06-14-2009, 02:19 PM
Sheer perfection!!
Greetings to everyone from hot Greece!
My first post is with my CaymanS resting at the garage ;-)
Lurking at the forum for 2 years.
Took delivery 3 weeks ago.
Done 2000km(1250 miles ).
Can't wait for the break-in period to end!
I had a tough time deciding between my car and a facelifted CS, but after some soulsearching, found out that the dillema was actually PDK vs manual.
When the manual gearbox won the battle (25 extra ponnies and DFI didn't do it for me  ), this beauty came into my possesion:
--PENDING PHOTOS---
Midnight blue
Sand beige leather seats
PASM
SportChrono
PCM
Xenons
Auto climate control
Park Assist
Couldn't be happier!
Love the handling, love the suspension, love the smell (  ) and absolutely love THE SOUND!!
I believe that this car is a keeper  !!
DFI
2005-2009 Mazda Rx-8
2009-(...) Porsche Cayman S
2009-(...) Audi Q5
06-14-2009, 02:49 PM
Re: Sheer perfection!!
Welcome. Please post some pictures, sweet list of options.
May I suggest you really study the owner's manual. I am still learning things about my CS now a year later.
Drive safe and enjoy. Ed
06-14-2009, 03:09 PM
Super Moderator
Congrats on your new car!
I think you may have some kind of record for lurking as a member, before your first post.
06-14-2009, 03:16 PM
Congrats!!!
Mine should arrive here tomorrow or tuesday (can't fooking wait  ), but i'll have to wait a week or too to actually drive it because i still have to legalize it  (used car bought in Germany)
But at least i won't have to wait for break in period
06-14-2009, 05:32 PM
Member of Southern Group
congrats και καλωσορίζουμε στο κλαμπ (Thank you google translator)
Cayman 2007
Boxster 2005
Boxster 2001
06-15-2009, 02:07 PM
Thanks!
@Ed Merry: Pics on the way!
@ KS-CS: It was worth the wait!
@Cayman-S: It'll put a smile on your face!
@greycroc: ΕΥΧΑΡΙΣΤΩ.
2009-(...) Audi Q5
06-15-2009, 03:10 PM
συγχαρητηρια....εχω το ιδιο σε ασπρο!!!!! χεχεχε! χωρις pasm βεβαια... αλλα θα ερθουν αλλα παιχνιδια στο δικο μ πορκι...που θα το τσαντισουν λιγακι! χαχααχ
06-15-2009, 03:35 PM
congrats and welcome!!!!!!!!!!!
i am sensing a get together soon!!!!!!!!!! weekday night!!
we should be able to accumulate around 3000 stuttgart horses for a night drive around Athens
06-15-2009, 04:27 PM
I'm an excellent driver ....
congrats and enjoy!!!
06-22-2009, 10:56 AM
2009-(...) Audi Q5
06-22-2009, 11:40 AM
Great pics JpoL
He looks so shinny
06-22-2009, 11:47 AM
@schwabe --> Thanks!!
@ Cayman-S --> Thank you, it was after the bath!!
@ Rocky-Numb -> Thanks παίδες, ready for night rides!
2009-(...) Audi Q5
06-22-2009, 11:59 AM
I believe this looked better in english.
Your translator must have been  !!
2009-(...) Audi Q5
06-22-2009, 12:22 PM
Congratulations on a great car! I have seen this exact car you bought at Sportscar in Glyfada (at least I believe that's the one), they had at the back of the showroom. It's a real beauty. One of these days we have to get together again - there's 6 or 7 of us in Athens and we occasionally get together for laughs.
Have fun with it and drive it like you stole it
06-23-2009, 08:22 AM
Thanx acg!
PS. 7 crocs is a nice company!!
2009-(...) Audi Q5
06-24-2009, 06:08 AM
Originally Posted by Wan Kher
Το ορυχείο είναι κόκκινο όπως τα χείλια κόλπων της γυναίκας!
That was disturbing, incorrect, and worrying all at once. Thankfully not many of us can read Greek.
06-25-2009, 02:08 PM
there is always the google translator...
06-25-2009, 02:50 PM
'Yellow Peril'
Yahoo BabelFish.............
"The mine is red as the lips trick of woman!"
Apparently?
Cheers Karel
06-25-2009, 11:56 PM
καλοριζικο και απο εμας τους boxster owners !!!!
drive safely and enjoy a true car as porsche is.......
06-26-2009, 03:17 AM
Apparently?
More like
"the mine (that's the digging mine, not the possessive) is red as the lips of gulfs (or vaginas or 'of tricks') of woman."
I'm choosing the "gulfs" translation as the tense of "vaginas" is an abnormal use of the word, it's almost never used in plural for obvious reason. The "of tricks" is also nonsensical.
I'm a lot more disturbed that someone would liken his car to a labia, but I'd rather we left it there.
LinkBack to this Thread: http://www.planet-9.com/cayman-boxster-chat/33613-sheer-perfection.html
| Posted By |
For |
Type |
Date |
| S Model Sheer perfection!! - |
This thread |
Refback |
11-16-2009 12:26 PM |
