Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    lithium1330's Avatar
    lithium1330 is offline PCA Member
    Jul 2009
    SF Bay Area (was: S. Florida)
    1,059
    Please post your ride height
    There are lots of posts about lowering springs, though not much information on the actual drop after install. I feel post-install measurement info would be useful for folks interested in lowering their cars.
    Approx. mileage on springs:
    Brand:
    Front (in.):
    Rear (in.):
    Porsche compensation plates, if any.
    I'll start with my OE setup:
    -2600 miles
    - OEM Springs (non-PASM)
    - Front: 15.0"
    - Rear: 15.5"
    - Comp plate: 3mm (f) & 6mm (r)
    Would folks who have lowered their cars to post the measurement between the highest point of fender and center of wheel/axle? (remember to use some painter tape so you don't scratch the fender ).
    Last edited by lithium1330; 11-08-2009 at 07:22 PM. Reason: added comp plates front & rear
    Chris
    2008 Boxster S : Speed Yellow : FVD tuned : Fabspeed headers & race cats : Remus race exhaust : Eibach springs : 19" Champion RG5 : Laser Interceptor + V1 : PFC 08/06 for DE
    Tracks : Mt Tremblant : Sebring : Lime Rock Park : Watkins Glen : Thunderhill-West : Homestead Miami : PBIR
    Backroads : Carmel Valley Rd (G16): Blue Ridge Parkway : Diamondback (226A) : Tail of the Dragon
    Schwabe's Avatar
    Schwabe is offline I'm an excellent driver ....
    Jan 2008
    MD
    1,629
    90
    Re: Please post your ride height
    Approx. mileage on springs: 8,000
    Brand: H&R coilovers
    Front (in.):13.5
    Rear (in.):14
    j_copeland's Avatar
    j_copeland is offline formerly the grill mesh guy...
    ohio
    723
    149
    2006 Cayman S with PASM at 20,600 miles:
    front: 14 1/4 in. rear 15 1/4 in.
    alan93rsa's Avatar
    alan93rsa is offline Porsche Purist 1,000 post club
    Ohio
    1,209
    2009 CS
    - 6000 miles
    - OEM Springs (PASM)
    - Front: 14 3/8"
    - Rear: 15 1/8"
    I'll fill this in as soon as I get my car back from having a new master cylinder and brake booster installed.
    Alan C.
    2015 GT3
    06cs's Avatar
    06cs is offline Porsche Activist
    May 2008
    304
    Approx. mileage on springs: 5,000
    Brand: TechArt (eibach)
    Front (in.):13.75
    Rear (in.):14.5
    these measurements are on my stock 18's , i suspect it might be different on my 19" classics?
    06 Carrara White S - SRP 4.1 / FVD Exhaust / Techart Springs / 19" Carrera Classics
    Jul 2009
    1,059
    Quote Originally Posted by 06cs View Post
    Thanks 06CS! Reason suspension height should be measured from the center of the hub to fender is to remove any wheel & tire variance. When suspension is loaded, the distance from hub to fender does not change.
    Some will simply measure the gap between tire and fender, but that assumes tire wear is even between different measurements taken, and also assumes wheel + tire diameter, air pressure are exactly the same between cars. Same issue for anyone doing measurement from the ground to fender.
    What about H&R and Eibach owners?
    Chris
    finance09's Avatar
    finance09 is offline Site Donor
    Nov 2008
    IL
    243
    Approx. mileage on springs: 16,500
    Brand: Stock w/PASM
    Front (in.): 14.25
    Rear (in.): 15
    Jul 2009
    1,059
    Just installed Eibachs Pro-Kit on a 2008 Boxster S. I'll report again once they've settled after 250 miles.
    Approx. mileage on springs: 100
    Brand: Eibach Pro-Kit (part#7218.140)
    Front (in.): 13-7/8 (just shy of 2 fingers gap) from 15"
    Rear (in.): 14-1/2" (just shy of 3 fingers gap) from 15-1/2"
    Porsche compensation plates: 9mm (F) and 9.5mm (R)
    Side view
    Before/OE Suspension :
    After/Eibach Springs:
    Front quarter view:
    Before:
    After:
    Chris
    Tomasz's Avatar
    Tomasz is online now Porsche Orator
    1,745
    42
    40
    OK, here are the measurements:
    OEM Springs (Non PASM)
    14.500 | 14.500
    15.875 | 15.875
    Eibach Cayman S Springs with 3mm Porsche spacers added on each corner AND brand new 6.5mm bushings (Old ones definitely compressed 1-2mm over time). 15 miles and 24 hours to settle, pre-alignement.
    13.750 | 13.750
    14.875 | 14.750
    Delta
    0.750 | 0.750 (~20mm)
    1.000 | 1.125 (~25/28mm)
    This is without any ballast in the car.
    Tomasz
    Tomasz's Avatar
    1,745
    42
    40
    Interesting thing to note is that on my 2007 Cayman S non PASM I had the 6.5mm bushings on all 4 corners while Lithium had the 3mm in front and 6.5mm in rear...
    Tomasz
    Doc_Rishi's Avatar
    Doc_Rishi is offline Site Donor
    May 2006
    Suffolk
    372
    2006 CS
    - 29,000 miles
    - OEM Springs (Non-PASM)
    - Front: 14.5 "
    - Rear: 15.9"
    (my rear seems to ride much higher than the other posters)
    mdavis's Avatar
    mdavis is offline Tennessee Vol
    May 2008
    South Florida
    651
    14.25 front
    14.25 rear
    H&R Springs
    Michael Davis-MLD Racing
    2006 CS - Arctic Silver (www.facebook.com/mldracing17)
    Rebel Rock Motorsport built racecar: MoTec CDL3, Fabspeed race exhaust, sport tips, EVO racing flash, IPD Plenum/GT3 TB, desnorked, OMP racing seat, 6pt harness, short shifter, Numeric shift cables, fire ext, Enkei wheels, racing tires and Pagid Yellow or PF pads, under drive pulley, RSS rear sway bar, GT3 front sway bar, RSS control arms, RSS toe links and drop links, RSS wheel spacers, oil sump extension, stainless steel brake lines, wheel studs, full Grand Am cage, GoPro and SmartyCam Video, Motorsports Cup AOS, Accusump oil accumlator, Cool Shirt system, Rennline racing pedals, Fabspeed long tube race headers, GT3 Cup Car battery, GT3 Cup Car hood pins, Guard Pro LSD, CF front splitter, Cayman Interseries rear wing, Sparco quick release steering wheel, 997 manifold and injectors, BGB cold air intake, , Fvd sump and baffle, WEVO 997 Semi-solid engine mounts, KW Clubsport coilovers, Lexan side windows with ducts Tracks: Sebring, Homestead-Miami, PBIR, Watkins Glen
    np0531's Avatar
    np0531 is offline Site Donor
    Nov 2009
    33
    Approx. mileage on springs: 1,500
    Front (in.):13.5
    Rear (in.):14
    Speed Racer S's Avatar
    Speed Racer S is offline Porsche Activist
    Jun 2006
    304
    Champion Motorsport springs (supposedly rebranded H&Rs, but now I wonder)
    13.5 front
    13.75 rear
    no spacer front, 15mm spacer rear.
    Matte Black Cayman S
    s550 Black/Black
    e93 m3 AW/FR
    FrankinCayman's Avatar
    FrankinCayman is offline Porsche Activist
    Feb 2008
    469
    ps9's, H&R sways. ( for the last week )
    13.75 front
    14.5 rear
    Geomic's Avatar
    Geomic is offline Porsche Enthusiast
    May 2008
    Limassol
    171
    52
    64
    Stock PASM 2005 Cayman S 12/2005
    Odo: 60100 Km
    Front: 13.98"
    Rear: 14.96"
    Current Car: Cayman S and Loving it!!!
    Previous Car: DC5 Integra Type R (JDM Version / 220Bhp)
    Bicycle: Cube LTD 2010
    Bike: Honda VTR SP2 (AKA RC51 in the USA)
  17. #17
    titanic's Avatar
    titanic is offline Site Donor
    Jul 2006
    1,223
    42
    Cargraphic springs with PASM
    Mileage: 13,750 mi
    Front: 13.6
    Rear: 14.2
    Looking for LED rear light units to replace stock
  18. #18
    harajuka's Avatar
    harajuka is offline Porsche Activist
    Mar 2008
    Jacksonville, FL
    328
    221
    Photos Re: Please post your ride height
    KW Variant 3
    Mileage: 14k mi
    Front: 12.625
    Rear: 12.75
  19. #19
    Schwabe's Avatar
    Jan 2008
    MD
    1,629
    90
    I am six feet.
  20. #20
    Feb 2008
    469
    I just changed to JIC cross shocks, and we set the ride height to 14 front and 14.25 rear.
    Would have made it lower, but the spoiler in the front will hit everything.
    Our goal with the ride height ( and over all ) is to make the car as balanced as possible.
  1. Please folks, post your pictures
    By What_a_Croc in forum 987 Cayman and Boxster Chat
    Last Post: 10-02-2007, 01:13 PM
  2. Definative Ride-Height Thread!
    By JackWood in forum United Kingdom, Ireland Region
    Last Post: 01-07-2006, 03:27 PM
  3. Spec & order confirmed, please post.......
    By S-Line in forum United Kingdom, Ireland Region
    Last Post: 11-25-2005, 03:44 PM
  4. Post your options ordered.
    By VicL in forum 987 Cayman and Boxster Chat
    Last Post: 10-04-2005, 03:09 PM
  5. Please donate your Cayman photos!
    By K-Man S in forum Website Info and Feedback
    Last Post: 08-30-2005, 10:41 AM
