12-18-2007, 12:04 PM
|  | Porsche Specialist 500 post club | | Join Date: Mar 2006
Country: | | | 5 speed vs. 6 speed gearbox comparison (pics) |
12-18-2007, 12:06 PM
|  | PCA Register Coordinator | | Join Date: Oct 2006 Location: Connecticut
Country: | | | I'd say it's made by Getrag, just like the 6 speed. If fact, I am pretty sure that's the case. |
12-18-2007, 01:05 PM
|  | Porsche Specialist 500 post club | | Join Date: Aug 2006 Location: The Kingdom of Fife
Country: | | | I seem to recall reading that the 5 speed box is sourced from Volkswagen.
JH |
12-18-2007, 01:21 PM
|  | Caymaniac  5,000 post club | | Join Date: Oct 2006 Location: California
Country: | | | Incidentally....a read of the manual shows that the 6-speed's gear ratios for 1st and 2nd are DIFFERENT when in the 2.7 versus the 3.4, which I find interesting.
(3.67 and 2.05 for the 2.7, but 3.31 and 1.95 for the 3.4)
3rd through 6th are the same.
Also, the final drive ratio of .82:1 for 6th gear isn't that much taller than the .84 in the 5-speed.
I liked the 5 speed in my 2.7, by the way.
__________________ 2007 Speed Yellow Cayman GT 2.7 (retired)
2012 Carrara White Cayman R
"Carpe Cayman" |
12-18-2007, 01:42 PM
|  | Silver Sponsor  2,000 post club | | Join Date: Jan 2007 Location: DC
Country: | |
Originally Posted by John H I seem to recall reading that the 5 speed box is sourced from Volkswagen.
JH |
audi more specifically.
__________________ Casey Parkin : Washington, DC Porsche of Silver Spring
301.890.4684 (Call for Porsche Sales Related Questions)
Sales & any other Porsche Questions you might have! cparkin@mileone.com
Happy to pull your VIN options if you make a $5 Donation to the Alzheimers Association |
12-18-2007, 03:31 PM
Country: | |
JH | I've got a little surprise for you. VW and/or Audi don't make transmissions. They source them out just like everyone else. That's sort of a specialty part. And they have also been known to use Getrags.
I had once heard that they were made by VW, and another time that they were Japanese. I asked the Guru, Scott Slauson, and he had this to say:
Originally Posted by PCA-TECH The G86.01 that was used in the 986 is much the same as the G87.01 that is used in the Boxster and Cayman. These are made by Getrag and are 5spd transmissions.
The Aisin Seiki is used in the 997. | |
12-18-2007, 10:03 PM
|  | PCA Member 1,000 post club | | Join Date: Apr 2007 Location: Maryland
Country: | |
Originally Posted by DaveN007 (3.67 and 2.05 for the 2.7, but 3.31 and 1.95 for the 3.4)
I liked the 5 speed in my 2.7, by the way. | So what do these ratios signify? Also what's a 'good' or 'bad' gear ratio...
__________________ -Chad-
2006 Black Cayman S, many mods. (broken, but not forgotten)
2013 Tuxedo Black Focus ST2 (New DD that makes me giggle every time.) |
12-19-2007, 01:18 PM
| | Porsche Specialist 500 post club | | Join Date: Mar 2006 Location: Florida
Country: | | | There are not many companies out there manufacturing transmissions. I say Getrag or ZF. A real dark horse would be the people in California "Butfoy" that make gear boxes for lambos, Vectors and others based on the old series SD-2 ZF.
__________________ formerly cebotech1 |
12-19-2007, 01:33 PM
Country: | |
Originally Posted by golfguy11800 So what do these ratios signify? Also what's a 'good' or 'bad' gear ratio...  | Gear ratio - Wikipedia, the free encyclopedia
The gear ratios will contribute to how quickly a car can accelerate and/or how fast it's top speed will be. My understanding is that the gear ratios in a Cayman S vary from those of a 911 in a way that makes the Cayman a bit slower to 60mph than it could be, with different gear ratios to avoid the problem of having a Cayman be too close for comfort to the 911.
The new Nissan GT-R is a great example of creative gearing. It is geared to accelerate very quickly to 60...and REDLINES at 186 mph. They do this to keep up with the 911 Turbo which has the same amount of HP but 400 pounds less weight. The GT-R probably NEEDS the auto/manual clutch gizmo to shift quickly enough to take advantage of the gearing. My brother's 997 TT is very hard to nail in first gear without banging against the rev limiter.
"Carpe Cayman" |
12-19-2007, 03:49 PM
|  | Porsche Orator 1,000 post club | | Join Date: Aug 2005 Location: Virginia
Country: | | | golfguy: From the gear ratios reported above, the 2.7 Cayman has "lower" ratios (higher number = lower ratio) for the first two gears, giving it more grunt (applied torque) in those gears. This may be partly why some who've driven both back-to-back reported being surprised that the 2.7 was so quick up to 60 mph or so.
When the '06 CS came out, it not only had higher gearing in the first two gears than the 997, but it also had higher gearing than the '06 Boxster S, which had 280 hp at that time.
One way to increase acceleration of the CS would be to lower the gearing some, but that doesn't seem very simple. I've not understood why the gearing of the CS is as it is (the two top gears are both over-drives, for example), unless it was to help maintain the separation between the CS and the 997. |
01-05-2008, 12:25 PM
|  | Porsche Chatter | | Join Date: Aug 2007 Location: Austria,Lower
Country: | | | Hi from Austria !
You have stolen my pics ! This is my old gearbox in my garage ! Now you have to buy it !
Greetings ! |
01-05-2008, 03:30 PM
Country: | |
Greetings ! | LOL!  Welcome aboard.
Hey, is it Getrag? |
01-06-2008, 03:45 AM
Country: | | | Hi again !
There is nothing to find except "made in Germany", "VW" and "Audi" on the 5-speed-gearbox.I did a conversion to 6-speed from a Boxster S `07 and the 6-speed-gearbox is definitely made by Getrag.But the 6-speed-gearbox has a very big disadvantage - the weight !
Best regards ! |
01-06-2008, 04:51 AM
|  | Porsche Enthusiast | | Join Date: Dec 2006 Location: wiltshire
Country: | | | gearbox looks identical to passat /a4 platform.
ive had a few of these out.
vag group make most of there gearboxes in house.
engines grygor hungary plant / gearboxes kassel plant.
(plus others of course, but these are the biggest.) |
01-06-2008, 05:07 AM
Country: | | i wonder if the bellhousing is the same bolt pattern as v.a.g ?
it looks it !
possible 1.8t / other v.a.g engine's in the future !
even the old water cooled flat four (i used to rebuild these when i was a apprentice !).
thats another thing - is the porsche bottom end similar to the vag water boxer ?.
i know they share a lot of stuff ! |
01-06-2008, 09:37 AM
Country: | |
Originally Posted by mugenseiki I did a conversion to 6-speed from a Boxster S `07 and the 6-speed-gearbox is definitely made by Getrag. | Do you have any pics of your 6-speed gearbox? |
01-06-2008, 01:32 PM
| | Porsche Activist | | Join Date: Jun 2007
Country: | | | I swore the 5 speed in my cayman said aisin on it... |
01-07-2008, 03:56 AM
Country: | | | Sorry - I didn`t take pictures before I installed it ! |  | | Thread Tools | | | | Display Modes | Linear Mode |
