06-21-2009, 06:39 PM
Cayman Clunk
After two years of dreaming, we're going to purchase a Cayman. I was curious if the "clunk" in the trunk has finally been cured with the introduction of generation 2 in the 2009 models?
06-21-2009, 06:45 PM
Re: Cayman Clunk
Apparently not... but this might not be classic "clunk."
http://www.planetporsche.net/cayman-...y-gen-2-a.html
06-21-2009, 07:30 PM
Re: Cayman Clunk
My information is that it's still a bit of a problem. There's a fix on the forum and at Porsche. Neither are perfect. Both help. I don't have a new one. Hope someone here with a Gen II can comment.
I just did a 400 mile trip with my somewhat fussy wife in my '06 w/19s and PASM. I did the Cayman Club clunk fix and tightened up the rear hatch lock, which had come loose on one side. It's pretty good now. You have to hit something just right with the right rear wheel to get a clunk.
It's a lot better than before. Also the subwoofer stuffing thing is great for the Bose. We listened for most of the trip.
-TB
06-21-2009, 10:11 PM
Insider
Re: Cayman Clunk
So far 2700 mi on my 2009 CS, no "clunk" heard. Slight noise from the luggage partition shifting/popping but rare, as is this option anyway. Mine is on stock 18" wheels, PASM. Even with PASM set in Sport mode, noise does not increase.
06-22-2009, 04:12 AM
Porsche-Driving Sushi-Eater
Re: Cayman Clunk
I get a little bit of a rattle in the upper hatch area, no "clunk". Something I've added to my 12k mile punchlist. Still haven't stuffed the Bose subwoofer - only have noticed maybe a couple really bass-heavy songs (out of a thousand) where you can barely hear the rest of the song.
"He who dies with the most toys is, nonetheless, still dead." — Unknown
06-22-2009, 03:28 PM
Re: Cayman Clunk
I tell you, it's a new and better world with that stuffing in there. It's surprisingly easy to do. (no affiliation with bose, the guy who wrote the original article or Pink Floyd, whose "Dark Side of the Moon" can now be listened to from beginning to end on the Bose.
-Six
