double-din + Bose adapter kit from? I can only find one that is significantly more than the $275 and it does not have the Porsche lettering.
  18. #18
    c-rizzle's Avatar
    Louisiana
    1,606
    987 double din items - Get great deals on Electronics items on eBay.com!
    $274
    or directly: http://www.euromotorspeed.com/ or 877-408-(EURO) 3876
    The PORSCHE lettering is a little thin sticker that you can put on.... very carefully as its just the letters on a backer sheet!!
  19. #19
    robaz38's Avatar
    May 2008
    AZ
    223
    sajacr,
    you can also order the kit directly from euromotorspeed if you didn't want to go through ebay. That's how i ordered my kit, just ask for Loi and he can answer all your questions you may have.
    Rob
  20. #20
    gmorat is offline Porsche Specialist 500 post club
    Feb 2006
    655
    I would love something like but finding somebody to do the work is difficult, especially when you hear some of the horror stories from shitty installs. Unfortunately I'm just not technically minded enough to do it myself. Anyone know of a good installer in the Raleigh area?
    G
  1. 02-13-2015, 02:43 AM
  2. 02-12-2015, 05:49 AM
  3. 07-29-2014, 11:58 AM
  4. 06-29-2014, 05:23 PM
  5. 06-14-2014, 02:22 AM
  6. 05-16-2014, 06:58 AM
  7. 04-22-2014, 09:18 AM
  8. 05-30-2013, 07:25 AM
  9. 02-03-2013, 02:26 PM
  10. 01-16-2013, 01:14 PM
  11. 12-25-2012, 03:22 PM
  12. 10-10-2012, 08:49 AM
  13. 09-04-2012, 07:08 AM
  14. 05-23-2012, 11:56 AM
  15. 05-20-2012, 02:12 PM
  16. 05-08-2012, 02:28 PM
  17. 04-10-2012, 09:53 AM
  18. 03-23-2012, 01:07 PM
  19. 12-27-2011, 02:49 PM
  20. 11-05-2011, 05:17 PM
  21. 07-24-2011, 01:04 AM
  22. 07-23-2011, 10:49 AM
  23. 07-03-2011, 01:10 PM
  24. 06-16-2011, 09:37 AM
  25. 05-15-2011, 03:14 AM
  26. 03-01-2011, 10:54 AM
  27. 02-14-2011, 03:01 PM
  28. 02-03-2011, 04:42 AM
  29. 02-03-2011, 04:05 AM
  30. 02-02-2011, 05:17 AM
  31. 02-01-2011, 12:17 AM
  32. 01-24-2011, 06:19 PM
  33. 01-19-2011, 03:41 PM
  34. 12-29-2010, 08:13 AM
  35. 12-19-2010, 11:49 AM
  36. 11-21-2010, 01:55 PM
  37. 08-18-2010, 10:06 AM
  38. 08-04-2010, 11:59 PM
  39. 08-04-2010, 04:36 AM
  40. 08-03-2010, 04:58 PM
  41. 08-03-2010, 09:56 AM
  42. 08-03-2010, 08:46 AM
  43. 08-03-2010, 06:42 AM
  44. 08-03-2010, 05:38 AM
  45. 05-11-2010, 09:56 AM
  1. CDR 24 w. Bose options?
    By tagnew in forum 987 Cayman and Boxster Electronics
    Last Post: 09-09-2010, 05:14 AM
  2. CDR-24 w/Sound Package plus to Kenwood DNX9960
    By robaz38 in forum 987 Cayman and Boxster Electronics
    Last Post: 08-31-2010, 10:24 PM
  3. CDR 24 non bose to bose pcm 2.1
    By heatfan5 in forum 987 Cayman and Boxster Electronics
    Last Post: 04-14-2010, 08:32 PM
  4. Will FM wired modulator work with Bose, non PCM cdr-24?
    By metaphor in forum 987 Cayman and Boxster Electronics
    Last Post: 03-18-2007, 11:06 AM
  5. CDR-24 & Bose Manuals
    By davidlee388 in forum 987 Cayman and Boxster Chat
    Last Post: 04-04-2006, 07:24 PM
