Results 1 to 7 of 7
    Globespy is offline Porsche Activist
    Jun 2009
    449
    Rythmic Ticking noise at Idle
    I notice that when the car is started and sitting idling there is a very rythmic ticking noise from the engine. I can't notice the noise when I'm driving, excpet when I come to a stop at a light and I can hear the noise reflecting from the car next to me.
    I've read some stuff about it being injectors etc and that it is normal on most porsches?
    Is this normal for Boxsters? Is it part of having a porsche?
    LA Boy's Avatar
    LA Boy is offline Site Donor
    Dec 2005
    2,547
    57
    Re: Rythmic Ticking noise at Idle
    Fuel pump?
    coal0101's Avatar
    coal0101 is offline Porsche Specialist
    Jul 2009
    GA
    514
    Quote Originally Posted by Globespy View Post
    Sounds like lifter tick. I am new to porsche, so I can't say if that is the norm. I came from having several Mitsubishi's and they were famous for lifter tick. There were all kinds of home remedies and oil additives, but I think the only real long term fix was the newer lifters with a larger oil hole.
    All of my mits had lifter tick and you could do some things to get it to go away...but it would always resurface.
    downshift's Avatar
    downshift is offline Porsche Idealist 500 post club
    Sep 2008
    USA
    791
    71
    I agree, sounds like lifter noise. Does the ticking get faster or slower as the revs increase and decrease?
    What weight oil do you use and when was it last changed? How many miles on the car?
    Krokodil's Avatar
    Krokodil is offline PCA / POC Member & Club Donor
    Sep 2006
    SoCal
    1,857
    154
    46
    It is most likely the variocam actuator. Many of the M97 engines seem to suffer from this. Not a big deal until it gets worse...then all goes wrong.
    If it starts to get worse, and does not go away when warm, then you should have it replaced. If you do not then it may fail completely, causing the cam timing to go haywire and the production of catastrophic sounding noises (sounds like flailing timing chains).
    You can test if this is the source using a Durametric or PIWIS by turning the variable cam timing on/off. If the clicking goes away when the actuator is shut off then viola, you have your problem.
    Cheers,
    A
    www.caymanspec.com
    Vision Motorsports - Fikse - JRZ - Tarett - MantisSport
    Jun 2009
    449
    Quote Originally Posted by downshift View Post
    The ticking get's faster as I rev the engine higher.
    49K miles on car
    Oil Changed 3K miles ago (Mobil 1)
    Sep 2005
    New Mexico
    10,001
  1. Fan Noise at start up?
    By KBS911 in forum 987 Cayman and Boxster Chat
    Last Post: 08-04-2011, 07:36 AM
  2. Boxster ticking noise at start up
    By O'Leary in forum 987 Cayman and Boxster Service and Tech
    Last Post: 10-03-2010, 11:24 AM
  3. Noise like a cricket at idle
    By motoadve in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 09-21-2008, 08:06 PM
  4. Whirring noise at idle
    By b0rked in forum 987 Cayman and Boxster Service and Tech
    Last Post: 10-22-2007, 07:41 PM
  5. What is your RPM at idle? Mine is 700 rpms
    Last Post: 05-29-2006, 07:14 PM
