LinkBack (258) Thread Tools Display Modes
  251 links from elsewhere to this Post. Click to view. #1
Old 04-25-2009, 11:42 AM
rocket's Avatar
Images: 20
Maybe DFI is not a good buy
These pics are from a 2008 Porsche cayenne turbo (DFI engine). Apparently this is a very common issue. Also showing up on a lot of Audi DI engines.
Old 04-25-2009, 11:51 AM
Re: Maybe DFI is not a good buy
Wow! Can you explain further? This looks like some very poor combustion...
Old 04-25-2009, 12:01 PM
jaica's Avatar
Ouch! Looks like a very expensive and recurring expense, even if at first it is covered by waranty.
Having fun in Puerto Rico
Old 04-25-2009, 12:11 PM
gtscayman's Avatar
Motorhead
Images: 2
Put some Shell nitrogen enhanced gasoline in there and it'll clean right up!
GT Silver CS
1980 Honda CBX
2004 Suzuki SV1000
2006 Subaru Legacy
2002 Honda Insight
Old 04-25-2009, 12:16 PM
Tomasz's Avatar
Images: 36
Yes, this has been discussed before. This is mostly a US problem as well. Seems that in order to achieve US emission standards our cars run rich. I do not understand why, beyond what I heard and posted here. Also, on non DFI engines the injection of gas appears to clan the valves, while on DFI it does not. Again, someone more technical could explain further. For these two reasons, DFI engines in US are having major carbon build up issues. It is likely that Softronic or similiar flash will help with the issue by properly leaning out the mixture. I am not sure if it will be a 100% fix.
It would be wise, to wait two or three years before buying a Porsche DFI car. But not all are that patient.
Tomasz
Old 04-25-2009, 12:42 PM
echoboy's Avatar
Member of West Coast Group
Images: 3
That looks simply FUGLY! whew, thank goodness I didn't wait to buy a DFI (i realize that these pix do not constitute direct evidence, but I'm trying to make myself better )
Old 04-25-2009, 12:50 PM
According to Porsche, this is not a defect at all. They will be announcing a new "feature" that happens to address this issue in the 2011 models. This is a part of the car design, like the trunk clunk, engine smoke and others.
Old 04-25-2009, 12:59 PM
Bronze Sponsor
You've GOT to wonder - aren't these things TESTED prior to introduction???? Jeepers...
Craig
Old 04-25-2009, 01:05 PM
USA and other cars run lean. Stoichometric mixture is 14.7:1 (or thereabouts)....
and this is the ideal mixture of air:fuel for a properly functioning converter to most fully process exhaust gases into something less harmful.
Just a bit either side of this ratio and converter efficiency goes down and emissions go up.
The engine controller is basically tasked with ensuring the engine receives this 14.7:1 air:fuel ratio in order to keep emissions below some unacceptable threshold.
Under some circumstances the engine controller can venture outside of this 14.7:1 ratio such as in cold starts or under heavy acceleration (or under closed throttle deacceleration).
14.7:1 is good for the converters but bad for the engine, well bad in that a gasoline engine develops more power with a slighly richer mixture.
Direct injection engines attempt to deliver a richer mixture of air:fuel to the combustion chamber but in a small cloud centered around the spark plug.
Away from the cloud there is an excess of air and a dearth of gasoline.
The "rich" cloud delivers better utilization of gasoline and more power, while the air outside of this could provides excess air (oxygen) to the converters. The converters need oxygen to use to process (through chemical reactions) the more harmful exhaust gases into less harmful exhaust gases.
One particularly bad gas is Nox. Nitrogen oxide. If forms in the high temperatures of combustion. To keep this temp down engines are designed to under some operating conditions to allow some mixing of exhaust gases with the fresh incoming charge. Intake and exhaust valve overlap is one such way.
A side effect is some of the cloud and some exhaust gases can flow back into the intake ports and leave deposits on the intake valves. Since fuel injectors are no longer spraying fuel on these surfaces there's nothing to wash these deposits off.
The intake sides of the intake valves are crucial to the proper flow and swirling of incoming air to form the pre-cloud around the spark plug/fuel injector into which fuel will be injected.
Deposits on these intake valve surfaces will affect the proper formation of this cloud and in fact likely lead to even more deposits as the cloud ventures outside of its intended area of existence.
The problem is exacrebated by mainly the way we in USA drive our vehicles. Lots of idling and low rpm useage. Most engines spend their time operating at 30% of throttle or less and under these conditions it is more likely air flow in the combustion chamber will be backwards and purposely so. Over time build up will occur.
Couple of things you can do to help engine:
1) Do not overfill engine with oil. Overfilling causes more oil vapor to get into the crankcase air and more oil vapor to remain in the air that passes through the oil recovery system designed to remove oil from this air on its way to the intake system and combustion chambers. This oil vapor in the air from the crankcase being routed to the intake and combustion chambers contributes to the build up of deposits on the valves.
2) Keep engine oil fresh. Old oil will accumulate water and unburned gas over time and this makes oil more fluid and this results in more oil foaming and more oil foaming results in more oil vapor in crankcause fumes. More oil in these fumes means more oil vapor routed to engine intake and more deposits.
3) Avoid long periods of idling.
3) Use higher engine rpms. Granted this one's tough cause we are all seeking to use lower engine rpms to mainly save fuel. One doesn't have to run engine to redline every shift but any bit of extra engine rpms helps.
Sort of related: A problem developed with VW's diesel engines. VW used exhaust gas recirculation to feed exhaust gases into the intake to essentially pollute the incoming air and lower its oxygen content and thus lower combustion chamber temperature and Nox creation.
The problem was 1) This (diesel) exhaust gas contained soot; 2) This soot mixed with crankcase fumes that contained some oil vapor and the soot and oil combined to in some cases form a hard layer of carbon (soot/oil) in the intake passages that in some cases limit intake air flow into the engine to the point the car would barely run.
The fix was an intake cleaning. That was not covered under warranty.
The solution was to run a good quality diesel engine oil. Change it frequently. Avoid overfilling the engine with oil.
And contrary to what many buyers felt was proper for the engine, to use more rpms, not fewer. Those that attempted to drive the car like a big rig and short shift and keep rpms low, below 2000 and even lower in some cases would find the engine coked up in sometimes 30,000 miles or even less.
OTOH those that followed the above solution -- of which I was one -- found upon inspection while the intake manifold passages had a layer of oil there was no build up and the intake passages were quite open. I drove my VW TDi for over 120,000 miles and never had a problem. Based on the way the woman I sold it too was driving it -- shifting at just 1500 rpms -- I expect it coked up on her pretty quick.
Anyhow, back to Porsche. I have heard rumors -- just rumors --the solution for DFI engines that develop this build up and it will not go away on its own -- is to develop an intake system cleaning process that consists of fitting a temporary tank of cleaning fluid to the engine's intake system and as the engine runs (at idle, or at some higher speed I do not know) feed this fluid into the intake system.
The fluid removes deposits upstream from the combustion chamber and of course in the chamber and beyond. An oil/filter change will almost certainly be required after this cleaning process.
My advice would be to attempt to use the vehicle/drive the vehicle in such a way as to avoid the build up. As I did with my VW. And in doing so I found engine fuel economy didn't suffer. Over 120,000+ miles of driving that engine delivered a reliable/consistent 40+ mpgs in all kinds of driving, from slogging through stop/go driving, to high speed highway runs in all sorts of weather.
These DFI engines I think will deliver better fuel economy even if driven in this manner and this will help to keep the intakes clear of deposits. Any deposits will almost certainly affect fuel economy so nothing's lost by being a bit more "agressive" with the engine's rpms. And much is to be gained. If (when) engine deposits accumulate fuel economy will go down and the symptom worsen.
Sincerely,
Rockster.
Old 04-25-2009, 01:44 PM
echoboy's Avatar
Images: 3
Re: USA and other cars run lean. Stoichometric mixture is 14.7:1 (or thereabouts)....
Rockster, nice summary! thanks
Old 04-25-2009, 02:33 PM
madcow's Avatar
Images: 6
Crappy us gas.
Old 04-25-2009, 02:38 PM
rocket's Avatar
Images: 20
Originally Posted by echoboy View Post
rockster, nice summary! Thanks
+1 .
Old 04-25-2009, 08:13 PM
Agree with most of your points but I work on VW and your comments are not 100% of the story. Not everything you learned fully translates to gas DFI and not for the same reasons. Some do. Many feel DFI engine buildup is a combination of poor quality fuel, too much idling, and PVC oil mist. My comments in bold.
Originally Posted by Rockster View Post
Sort of related: A problem developed with VW's diesel engines. VW used exhaust gas recirculation....
Many cars use EGR, it's not unique to VW diesels and not totally the fault of the engine.
The problem was 1) This (diesel) exhaust gas contained soot; 2) This soot mixed with crankcase fumes....
They also have tons of piston blowby from high compression and cold starts. The oil mist is so heavy that people find a significant amount of oil pooled at the low spots of the intake tract. There is no oil seperator / trap to let the oil pool back into the crankcase. The other cause is fuel quality. The new cleaner diesel fuel sold in the US greatly reduces this problem. Biodiesel users say that there's almost no soot buildup in the intake.
This is probably the most relevent but it's not just rpm, it's also higher exhaust gas temps that clean out the soot and buildup. Diesels run cooler so higher EGT help burn up and blow out engine buildup. Adding to the problem-modern VW diesels have very high EGR to meet emissions - it can be as much as 30% of the intake air at idle since diesels run super lean. Higher RPM/load reduces EGR in that car.
My best guess is that high rpm and load could help burn up sooty deposits in gas DFI as well. I'm sure 95% of drivers don't run hard onto the highway on ramp and only rev through the full engine rpm once or twice. I've heard US gasoline doesn't help DFI buildup but not sure on this one.
Seafoam is great for cleaning up engine deposits.
Audi DFI use an oil cyclone seperator to get as much oil out of the PVC system but it's not 100% effective and many believe it's a contributing factor to DFI related valve buildup. Any PVC breather to the open air is not emissions legal and an oil dump tube to the ground will probably wipe out a few bikers
Old 04-25-2009, 10:11 PM
First, my TDi was an '02. Newer models may be improved. IIRC the complaint....
was that VW didn't have any means to filter out soot and the air/oil separator for the TDi was junk. Diesels of course suffer huge amount of blowby and the TDi being turbo-charged only added to this. Oil would soot up, darken to black, in just a few hundred miles of running. My '02 Boxster would keep its oil looking just like it did when it came out of the bottle for far longer.
Anyhow, running a better grade of gas might help curb DFI deposits on the intake valves. The gas cleaning benefits severely limited by the fact it is no longer sprayed against the valve surfaces but has to get there if it gets there at all by being carried back into the valve area where it hopefully will help remove deposits. 'course, if one uses a lousy grade of gas this will cause the deposits to increase.
Of course since many believe gas is gas many will continue to use the lowest quality of gas. Gas is a vital fluid too just like oil or coolant yet many dismiss it as something less vital and expect/assume the engine will be just fine burning any old thing. (Sort of reminds me of a steam train group that used to collect old engine/lube and cutting oil to burn in the steam train's boiler.)
Porsche has a similar cyclone air/oil separator/defoamer mounted down low in the sump. Oil from the scavange pumps is directed to these cyclones and swirls around with no little violence. Fluid goes low and exits air goes up and exits into the crankcase proper. Still carrying alot of oil in vapor form though.
Here's a pic of one of two in a 996 engine:
The crankcase ventilation system of course keeps the fumes from building up and works to keep pressures lower in the crankcase. This helps lower boiling point of the more volatile liquids in the oil so they boil off and of course their fumes routed to the intake manifold.
The old style crankcase breather tube (draft tube) routed down under the car is terrible. This is one reason why sludge was a problem with older engines. This poor excuse for a crankcase ventilation system allowed water and gas to build up in the oil. Low detergent oil didn't help either. It had to be low detergent cause oil companies hadn't figured out how to produce high detergent oil that didn't entrain a huge amount of air. Even today this is still a problem for some engines that have insufficient means to remove air from oil. In some case at high rpm this oil with air gets into the valve lifters and they soften and valve action becomes poor and high rpm horse power suffers.
Anyhow, engine designers of these DFI engines are going to have to come up with much better designs to remove more oil vapor from the crankcase fumes before these fumes are routed to the intake to be burned.
Or DFI engines will get a bad rap for loading up with deposits that really will impact the critical air flow into the combustion chambers DFI counts on so much to deliver the benefits it delivers when it all works right.
Sincerely,
Rockster.
Old 04-25-2009, 10:39 PM
Krokodil's Avatar
PCA / POC Member & Club Donor
Images: 104
Re: First, my TDi was an '02. Newer models may be improved. IIRC the complaint....
Unfortunately the m97.21 engines do not have the cyclone separators that were installed in the m96 engines. Here a link to a single post and pictures describing the differences: http://www.planetporsche.net/345063-post202.html
Cheers,
www.caymanspec.com
Old 04-25-2009, 11:36 PM
graphix25's Avatar
Like I needed any more reasons to hit red line at least a couple of times a day.
Old 04-26-2009, 07:26 AM
Images: 1
Sincerely,
Rockster.
Ordering a 2101 CS in June for September delivery. If this were you would this DFI issue stop you from ordering?
Old 04-26-2009, 07:29 AM
echoboy's Avatar
Images: 3
my take is that this is pretty new technology: could be worthwhile to see how things turn out with the DFI's that are already in the Cayennes and 911's. the gunk in the pix makes me wonder how ever passed Porsche's quality control?
Old 04-26-2009, 07:30 AM
Images: 1
So would you still order a 2010 CS knowing this ?
  #20
Old 04-26-2009, 07:55 AM
zedcat's Avatar
If you're really worried about it you could consider the 2.9L engine in the base Cayman. It is the new 9A1 design but with conventional FI.
LinkBack to this Thread: http://www.planet-9.com/cayman-boxster-chat/32256-maybe-dfi-not-good-buy.html
Posted By For Type Date
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback Today 06:24 AM
The Audi TT Forum • View topic - Forge Oil Catch Can This thread Refback 03-06-2010 06:47 AM
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback 02-16-2010 11:05 PM
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback 01-12-2010 01:43 PM
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback 01-11-2010 07:28 PM
The Audi TT Forum • View topic - Forge Oil Catch Can This thread Refback 01-11-2010 05:24 PM
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback 01-10-2010 03:00 PM
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback 01-10-2010 10:04 AM
The Audi TT Forum • View topic - -carbon buildup problem with TFSI - serious worry This thread Refback 01-10-2010 09:40 AM
Porkers.co.uk ::: Porsche Forum This thread Refback 12-24-2009 02:19 PM
Colour for the RS - Page 18 - Tyresmoke Forums This thread Refback 12-22-2009 03:52 PM
The Audi TT Forum • View topic - Forge Oil Catch Can This thread Refback 12-16-2009 05:23 AM
The Audi TT Forum • View topic - Forge Oil Catch Can This thread Refback 12-08-2009 07:39 PM
Gen 2 Turbo does 0-60 This thread Refback 12-05-2009 07:39 AM
Gen 2 Turbo does 0-60 This thread Refback 12-05-2009 01:00 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:07 PM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 12:40 PM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 12:08 PM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 09:12 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 08:48 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 08:47 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 08:36 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 07:32 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 07:23 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 05:56 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 05:51 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 05:44 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 05:09 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:37 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:28 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:19 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:17 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:12 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:10 AM
Gen 2 Turbo does 0-60 This thread Refback 12-04-2009 04:06 AM
The Audi TT Forum • View topic - Forge Oil Catch Can This thread Refback 11-20-2009 03:35 AM
Driving style? - AudiWorld Forums This thread Refback 11-17-2009 08:34 AM
Audi = carbon buildup?!? - 6speedonline.com Forums This thread Refback 11-08-2009 04:44 PM
The Audi TT Forum • View topic - Forge Oil Catch Can This thread Refback 11-08-2009 12:13 AM
Lost horses found - Octane.ie Forums This thread Refback 11-02-2009 07:40 AM
Lost horses found - Octane.ie Forums This thread Refback 11-02-2009 06:18 AM
Heads up Carbon on Porky DI engines This thread Refback 10-17-2009 01:19 PM
Heads up Carbon on Porky DI engines This thread Refback 10-17-2009 05:06 AM
Heads up Carbon on Porky DI engines This thread Refback 10-17-2009 04:54 AM
Heads up Carbon on Porky DI engines This thread Refback 10-17-2009 03:23 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 12:50 PM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 12:38 PM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 11:58 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 11:54 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 10:20 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 10:17 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 10:14 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 10:11 AM
Heads up Carbon on Porky DI engines This thread Refback 10-16-2009 03:28 AM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 05:55 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 02:32 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 02:19 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 01:49 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 01:13 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 01:12 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 01:07 PM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 11:37 AM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 11:19 AM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 09:56 AM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 07:14 AM
Heads up Carbon on Porky DI engines This thread Refback 10-15-2009 01:55 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 05:22 PM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 05:04 PM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 04:51 PM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 04:19 PM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 03:39 PM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 03:27 PM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 11:31 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 10:18 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 09:39 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 09:03 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 08:22 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 08:17 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 08:09 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 07:43 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 06:54 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 05:30 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 05:05 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 04:43 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 04:10 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 04:04 AM
Heads up Carbon on Porky DI engines This thread Refback 10-14-2009 03:58 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 06:07 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 03:43 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:54 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:45 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:44 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:35 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:31 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:21 PM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 07:11 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 06:39 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 06:36 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 05:58 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 05:49 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 05:40 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 05:31 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 04:57 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 04:05 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 03:19 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:48 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:44 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 02:38 AM
Heads up Carbon on Porky DI engines This thread Refback 10-13-2009 01:10 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 09:36 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:59 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:57 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:24 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:21 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 10-12-2009 06:09 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:17 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:56 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:55 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:54 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:46 PM
Porkers.co.uk ::: Porsche Forum This thread Refback 10-12-2009 04:35 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:32 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:28 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:24 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:07 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:04 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 03:50 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 03:38 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 03:01 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:35 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:32 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:22 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:17 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:15 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:14 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 02:04 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 01:40 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 01:39 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 01:03 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 12:43 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 12:38 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 12:37 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 12:23 PM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 11:56 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 11:38 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 11:30 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:43 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:37 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:28 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:26 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:18 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:14 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:13 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:11 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:04 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 10:02 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 09:43 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 08:32 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 08:24 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 08:21 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 08:20 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 08:05 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 08:03 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:43 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:36 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:27 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:18 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:15 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:14 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:11 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:03 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 07:01 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:59 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:55 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:54 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:53 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:52 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:50 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:45 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:37 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:36 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:35 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:34 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:30 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:25 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:22 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:15 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:13 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:12 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:11 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:10 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:09 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 06:03 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:52 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:51 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:49 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:47 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:45 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:40 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:22 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:13 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:09 AM
Porkers.co.uk ::: Porsche Forum This thread Refback 10-12-2009 05:01 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 05:01 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:57 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:55 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:53 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:50 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:47 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:46 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:45 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:44 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:41 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:40 AM
Heads up Carbon on Porky DI engines This thread Refback 10-12-2009 04:38 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 09-11-2009 07:09 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 08-31-2009 06:44 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 08-29-2009 09:41 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 08-26-2009 05:17 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 08-06-2009 10:22 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 07-19-2009 04:23 PM
CC'ers march lockstep into the arms of BMW - Page 97 - Corner-Carvers Forums This thread Refback 07-13-2009 12:15 AM
CC'ers march lockstep into the arms of BMW - Page 97 - Corner-Carvers Forums This thread Refback 07-10-2009 11:20 AM
MTM's kit for the 2010 S4 - MY350Z.COM Forums This thread Refback 07-06-2009 11:45 PM
CC'ers march lockstep into the arms of BMW - Page 97 - Corner-Carvers Forums This thread Refback 07-01-2009 08:41 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-23-2009 12:38 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-18-2009 07:15 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-18-2009 01:11 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-16-2009 11:05 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-14-2009 01:20 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-13-2009 07:06 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-13-2009 12:09 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-12-2009 02:36 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-12-2009 02:33 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-12-2009 12:34 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 11:26 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 11:13 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 06:28 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 02:40 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 02:00 PM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 11:02 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 10:57 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 10:53 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 10:40 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 10:30 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 10:23 AM
Even the mighty Porsche DI succumbs to deposits - Bob Is The Oil Guy This thread Refback 06-10-2009 10:07 AM
carbon buildup on intake valve This thread Refback 05-20-2009 09:25 PM
carbon buildup on intake valve This thread Refback 05-20-2009 11:51 AM
How to Change Brake Pads Porsche Cayenne on Kosmix This thread Refback 05-07-2009 10:26 AM
