Results 1 to 20 of 36
Like Tree2Likes
Thread: Airbag light after battery change walmart
    armornone is offline Porsche Chatter
    Mar 2011
    Utah
    Does anyone know if the Walmart auto center has the ability to turn off the airbag warning light.
    My battery died and Big O wanted like $215 to replace the battery vs Walmart's $80.
    Anyway, walmart change the battery and the car works fine except for the airbag warning light that must have been tripped by the battery change.
    Does anyone know if they are able to turn off the airbag warning light from whatever computer system hookup they have?
    Assuming they can get access to the computer system in the Porsche Caymen, does anyone know exactly how they would maneuver around to turn that airbag warning light off?
    Thanks.
    Mar 2011
    Utah
    Can 3rd party mechanics shops do the reset?
    Can 3rd party mechanic shops do the airbag reset or just the Porsche dealer.
    Battery died and changed out for a new one and airbag light won't turn off.
    Wondering if resetting that is a dealer only thing or if 3rd party companies every have access to these things.
    I don't know how standardized the computer systems are in these cars.
    Thanks.
    DMN987S's Avatar
    Alabama
    1,606
    70
    Re: Can 3rd party mechanics shops do the reset?
    You can reset the airbag warning light with the Durametric software, most independent shops should have one.
    drPhilGandini's Avatar
    drPhilGandini is offline Site Upgrade Donor
    Aug 2010
    New Mexico
    1,365
    152
    Yes, I've found most shops that actually work on Porsches have the Durametric software, but few can afford the PIWIS software that the dealer will have. The Durametric will reset the airbag light.
    My question: what did they do to trip it? It should not have gone off for a regular battery change, unless perhaps the ignition was on while they changed the battery?
    bxstr's Avatar
    bxstr is offline Porsche Orator
    1,830
    Quote Originally Posted by DMN987S View Post
    Agreed! Good luck at tell us your results.
    bxstr
    Cars-
    2009 BMW 335i Xdrive Coupe Space Grey Metallic
    2003 Porsche Boxster-Lapis Blue Metallic (SOLD)
    Mar 2011
    Utah
    I figured that changing a battery was the easiest thing you could have done mechanically to a car yet those guys managed to find a way to screw it up.
    I read on this forum that other people said their airbag went out after changing the battery.
    Here is the deal, I traveled for a few month, so I left a float changer on the batter to prevent it from going dead however the hood was not closed all the way so the light was still on. So the battery was completely dead for an extended period of time. I am not sure if that was a contributing factor or not.
    Anyway, Walmart auto services are oil change, tire change and battery change. So I am not sure what type of computer system or software they are working on.
    Man, I don't want to have to travel hundreds of miles to my nearest porsche dealer and shell out hundreds of dollars to them to reset this light.
    I will let you know what happens as soon as I get back in town and bring the car back to the walmart. I am sure other will be interested on that Walmart ability are with Porsche.
    P.S.
    Walmart and porsche, 2 words you never hear in the same sentence.
    KS-CS's Avatar
    DFW TX
    3,885
    444
    169
    Re: Airbag light after battery change walmart
    I hate to be pessimistic, but I doubt Walmart will be able to help reset the light, or figure out why it is on in the first place. I have had my battery die, and have disconnected it numerous times, and have never had the airbag light come on because of it. The only thing I can think of is that they may have disconnected one of the airbag wires, either intentionally or unintentionally, when they installed the new battery.
    2011 Macan S: Wifey's DD
    DocSteve's Avatar
    DocSteve is offline Porsche Enthusiast
    Mar 2011
    Grants Pass, OR
    188
    Get 9volt accessory plug to keep codes..
    Anytime you need to do a battery change get one of those accessory plugs with a 9v battery you attach (about 5 bucks ). It's enough juice to keep the electronics going so this doesn't happen..Good insurance.
    gtscayman likes this.
    Mar 2011
    Utah
    If the airbag light was tripped by low power than the reset should take care of it. If there is a wire disconnected,then this warning light should come back on I am thinking?
    Do you agree?
    Thanks.
    K-Man S's Avatar
    31,592
    4656
    264
    121
    Quote Originally Posted by armornone View Post
    Do you agree?
    Thanks.
    As KS-CS said, if you disconnect your battery your airbag light should NOT come on, that includes your battery going low and going dead, again should NOT come on.
    The proper course of action here is to take your car to a Porsche dealer and have them put it on the PIWIS and see if something else is wrong with your car. What if you also happen to have a faulty airbag? Sure you could clear the warning light but hopefully it would come back on anyway to alert you to the fact you have a faulty airbag. Do you want to find that out in an accident?
    Others have recommended Durametric and that would be your other choice, use it to turn off the airbag light, but in doing so do you know what caused it in the first place? You are assuming it is the low battery, but I don't think that assumption is correct and you have no proof that it is. If the airbag is faulty or there is a wiring problem etc. then the airbag light will/should come back on and you'll have to go to the dealer anyway, so spending the money on Durametric may be a good investment for other work later on, but it may not pay off for the airbag light alone depending on what your circumstances are.
    Finally, changing a battery on our cars is not hard, you just need to make sure they hook up the vent tube properly to the side of the battery. Once changed you will get PASM, etc. warnings but those will go away after you drive the car a short distace. The airbag light should not come on with simply changing the battery.
    Mar 2011
    Utah
    All I know if that the airbag light was off when I drove it in the Walmart auto center and it was on when it left. They did drive the car outside and part it.
    I should have placed a hidden camera in the car to see what those people did to my car.
    Is there any reason that whatever error you have can't just show up on the car's display like the tire pressure does,etc..
    For example, it could state the problem or even an error code that you could look up online or call in about.
    When you group the serious problems in with the silly ones, it causes people to just ignore them all.
    I wonder if it has to do with the dealers making money?
    Anyway, I just wonder what those walmart guys did to my car.
    Thank you for your concern.
    aiiee's Avatar
    aiiee is offline Porsche Specialist 500 post club
    Mar 2011
    MI
    740
    You sure the airbags are still there?
    K-Man S's Avatar
    31,592
    4656
    264
    121
    No one saying you don't have a serious problem, the problem is we don't know what is wrong with your car. You can get a code reader or the durametric pro software will read out the codes for you but often times it is just an airbag fault and you don't know what it is. Finding out what they did at Walmart might help pinpoint why you have the light on, so would diagnosing with durametric or at your dealer.
    Sent from my iPhone using Tapatalk which means I'm probably traveling at the moment so please excuse any brief or hurried replies, spelling errors, etc. Etc.
    In2Esses's Avatar
    In2Esses is offline Porsche Purist
    Dec 2006
    Georgia
    1,318
    I don't think anything is really amiss here.
    I had Kinetic replace my battery during a DE inspection a couple of years ago (no, I did not go and fight with Porsche to replace a wear item; I have better things to do with my time). But, when I got in the car, the air bag light was on. In 2 minutes they took car of it, but of course, they are a specialty shop that knows Porsches, not WalMart...................
    In2Esses
    2006 CaymanS - Black/Black
    2010 BMW 135
    2012 Mercedes GLK 350 4Matic
    K-Man S's Avatar
    31,592
    4656
    264
    121
    Quote Originally Posted by In2Esses View Post
    BTW I concur, I doubt this is a missing airbag, etc. the people at Walmart probably tripped something accidentally that caused the light. It would be nice to know what it is though just to be on the safe side of things.
    aiello11's Avatar
    aiello11 is offline PCA Member
    Apr 2010
    NJ
    156
    Well the first thing i would do simply at my home is shut the car off open the front hood , take the key OUT SIDE OF THE CAR " dont ask me why" Take the cover off not take the power and negative terminals off from the battery wait 30 min. drink a nice glass of wine in between. Then simply conntect back the correct way tighten. start up the car and go for a 15 minute drive. that should take care of any issues that are not really going on. I changed my batt and yes ther was a psm light or something else i just did the same thing and dont forget to drive and it should go away.
    If not then get it checked. its seems like a simple way to make sure that all this fuss is not about nothing. if you did this already then sorry about the time spent reading this haha.
    alex
    P987 likes this.
    The World Is Yours 08 black on black Cayman
  17. #17
    aiello11's Avatar
    Apr 2010
    NJ
    156
    and also i bought the johnson controls battery at walmart. My porsche dealer tech reccomended it to me.
  18. #18
    aiiee's Avatar
    Mar 2011
    MI
    740
    Yeah? That's what they said about my kidney...
  19. #19
    Mar 2011
    Utah
    They tried to use like a device they said cost around $100 and it could not even communicate with the porsche.
    Called the porsche dealers and they want $125 just to reset this! My goodness, anyway. One of the guys said they might be able to get access to a machine that cost several thousands of dollars that would have a better chance of working.
    I also tried the trick of disconnecting the battery with no luck.
    Just wanted to give everyone an update.
  20. #20
    clint.spann's Avatar
    clint.spann is offline Porsche Prophet
    Oct 2010
    93
    I have the same issue.
    I left my headlights on which drained the battery. I hooked up the jump wire to get the front trunk open. I charged the battery for 15 mins, disconnected the charger, and attempted to start the car. It wasn't enough. I charged for 45 minutes more and was able to crank the car. I got a message about Airbag error (forgot the actual message) but the air bag light remained on.
    I drove car for about 10 minutes and the light remained on. I disconnected the battery for about 45 minutes, hooked it back up, and turned on the key. I then got a PSM error along with the air bag error. I turned off the ignition and started again. PSM error and air bag error occurred again. I drove for a while and switched the PSM switch on and off. The PSM error went away and hasn't returned.
    I've driven the car for about 30 minutes and the air bag light is still on.
    Ideas?
    2006 Cayman S
  1. 04-15-2011, 10:56 PM
  1. Battery short after battery change
    By trendy996 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 09-26-2013, 01:31 PM
  2. Radio dead after battery change
    By will3hawks in forum 987 Cayman and Boxster Electronics
    Last Post: 04-05-2013, 05:33 PM
  3. Airbag light stays on after battery died and was replaced
    By caymansboy in forum 987 Cayman and Boxster Service and Tech
    Last Post: 02-12-2010, 06:24 PM
  4. Airbag light and seat position
    By jonathan in forum 987 Cayman and Boxster Chat
    Last Post: 10-25-2006, 01:39 PM
  5. airbag light if you recline seats too much
    By craignyc in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 05-28-2006, 11:43 AM
