Results 1 to 3 of 3
Thread: Cayman S 2006 how to open the engine compartment
    ilyushin is offline Porsche Person
    Mar 2008
    maryland
    Hello, New to Porsche, New to Cayman, last Car Z4M. Bought the Cayman but no Manual or 2nd and 3rd keys. Low miles 6K but rear tires will only last 2K more by my estimate. My questions, How do I know if this car has TPMS or not? Also, How do I open the engine bay?. Will changing the oil void my warranty? Thanks a ton in advance. Ilyushin
    Gamecock's Avatar
    Gamecock is offline PCA Member
    Nov 2006
    276
    Here is a link to opening the engine compartment. Check out the articles section as there is a lot of info on all kinds of Cayman projects there.
    My Articles - Engine Cover & Air Filter Removal - Powered by ReviewPost
    KS-CS's Avatar
    DFW TX
    3,885
    444
    169
    Quote Originally Posted by ilyushin View Post
    Welcome to the Club!
    To answer a couple of your questions:
    I think the simplest way to determine if you have TPMS is to look at your valve stems: if they are rubber, then you don't have TPMS; if they are metal, then you probably have TPMS sensors. You should also be able to bring up the TPMS screen on your info center with the control stalk, if you have TPMS.
    Just changing the oil will not void your warranty (at least so long as you are replacing it with a Porsche-recommended oil e.g. Mobil 1 0W-40). I'd advise keeping a record with receipts for your oil/filter purchases, etc. however, just in case.
    If you do a bit of exploring, especially under Files, Articles, and FAQ, you will find a wealth of info on just about anything you want to know about your Cayman, for example here is a link to the 2006 Owners Manual for download.
    2011 Macan S: Wifey's DD
  1. How to open the home link panel above the center mirror?
    By zapta in forum 981 Cayman and Boxster Electronics
    Last Post: 08-29-2013, 12:43 PM
  2. Capristo Exhaust on 2006 Cayman, what RPM to open the valves for most performance?
    By mcbrite in forum 987 Cayman and Boxster Modifications
    Last Post: 03-28-2013, 11:45 PM
  3. how to make the Cayman sound like a V-8
    By prodgers in forum 987 Cayman and Boxster Pictures & Video
    Last Post: 05-22-2011, 10:17 PM
  4. Tinted rear lights on Cayman, how to remove the tint
    By smartmove in forum 987 Cayman and Boxster Modifications
    Last Post: 10-13-2010, 02:22 AM
  5. How to remove the front scoop on a Cayman
    By oregonduckman in forum 987 Cayman and Boxster Modifications
    Last Post: 08-31-2009, 01:50 PM
