12-10-2008, 08:50 AM
 | Porsche Prophet | | Join Date: Oct 2008 Location: Oxfordshire
Country: | |
| Re: Mech Advice Needed: Alignment After Strut Replacement? If the steering wheel is not level when the car is travelling straight it most likely points towards a lazy technician!!
They probably checked the front, found the tracking out (highly likely even if its not been worked on, kerbing, pot holes, worn tyres, etc) and only adjusted one track arm.
If the strut has been off completely then the car will need an allignment. When checking anything other than just the front tracking its just as easy to check the whole car than either just the rear or just the front. Any adjustment made to toe, caster or camber will result in changes in another area of the car by default. Geometry work is a juggling act.
I would suggest that even if you only replaced the springs and havent touched any adjusting bolts you should still consider an alignment check if only as a precaution.
__________________ [SIGPIC][/SIGPIC] |
