Results 1 to 20 of 33
Like Tree2Likes
Thread: Leaking CV Boots
    KS-CS's Avatar
    DFW TX
    3,885
    441
    169
    Question Leaking CV Boots
    My right-sided, outboard CV boot has started to leak a small amount of grease; I recently had the left-sided boots replaced by the dealer (at some expense, because the outer boot was leaking on that one as well). The arrow on the picture below indicates that the grease just appears to be leaking at the end of the boot before the bearing housing. There doesn't appear to be any tear in the boot itself, and there doesn't appear to be any easy way to tighten the retaining bands on the boot, or make the seal against the housing any tighter.
    When I took my car into the dealer for the left-sided leak, they told me that the high lateral g-forces on the track were probably causing the problem by forcing small amounts of grease out through the end seam. They felt the only way to fix it was by replacing with a new boot which would fit tighter on the axle.
    With all the 987s on the track, I'm surprised that I can't recall seeing this problem reported before. Has anyone else faced this issue, and if so how did you deal with it? Any other recommendations?
    2011 Macan S: Wifey's DD
    K-Man Isle's Avatar
    K-Man Isle is offline Porsche Enthusiast
    Feb 2011
    Hawaii
    121
    Re: Leaking CV Boots
    You probably know more about this than I do. However, I would be very skeptical that lateral g of less than 1 would cause the leak you describe. I would be more inclined to believe that the dealer wanted some work to do, wanted to stop the leak, wanted to replace the left boot, and didn't really know the cause.
    2010 Cayman S, PDK, LSD, Sport Chrono
    jhthornley's Avatar
    jhthornley is offline Site Donor
    Charlotte, NC
    1,117
    I too tend to think the G force business is BS... Are you sure you can't tighten the clamp? It should be one of two types... crimp, in which case you might be able to "extra crimp", or screw down, which obviously you could alter
    DMN987S's Avatar
    Alabama
    1,584
    70
    Mine leak and I know my mechanic tried to tighten them but couldn't, I just live with it. The grease is a PIA to clean too.
    Edit: I'm not sure where they leak, I just know grease drips on the inside of the wheel during DEs, it used to drip a little all the time.
    aiiee's Avatar
    aiiee is offline Porsche Specialist 500 post club
    Mar 2011
    MI
    740
    Why not cut the bands off and replace them with ones you can tighten?
    3G3T7I's Avatar
    3G3T7I is offline Insider
    May 2010
    Pennsylvania
    673
    69
    As suggested those band clamps can be replaced, but I'm not sure you'll see an improvement. If you cut the existing clamp and try to clean the sealing surfaces I think you find it nearly impossible, but you might be able to get a new clamp just a bit tighter or at least enough to make a better seal. And then again you could get the clamping tool and try to get a tighter fit.
    This tool looks decent:
    Amazon.com: Lisle 30800 CV Boot Clamp Pliers: Automotive
    KS-CS's Avatar
    DFW TX
    3,885
    441
    169
    There has been a discussion on the Cayman Register on this topic as well, and a couple of people there have reported some success at removing the existing clamps, cleaning the axle surfaces and repacking the boot with new grease, and placing new clamps (which do require a special CV boot clamp tool). The alternative is removing and replacing the boots with new ones (it is usually recommended to replace both the inner and outer boot if you are removing the axle anyway) - a much more laborious (read: $$$) procedure.
    It appears that this may not be a rare problem among those of us who track our cars; the common wisdom thus far is that the sustained high temps around the outer boots (e.g. from hot brake rotors, exhaust pipe, etc) tends to liquify the lithium grease more, and this perhaps combined with the high lateral g's tends to force some of the grease out through the end of the boot.
    In any case, placing new clamps is probably just a temporary fix for those who regularly track their cars.
    ChipB's Avatar
    ChipB is offline Porsche Activist
    Feb 2012
    Illinois
    263
    Resurrecting an old thread here. I was wondering if others have experience with DEs and leaking drive shaft seals. Just completed two wonderful days at Road America, and following the last session of the last day was parked in the paddock with engine idling to keep the water pump and fans running when after about three minutes suddenly a gush of lubricant like thick oil came pouring out of the left rear wheel hub area. I'm no expert, but my guess is it's due to leak in the drive shaft seal. I was able to drive home (about 150 highway miles) with no further detrimental effect - no strange smells, grinding noises, etc. So I'm trusting that I can drive the car to the repair shop without too much issue - not as if all the oil had drained from the differential, for example, right? (I know from experience that if you drive a couple miles with no differential oil the diff becomes toast.)
    KS-CS's Avatar
    DFW TX
    3,885
    441
    169
    FOLLOW-UP:
    I recently repacked and replaced the clamps on one of my CV boots which was leaking quite a bit. I documented the procedure in an Article here:
    Repacking and clamping CV Boots - Articles
    Jeff_07S likes this.
    Jeff_07S is offline Porsche Activist
    Sep 2011
    Los Angeles, CA
    398
    Great write up! I'll be trying to do the same. One of my boots is leaking, and I've never driven on the track. I think all the commuting driving during summer temps will liquify the grease just the same.
    Sep 2011
    Los Angeles, CA
    398
    Is there a part number for the larger adjustable clamp?
    KS-CS's Avatar
    DFW TX
    3,885
    441
    169
    Quote Originally Posted by Jeff_07S View Post
    The official OEM part # is 996-332-957-00 which is supposed to fit 70-74mm, however I found it to be too large. The one I bought from my local dealer isn't an official Porsche OEM part, so I'm not sure who makes it. Others have posted using the following successfully Oetiker CV68 CV Clamp.
    San rensho is offline Porsche Enthusiast
    Oct 2012
    108
    Worm gear type hose clamp works very well.
    mroseland is offline Porsche Prophet
    Mar 2012
    AZ
    92
    There are also the belt-type of bands that are one size fits all and use a tool you put a ratchet on to tighten. I'm a big fan of that type.
    Mathelo is offline Porsche Prophet
    Jun 2012
    CT
    84
    I used these EMPI CV Boot Clamps Amazon.com: EMPI CV Boot Clamp: Automotive
    with this OTC 4623 CV Joint Banding Tool And Cutter OTC 4623 CV Joint Banding Tool And Cutter : Amazon.com : Automotive
    I was generally satisfied with it but I never felt like it was tight enough. I broke one of the clamps when tightening but it may have been good enough.
    Louis
    Sep 2011
    Los Angeles, CA
    398
    I saw "67" stamped on the large clamp on my car. My guess is 67mm is the size
  17. #17
    NE Spyder's Avatar
    NE Spyder is offline Porsche Specialist 500 post club
    Feb 2011
    Greater Kansas City
    667
    This is likely what is really happening.
    The grease will break down with time and as its viscosity drops it will pass through seals easier than before resulting in leaks.
    The right correction would be to pull the boots back, clean and replace the grease. The question now is, how frequently do you do this?
    Afshin
    2011 Spyder - Basalt Black, Black Full Leather, 6MT, Sport Buckets, PSE
  18. #18
    Oct 2012
    108
    Quote Originally Posted by NE Spyder View Post
    In my case, it was very clear that the clamp had worked its way loose. It was very easy to twist the boot by hand. Once I replaced the clamp with a worm gear hose clamp, no leaks at all.
    Remember, the factory clamps are flimsy excuses for clamps that are designed for speed of assembly at the factory. Use good clamp and you will have no problems.
  19. #19
    Livermore, CA
    830
    When the boots fail and before they let any dirt in.
    In the case of my 02 Boxster when the original CV boots cracked at something way over 200K miles. The tech removed both axles and disassembled cleaned and inspected the bearings and found no reason to replace. He repacked them with grease fitted new boots and the axles/boots/etc have been problem free since. The car now has just under 275K miles.
  20. #20
    Livermore, CA
    830
    No it doesn't. That is the grease doesn't break down and leak. The boots fail or less often a clamp fails.
  1. Leaking Grease from CV Boot Clamp
    By ChipB in forum 987 Cayman and Boxster Service and Tech
    Last Post: 08-13-2014, 03:03 PM
  2. Leaking CV Boots - Repack and Clamp
    Last Post: 10-20-2013, 08:20 AM
  3. Rear CV boot replacement cost
    By bldn10 in forum 987 Cayman and Boxster Chat
    Last Post: 11-27-2012, 10:19 AM
  4. ECS Air Powered CV Boot Installer for Caymans
    By DocSteve in forum 987 Cayman and Boxster Service and Tech
    Last Post: 02-02-2012, 07:09 PM
  5. CV Boot Grease
    By heyhobingo in forum 987 Cayman and Boxster Service and Tech
    Last Post: 10-16-2011, 08:18 AM
