Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Like Tree1Likes
Thread: hard to shift into 2nd gear in the morning
    Jon_UK's Avatar
    Jon_UK is offline Porsche Chatter
    Jan 2009
    2nd gear crunchy in 6 spd?
    i have a crunchy 2nd gear when cold. seems fine when it's warmed up.
    is this normal, or should i be afraid?!
    thanks,
    Jon
    kehr's Avatar
    kehr is offline Porsche Idealist
    Dec 2007
    Missouri
    911
    Re: 2nd gear crunchy in 6 spd?
    Be afraid . . . be very afraid! JK. I get a little grind in 2nd occasionally too. can't say it's just when it's cold though.
    downshift's Avatar
    downshift is offline Porsche Idealist 500 post club
    Sep 2008
    USA
    792
    71
    Crunchy shifting is somewhat normal when cold. Just be extra careful and smooth until the car warms up.
    How many miles on your car? Or more specifically, how many miles on the gear oil? What brand and weight is it? Perhaps you just need to drain and refill with the proper oil (I believe Porsche recommends Mobil 1 75W-90).
    SCOPPOLA is offline Know-it-all
    Jan 2008
    119
    48
    Gamertag: Neb00
    I have a bit of a crunchy feeling when shifting into second sometimes too, but not always when cold. Don't like it much! Unfortunately, at my dealer, things that cannot be reproduced on command cannot be fixed!
    NNH's Avatar
    NNH
    NNH is offline Porsche Enthusiast
    Jul 2008
    DE
    109
    The synchro on second gear is always the one that's used hardest, because the gap from 1st to 2nd is so big: rpm fall by almost 50%, whereas (for example) they fall by only ~16% from 5th to 6th so there is much less of a difference in engine speed.
    Eventually, the second gear synchros will get worn to the point that there is a little crunchiness even when warm, but that takes a huge mileage
    Preventative measures are:
    1) Change more slowly from 1st to 2nd to let the engine revs drop enough (especially when cold)
    2) Double-declutch the 1-2 shift for the first couple of minutes in the morning, especially when it's cold
    Option (2) is a hassle, but it has helped me keep a number of German gearboxes happy well past the 100k mark, and it's a fun skill to learn.
    Simon
    Another Brit in Delaware
    Jan 2008
    119
    48
    Gamertag: Neb00
    I too thought a double-declutch would solve this, but it makes no difference on my car. And, it's done it since it was new.
    echoboy's Avatar
    echoboy is offline Member of West Coast Group
    Feb 2008
    659
    can you please explain what a double declutch is?
    thanks
    Starlight's Avatar
    Starlight is offline Porsche Activist
    Apr 2007
    412
    40
    Quote Originally Posted by echoboy View Post
    thanks
    When changing down gear, press in clutch, put gear into neutral , release clutch, rev the engine to match expected higher revs from the lower gear, press in the clutch, change down a gear and release the clutch. (all done in a quick sequence)
    Had to do that for many years on my dads old Renault 18 Turbo, no syncro in 3rd for 10+ years
    Basically you are saving the syncro from having to work by speeding the engine a free gears up to the required new speed in the gearbox.
    Track Days - Anglesey, Bedford, Castle Combe, Spa F1 Track
    NNH's Avatar
    NNH
    Jul 2008
    DE
    109
    thanks
    In US English "double clutch"
    For a 1st to 2nd change
    1) Accelerate to (say) 4500rpm in first
    2) Push in clutch and hold it down
    3) Move gear lever to neutral
    4) Allow revs to drop to ~2300rpm and use throttle to hold them there
    5) Let clutch out while in neutral with engine speed still at ~2300rpm
    6) Push in clutch while still holding ~2300rpm
    7) Move gear lever to second
    8) Let clutch out
    9) Enjoy perfect smooth shift with no strain on synchros or engine mounts
    10) Accept adulation of passenger, while attempting to pass it off as no big deal...
    In real life, 2-4 happen pretty much together, and 5-6 happen as quickly as you can pump the clutch. On the rare occasions that I get it right (9), I make sure that I get all the benefit that I can out of 10.
    Some older guys (I mean more mature people) tend to use this more for downshifting, but I'm convinced that it's 1st-2nd shifts on a cold gearbox that cause the most wear.
    Incidentally, once you've got this procedure down pat, you can in theory skip using the clutch entirely as the engine, road, and gearbox layshaft speeds are all perfectly aligned. I don't recommend this for expensive cars, but it did get me home once with a Miata with a busted clutch slave cylinder, and another time when I mangled my left knee skiing and used a ski pole for the initial engagement of the clutch in first followed by 100 miles of clutchless shifting in my old WRX (for anyone on this board who may eventually buy my Cayman, I absolutely promise I've never done this in it)
    Simon
    Kujibo is offline Porsche Prophet
    BC
    91
    Quote Originally Posted by Jon_UK View Post
    thanks,
    Jon
    My car is exactly like this. That first shift into second is always really stiff, and I have ground the gears a few times because of it. It actually seems worse lately as I don't recall grinding the gears before. I have the short shifter as well so it probably doesn't help. On top of that a porsche tech who did a test drive said my shifter seemed stiff in general as well, so it all adds up to a pretty nasty shift into second when cold. It is fine when warmed up.
    AdamR's Avatar
    AdamR is offline Porsche Person
    Jan 2009
    illinois
    when it is cold (assuming there is no synchro damage) shift 1st to 3rd slowly until the tranny warms up after a few miles or at least 6/7 shifts it should ease up...if it persists it is a synchro....first and second gears have a special coating they should be ok on a newer car unless it was habitually missed shifted....and try not to hold the shifter when not using it....its not some dumb Hollywood movie where they think that is something cool to do with a manual trans.
    Jon_UK's Avatar
    Jan 2009
    Thanks all for your help - definitely reassuring. I'll give double de-clutching a go, and be extra smooth (as I always try to be when cold).
    It's worth saying this is one of the best gearboxes I've ever had the pleasure of using - when warm !
    Jon_UK's Avatar
    Jan 2009
    update : double de-clutching definitely helps. I'm also going to try the first to third option, and will report on that... more to follow!
    NNH's Avatar
    NNH
    Jul 2008
    DE
    109
    Great to hear it's working! Your gearbox will thank you as you approach 60-100k miles, and it's more fun too!
    Simon
    pcheng2 is offline Porsche Chatter
    Cerritos/Irvine
    it's very hard to shift into 2nd gear in the morning when it's cold. however, as the engine warms up after a couple mins. it becomes easy. do any of u guys have this problem? it's only 2nd gear that has this problem.
    oh and i got my oil changed last week and told the technicians this problem. they said they moved the shifting wires, but they said they won't know until the car completely cools down(i guess they were too busy to wait for the car to cool down). but i still have this problem. what should i do?
    it gets annoying because sometimes i try to shfit into 2nd gear, it only goes half way in, and as i let up the clutch it grinds the gear....so annoying. should i take it back to the dealer?? thanks.
    Sep 2005
    New Mexico
    10,001
    Re: hard to shift into 2nd gear in the morning
    Do you have the short shifter? There have been some reports of that being an issue with them (search for short shifter). You didn't mention searching so here are is a somewhat related thread http://www.planet-9.com/cayman-boxst...ough-pcna.html
  17. #17
    In2Esses's Avatar
    In2Esses is offline Porsche Purist
    Dec 2006
    Georgia
    1,318
    If you have a new car (seeing your post count), everything will loosen up over time...... and with higher operating temps....
    In2Esses
    2006 CaymanS - Black/Black
    2010 BMW 135
    2012 Mercedes GLK 350 4Matic
  18. #18
    old dude's Avatar
    old dude is offline Porsche Specialist
    Feb 2007
    732
    Try a double clutch from 1st to 2nd when the gear box is cold. I've been doing this for years. The stuff in the tranny is really thick in cold weather.
  19. #19
    Cerritos/Irvine
    thanks for the input guys.
  20. #20
    ELP_JC is offline Porsche Specialist 500 post club
    520
    I know nothing about Porsches, but have solved that exact problem in many other cars with fully synthetic oil, like Redline. It's much more 'liquidy' than stock, therefore much better in the cold. Definitely worth trying IMO. Good luck.
  1. Replies: 0
    Last Post: 03-10-2014, 07:00 PM
  2. Car getting towed in the morning to the dealership =/
    By shootermcgavin in forum 987 Cayman and Boxster Chat
    Last Post: 10-30-2013, 09:44 AM
  3. Replies: 0
    Last Post: 09-20-2012, 09:30 AM
  4. Can't shift into second gear
    By caymanpilot in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 07-26-2011, 06:22 PM
  5. Where to buy H&R springs in the uk
    By bambino don in forum United Kingdom, Ireland Region
    Last Post: 05-20-2008, 11:22 AM
