09-20-2011, 10:18 AM
|  | Porsche Enthusiast | | Join Date: Jul 2011 Location: Kuala lumpur, Malaysia
Country: | | | Cayman S owner in Malaysia! Hi all owners of CS in malaysia, pls check in...
Rex- CS black, KL |
09-20-2011, 08:51 PM
|  | Porsche Chatter | | Join Date: Jul 2011 Location: KL
Country: | | | Re: Cayman S owner in Malaysia! Rex- CS black, KL
Barb-CS grey, KL |
09-23-2011, 02:09 AM
| | Porsche Chatter | | Join Date: Aug 2011 Location: Selangor
Country: | | | Re: Cayman S owner in Malaysia! Rex - CS black, KL
Barb - CS grey, KL
Nicholas - CS Black, SL |
09-23-2011, 05:16 AM
Originally Posted by nicholas Rex - CS black, KL
Barb - CS grey, KL
Nicholas - CS Black, SL | Bro, what ur contact number? Where is SL? Lol! |
09-28-2011, 07:58 AM
Country: | | | Re: Cayman S owner in Malaysia! Whole Malaysia only 3 CS? Lol! |
09-29-2011, 12:23 AM
Country: | | | Re: Cayman S owner in Malaysia! nay... they are not in this forum... saw a few around... kota damansara area has quite a number of caymans as well..... |
10-02-2011, 08:38 AM
Country: | | | Re: Cayman S owner in Malaysia! Got other forum? |
10-05-2011, 08:21 PM
| | Porsche Chatter | | Join Date: May 2010 Location: Puchong, Selangor
Barb - CS grey, KL
primus2211 - CS Black, Puchong |
10-06-2011, 10:02 AM
Country: | | | Re: Cayman S owner in Malaysia! sorry guys, been busy for a while.
im SL mean Selangor bro ! huhu~
guys, gt any pic of your guys ride? |
10-18-2011, 10:26 AM
| | Porsche Chatter | | Join Date: Apr 2011 Location: Malaysia/Sg
Country: | | | Re: Cayman S owner in Malaysia! 1 more grey CS, location Bangsar. Free can go yumcha :P |
10-18-2011, 09:05 PM
Country: | | | Re: Cayman S owner in Malaysia! hey Taiming.... I'm at Seputeh..... pretty near each other.... |
10-21-2011, 01:51 PM
Country: | | | Re: Cayman S owner in Malaysia! Awesome, should organise a teh tarik session one day and then maybe a short drive somewhere. I'm reachable at taiming86@gmail.com. Cheers |
10-30-2011, 09:11 AM
Country: | | | Re: Cayman S owner in Malaysia! Yea... Let's meet up... After barb wedding dinner at nov 5 . Then let's go genting perhaps.... |
10-30-2011, 09:13 AM
Originally Posted by primus2211 Rex - CS black, KL
Barb - CS grey, KL
primus2211 - CS Black, Puchong | Taiming pls reported in! |
10-30-2011, 10:10 PM
Country: | | | Re: Cayman S owner in Malaysia! taiming86 - CS grey, Bangsar |
10-30-2011, 11:27 PM
Country: | | | Re: Cayman S owner in Malaysia! yay.... finally another grey... |
10-31-2011, 06:08 AM
Country: | | | Re: Cayman S owner in Malaysia! Total 3 blacks n 2 greys at the moment... We need more.... |
10-31-2011, 10:20 AM
Country: | | | Re: Cayman S owner in Malaysia! neighbour has a white PDK CS and my buddy drives a dark blue TechArt CS too....  |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
Derived from motorsport, PDK, available for the 911 Turbo for the first time, achieves one thing above all else: it provides the perfect balance between uncompromisingly dynamic performance and exceptional levels of comfort. It’s purely about point of view. The driver’s especially.
The optional PDK with both manual and automatic modes enables extremely fast gear changes with no interruption in the power flow. For improved acceleration and significantly lower fuel consumption – without having to dispense with the advantages of an automatic.
The driver experiences a sportier, even more dynamic drive with more agility. Depending on driving style, gear changes range from exceptionally comfortable to exceptionally sporty.
Manual gear changes are performed using the PDK’s ergonomically designed gear lever or the switches on the steering wheel: nudge forwards to change up, pull back to change down. The logic behind the optional three-spoke sports steering wheel with gearshift paddles comes from motorsport: pull to the right to shift up, pull to the left to shift down.
PDK has been specially tuned to the characteristics of the new 911 Turbo models. It has seven gears at its disposal. Gears 1 to 6 have a sports ratio, with the top speed being reached in 6th gear. The 7th gear has a long ratio and helps to reduce fuel consumption even further.
PDK is essentially two half-gearboxes in one and thus requires two clutches – designed as a double wet clutch transmission.
This double clutch provides an alternating, non positive connection between the two half-gearboxes and the engine by means of two separate input shafts (input shaft 1 is nested inside the hollowed-out input shaft 2).
The flow of power from the engine is only ever transmitted through one half-gearbox and one clutch at a time, while the next gear is preselected in the second half-gearbox. During a gear change, therefore, a conventional shift no longer takes place. Instead, one clutch simply opens and the other closes at the same time. Gear changes can therefore take place within milliseconds.
Clutch 1 controls the first half-gearbox, which contains the odd gears (1, 3, 5, 7) and reverse. Clutch 2 controls the second, which contains the even gears (2, 4, 6).
The optional Sport Chrono Package Turbo with dynamic engine mount system provides PDK with two additional functions, ‘Launch Control’ and ‘motorsport-derived gearshift strategy’.
PDK – sporty, comfortable and efficient. Characteristics that have been given some thought elsewhere too: in the specification for the new 911 Turbo models. | |  |  |  |  | |
11-01-2011, 06:38 AM
|  | Porsche Enthusiast | | Join Date: Nov 2008 Location: Houston
Country: | | | Re: Cayman S owner in Malaysia! Zedcat in KL
2009 Cayman 2.9, Midnight blue/ Sand beige, 6 Speed+short shift, SC, PASM, 18in Cayman SIIs  |  |  |  | | PASM - Porsche Active Suspension Management |  | This active damping system offers continuous adjustment of individual damping forces based on current road conditions and driving style.
Need more information about PASM? Click this link: FAQ for PASM | |  |  |  |  | |
11-03-2011, 03:59 AM
Country: | | | Re: Cayman S owner in Malaysia! We need more members. Pls all reported in in the forum. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
