| Cayman and Boxster Chat General conversation about the Cayman and Boxster. | 7Likes -
1 Post By cbzzoom -
5 Post By sixisenuff -
1 Post By s knot  |
02-06-2012, 11:49 AM
|  | Porsche Chatter | | Join Date: Jan 2012 Location: Arizona
Country: | | | Information about the 09+ Cayman Reliability, Cost of Ownership, General Questions I will apologize in advance for asking this as i'm sure it's probably a question that comes up often, but i'd like to get some honest feedback on it
I have been looking more and more into purchasing a Cayman. Last week I had my first chance to take a Cayman 07 and an 11 PDk Cayman S out for a spin. Honestly i'm absolutely love struck by the cars. The way it feels to drive and the sounds are absolutely a one in a million feeling. That being said I have for a great while now been curious about just how cost efficient it is to own a Cayman.
I do understand that if you purchase an 09+ that IMS issues are non existent, and that RMS issues are not a problem? Is this correct? I've also heard that when migrating to the newer engine(not sure of it's name off the top of my head) that power steering leaks are no longer a problem and that virtually every previous problem on the previous model has been worked out. Is there any truth to this? I'm basically curious too if it would be reliable in the sense of owning a Japanese car or something with the an LS engine in it from Chevy. I will admit I probably can't pull 15k out of no where to fix an issue should the engine go, but a few thousand in repair may be manageable per year if absolutely needed.
I'd also like to know some figures on cost of ownership if anybody has them. The oil changes i'm not too worried about even at 200 bucks which is the highest i've heard on here it doesn't seem too horrible. I am a little curious on brakes and how much fluid changes run for the Cayman S models? If you get the PDK does it have to have a 40k Flush of the fluids similar to my VW? Also if anybody has experience what could I expect to pay for replacement rotors/pads at an indy shop? What do your maintenance cost per year usually come out to?
I have also heard about early 2000 boxsters eating up tires excessively often within 10k miles of purchase. Is the Cayman also like this?
Are the cars troublesome? I know with my current VW i've spent some time in the shop already 3 times for windows not sealing, Gas cap latch breaking and leaving me stuck in Texas, Rear trim cracking and needing replacement. Cupping issues with tires, Trans issues. Will the Cayman also be like this given that Porsche is now part of the VW family?
With these questions in mind i've basically worked out if I do purchase the car I should purchase it on the side as a weekend car and have something else to daily during the week. Is that what most others here do or do many of you daily your Cayman's?  |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
Derived from motorsport, PDK, available for the 911 Turbo for the first time, achieves one thing above all else: it provides the perfect balance between uncompromisingly dynamic performance and exceptional levels of comfort. It’s purely about point of view. The driver’s especially.
The optional PDK with both manual and automatic modes enables extremely fast gear changes with no interruption in the power flow. For improved acceleration and significantly lower fuel consumption – without having to dispense with the advantages of an automatic.
The driver experiences a sportier, even more dynamic drive with more agility. Depending on driving style, gear changes range from exceptionally comfortable to exceptionally sporty.
Manual gear changes are performed using the PDK’s ergonomically designed gear lever or the switches on the steering wheel: nudge forwards to change up, pull back to change down. The logic behind the optional three-spoke sports steering wheel with gearshift paddles comes from motorsport: pull to the right to shift up, pull to the left to shift down.
PDK has been specially tuned to the characteristics of the new 911 Turbo models. It has seven gears at its disposal. Gears 1 to 6 have a sports ratio, with the top speed being reached in 6th gear. The 7th gear has a long ratio and helps to reduce fuel consumption even further.
PDK is essentially two half-gearboxes in one and thus requires two clutches – designed as a double wet clutch transmission.
This double clutch provides an alternating, non positive connection between the two half-gearboxes and the engine by means of two separate input shafts (input shaft 1 is nested inside the hollowed-out input shaft 2).
The flow of power from the engine is only ever transmitted through one half-gearbox and one clutch at a time, while the next gear is preselected in the second half-gearbox. During a gear change, therefore, a conventional shift no longer takes place. Instead, one clutch simply opens and the other closes at the same time. Gear changes can therefore take place within milliseconds.
Clutch 1 controls the first half-gearbox, which contains the odd gears (1, 3, 5, 7) and reverse. Clutch 2 controls the second, which contains the even gears (2, 4, 6).
The optional Sport Chrono Package Turbo with dynamic engine mount system provides PDK with two additional functions, ‘Launch Control’ and ‘motorsport-derived gearshift strategy’.
PDK – sporty, comfortable and efficient. Characteristics that have been given some thought elsewhere too: in the specification for the new 911 Turbo models. | |  |  |  |  |
Reason: Grammar, Clarity, Simplicity.
02-06-2012, 01:56 PM
|  | Porsche Enthusiast | | Join Date: Mar 2010
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question
Originally Posted by MrRline2010 I do understand that if you purchase an 09+ that IMS issues are non existent, and that RMS issues are not a problem? | Basically yes. There may be HPFP issues but normally covered under warranty. |
| Hard to say yet with how young the DFI engines are, but I highly doubt they are anywhere near as reliable as a Japanese car or even a Chevy LS. |
| You should not buy a Porsche unless you can handle at least a few thousand a year in repairs. Hopefully it won't be that much, but it easily could be. |
| You can always have those things done at a generic shop if you are cost conscience. I find that even cheap indy Porsche mechanics are at least 2X the price of other mechanics. They generally charge around $100/hour , where a generic shop can be as low as $20. Brakes and fluids are also easy to DIY on Porsches. |
| A few hundred in labor; rotors are $300 a pair, pads are $100 a pair. |
| It depends how hard you drive, obviously, but you can easily run $1-2k just on tires and brakes (expendables). |
| Depends on your driving style; 10k is a bit quick but not unheard of. I corded my rear tires in 8k miles, but I have a lot of rear negative camber and drive very hard + some track time. |
| Yes, those types of issues do occur. It's got that "great German engineering" which means lots of things break and when they do they're very expensive
I've been spending around $3-4k a year on expendables + repairs. Little things like bad water pump, bad coil pack, bad shifter cable can all be very expensive because they're so hard to get to in the car that they take a lot of hours of labor or are hard to DIY.
Yes of course some people may chime in and say they haven't had any repair bills at all, but the point is you should not have any illusions about low cost of ownership, don't get into it if you can't afford the repairs IMO.  |  |  |  | | DFI |  | Direct Fuel Injection (DFI), is a new technology that Porsche states can cut fuel consumption by up to 15 percent, while increasing power by up to 13 percent. DFI cuts emissions by warming up the catalytic converter more quickly, and ensures a sharper throttle response. Better for your right foot - and the planet, then.
The direct injection process is continuously adjusted. The engine management system reads changes to throttle inputs and performance requirements and, as you drive, the air/fuel mix is monitored and adapted as required. Oxygen sensor circuits within the exhaust system provide accurate emissions control. | |  |  |  |  | |
02-06-2012, 02:42 PM
|  | Porsche Enthusiast | | Join Date: Sep 2010 Location: Bay Area
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question I have an '06 CS; it's my do-everything car.
For oil changes, I've paid ~$150 from an independent and well over double that at a dealer. For OEM brake pads it's something like $550 from that same independent (wear sensors are expensive!), plus another ~$150 for a flush. Can't speak to PDK or issues specific to the '09+ models, but this should be generally applicable
I've also spent about $2,000 on preventative maintenance since I bought the car, including replacing the water pump (leaking), serpentine belt, spark plugs and some power steering hoses/fittings (also leaking; should not be an issue on '09+ models from what I hear here).
My cost/yr is somewhat atypical because I put a ton of miles on my car between commuting 35 miles each way and tracking it on weekends. Add tires every 6-7 track days and frequent alignments and you begin to get the picture haha
Having said that, my car makes me happy just to see it and I wouldn't have it any other way
edit: My CS has never once stranded me or failed to start
edit 2: If you do track it, heaven forbid you hit a cone at 90mph because it will cost $500 to replace the flimsy plastic wheel well liner   |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
02-06-2012, 03:40 PM
|  | Porsche Activist | | Join Date: Sep 2007 Location: Houston, Texas
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question Don't let these high maintenance costs scare you.
My experience: Bought an '03 Boxster S 3/04 and sold it 6/08. Did my own oil changes for about $100 each, Air filter $25, new tires approx $1000 and a new battery $90. That was it, never had single problem. total mileage-25000
Bought an '08 Cayman S 7/08 and sold it 11/11. Ditto on the oil changes. Changed cabin filter $25, replaced battery under warranty, needed tires when I sold it. Never a problem. total mileage 17000.
Granted I don't put a lot of miles on my car but if you don't track it, your expenses can be quite reasonable.
Even though I never had a single problem, I would recommend you stick with the 09 plus vehicles to avoid the possibility of the IMS and RMS issues. Time will tell if these cars develop other issues. I have owned seven Porsches since 1982 and they all seem to have some minor unique problems. But what car doesn't. |
02-06-2012, 03:47 PM
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question Thank you all for the feedback thus far. I really appreciate cbz being so honest about the cost and the worst case scenarios. I know you can ask this question on a million forums and not get an answer with as much clarity as his. That being said I don't plan on throwing a ton of miles on this car hence the pos daily idea. This thing may see track time from time to time, but nothing more than a few events a year at max. A few days here and there will be fun enough for me. |
02-06-2012, 03:59 PM
|  | Porsche Spieler 2,000 post club | | Join Date: Apr 2009 Location: N. Illinois
Originally Posted by MrRline2010 I will apologize in advance for asking this as i'm sure it's probably a question that comes up often, but i'd like to get some honest feedback on it
With these questions in mind i've basically worked out if I do purchase the car I should purchase it on the side as a weekend car and have something else to daily during the week. Is that what most others here do or do many of you daily your Cayman's? | OK...Here's the thing. This car is as close to an exotic as you can get without buying an exotic. The parts cost a lot more. They are not designed to be cheap to keep. That said...
1. '09+ cars are very reliable and '06-'08 cars are also very reliable IF YOU DON"T TRACK THEM.
2. '06 to '08 Boxster/Caymans don't generally get IMS problems. Drive them with enough revs after warm up...always over 2,000 and make a point not to lug and to occasionally run them at over 3,000. A good indication of how they like to run is the high RPM at 70 or so mph. Most IMS problems with Gen1 cars are due to a crushing amount of very low RPMs in traffic and not changing the oil enough.
The '09+ engines don't have an intermediate shaft, so no intermediate shaft bearing problems are possible.
3. One of the big weaknesses of the Gen 1 is that the oil pump can start sucking air on long very hard turns...like at a track. So either don't do that or spend some money on upgrading that oil system so it won't suck air. The forum is full of that sort of information.
4. Japanese cars, as a group, generally don't last very long on race tracks. They aren't built for it and they don't reward fast driving...Most of the "reliable" ones are very happy at normal speeds and tend to go all soft and squishy when you push them a little. So, it's kind of apples and oranges.
5. With good maintenance, which is not, in my opinion, excessively expensive, a weekend or street driven car that doesn't spend most of its life in downtown traffic, will last a very long time. I've done several track events with my car. I have 55K miles on it. It has the original clutch, which works fine, the valves are hydraulic, so you don't have periodic adjustments to pay for. I drive it all winter in Chicago. I wash it at car washes. I use my winter mats all year long. I do oil changes before 10K miles. Sometimes way before if I've been to the track. I changed out the original brake pads and am on my second set but the rotors are still original.
I don't baby the car, but I use cruise on the interstates and I don't race. My track sessions consist of 20 minute sessions with maybe 3 really fast laps. I've changed my oiling system...bigger sump, extra pump, improved baffles in the oil pan. I've got a power steering cooler. I put on a different Air/oil separator from a GT3. These are not easy projects if you are not an experienced mechanic with a good collection of tools. You don't need them if you don't track the car hard. I have R tires, coil-overs, a roll bar, bigger anti-roll bars and increased negative camber....so I NEED this protection. I've also replaced my seats and have full harnesses for the car. It's not my first street/track car, so I knew what I was getting into...sort of. I would not classify these cars as easy to work on. I use a local tech for more than half of the modifications.
I change my own oil and do my own brake work. I have a real frame service lift in my garage. It's still expensive, but I'm nuts. If you just want to enjoy the car driving around...and that's a BIG part of the fun with them, you can spend a lot less than half the guys on this site.
I plan to drive my car for 200,000 or more miles. The construction of it seems very stout to me and I don't have little electrical gremlins or rattles that make me crazy. It's still a hoot to drive and looks amazing. I keep it in a heated/cooled garage out of the sun. I think that's important if you're keeping one a long time.
I'm not planning on having a rear main seal problem. Hope I don't but if I do, I'll just get it fixed and move on. I think the next Caymans are going to be the best. After that, they'll start taking power away from them and may go to 4 cylinder turbos. Even with more power, I can't see a turbo four having the same character as these cars. They are just so cool and still get what I would call reasonable economy.
If you can afford it, '09+ is the way to go, I'm convinced, but I've come this far, I'm going to stay with this one. Love all the Caymans but the early ones are best owned by people with a good shop and a checkbook or a will and the tools to do a lot of work themselves.
If you drive one normally, they'll give good service and long life.   |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
__________________ -Sixisenuff
'06CS;Arctic/BlkStdLea;PCM2.1Nav;SC+;Bose/stuffdsub,gtwy500,iPod;ClutchDlyFix;udPulley;psCoo ler+wintrcover;gt3VOS;sumpExt;TTPOilsafe;MDSGrills ;18"ChmpRg5w235/40+265/40MichPSS;18"Forgestar+245/40&275/40NT01;18"BoxsterSRims+Pir240Winters235/40&265/40;HeigoRllBar;SptBuckets;Schroth6pt;SoftrncPlenm& 4.1flsh;TchartTUVcatbck;gt3LCAs;gt3scoops;tpcSwayb ars(quietlnks);PCCBmasterCyl;PASM/Dmptrnics;PgdYel+StockPds;StockRtrs;Motul600;FOR SALE:1newRecaroProfiXLw/slidrs+mounts,19"CarreraS/Nitto555/F235/35&R275/35;CDC4chngr;ROTTec sCGTF Seats w/Cayman mnts. |
02-06-2012, 05:16 PM
Originally Posted by sixisenuff OK...Here's the thing. This car is as close to an exotic as you can get without buying an exotic. The parts cost a lot more. They are not designed to be cheap to keep. That said...
If you drive one normally, they'll give good service and long life.  | yeah I don't plan to go quite where you are with your car, but good to know that it can be moderately inexpensive to own as a weekend car. Honestly I am thinking I would like to keep this car for quite a while and maybe towards the end of it's life track it, but either way I can't see just getting rid of a Porsche unless you're getting another one. |
02-06-2012, 06:33 PM
Originally Posted by MrRline2010 yeah I don't plan to go quite where you are with your car, but good to know that it can be moderately inexpensive to own as a weekend car. Honestly I am thinking I would like to keep this car for quite a while and maybe towards the end of it's life track it, but either way I can't see just getting rid of a Porsche unless you're getting another one. | I think, for what you want to do, it's a great car because the look and feel of it is timeless. Great looking and great driving car made well. They can improve 911s, but the old ones will always be cool. I think the Cayman is a better deal than a 911 because it's better to drive. There are exceptions, but for a car that you can actually use and own and isn't over the top, it's hard to beat.
02-06-2012, 10:01 PM
|  | Porsche Chatter | | Join Date: Dec 2011 Location: california
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question If you put it into perspective I don't think you can find a better sports car for the money. Japanese cars get dated or old much faster from a styling / design perspective, I've owned an MR2, 2 NSXs, a BMW, and a MBZ and I've been in the car design business for over 20 years. My first car design project out of design school was designing the Corvette C5 and my partner was one of the key designers who designed the original Boxter, he had just left Porsche to work at GMs advanced design studio in CA and arrived there when I did. He later went on to head up Pininfarina and was credited with the Enzo Ferrari.
Porsche has the best brand going and their quality is tremendous considering the volume, performance, and price points for most of their models. IMO even BMW has struggled to maintain there brand. Audi, Cadillac, and Corvette have done OK but only as of late. Porsche simply rules when it comes to maintaining a their brand, delivering performance, and building quality cars over time. When I was ready to go back into a pure sports car this year I considered several vehicles but couldn't justify anything but a Cayman when I considered everything I was looking for. With any high performance vehicle you can expect to pay more for maintenance and parts, as much as 100% over typical DD cars. I haven't owned mine long enough to to provide you with good feedback regarding the true cost of ownership, but keeping it in perspective, you would be getting one of the top five best handling cars at any price point and it looks as stunning as it did when it debuted in 05, name another modern non Porsche car that can claim this. I've had my car for just a month now and put close to 2K on and it tuns heads and has people gawking or saying "that's one sick car bro". A bit off topic but my two cents....
02-07-2012, 05:51 AM
Originally Posted by s knot If you put it into perspective I don't think you can find a better sports car for the money. Japanese cars get dated or old much faster from a styling / design perspective, I've owned an MR2, 2 NSXs, a BMW, and a MBZ and I've been in the car design business for over 20 years. My first car design project out of design school was designing the Corvette C5 and my partner was one of the key designers who designed the original Boxter, he had just left Porsche to work at GMs advanced design studio in CA and arrived there when I did. He later went on to head up Pininfarina and was credited with the Enzo Ferrari.
Porsche has the best brand going and their quality is tremendous considering the volume, performance, and price points for most of their models. IMO even BMW has struggled to maintain there brand. Audi, Cadillac, and Corvette have done OK but only as of late. Porsche simply rules when it comes to maintaining a their brand, delivering performance, and building quality cars over time. When I was ready to go back into a pure sports car this year I considered several vehicles but couldn't justify anything but a Cayman when I considered everything I was looking for. With any high performance vehicle you can expect to pay more for maintenance and parts, as much as 100% over typical DD cars. I haven't owned mine long enough to to provide you with good feedback regarding the true cost of ownership, but keeping it in perspective, you would be getting one of the top five best handling cars at any price point and it looks as stunning as it did when it debuted in 05, name another modern non Porsche car that can claim this. I've had my car for just a month now and put close to 2K on and it tuns heads and has people gawking or saying "that's one sick car bro". A bit off topic but my two cents.... | I have to say, most of the money I've spent on my CS is because I wanted to, not because I had to. If you just want to drive the car and don't care about mods...and have A GARAGE, it's not expensive. I wouldn't have any car worth anything without a garage to keep it in. The UV if nothing else, really messes things up that are difficult to replace: rubber, plastic, vinyl pieces. Agree so much that the Cayman is a great choice for a pure sort of sports car that you want to keep for years. It just never gets old and makes me smile whenever I see it in my garage even if I won't be driving it that day.
02-07-2012, 07:55 AM
|  | Porsche Enthusiast | | Join Date: May 2006 Location: Texas
Originally Posted by sixisenuff I think, for what you want to do, it's a great car because the look and feel of it is timeless. . . | And that's the key. If 'timelessness' is important to you, you'll love a Gen. 2 Cayman.
__________________ Young Turk
2011 Cayman (Platinum Silver/Black) PDK, Bose, Ventilated seats, Heated seats, Bi-xenons, 18" Boxster S II wheels, Colored wheel crests, Porsche Crests on Headrests Previously owned:
2001 Boxster, 2005 997 Cpe, 2005 997 Cab |
02-07-2012, 10:47 AM
|  | Porsche Chatter | | Join Date: Nov 2011 Location: New York
Originally Posted by s knot My first car design project out of design school was designing the Corvette C5 and my partner was one of the key designers who designed the original Boxter, he had just left Porsche to work at GMs advanced design studio in CA and arrived there when I did. He later went on to head up Pininfarina and was credited with the Enzo Ferrari. | That's cool as hell man, I think the C5 was one of the best designs ever and it preceded my Cayman. Good job!
To the original poster...I haven't seen anybody comment on an extended warranty. I've only had my base 2008 since early November of 2011 so I can't really comment on maintenance with it so far but I did do my research like you. I seriously doubt you'd have to spend a few thousand on it a year unless, like said, you were tracking it and/or driving an extreme amount of miles. If it really bothered you, you could get an extended warranty for that few thousand and drive the piss out of it.
I do my own oil changes, filters and other easy tasks mentioned here so I'm not too worried but I will have to take it in for major service just to get them to check the comp and other points for the sake of the warranty. But at only 24k miles (major service is at 40k and 80k) I don't see costs adding up to the point of having to get rid of the car. And I drive HARD but correctly.
Having the gen 1 Cayman I've been nervous about tracking it but if its only going to be 2-3 times a year and I'm only putting around 7k mi/yr on it I figure all will be well. However, I do have a factory warranty on it still and I am planning to extend it for piece of mind.
I think you should go for it and drive it everyday. I had a pos DD and got rid of it because I couldn't deal with waking up and not driving the Cayman. I love this car. From what I've read, seen, and experienced so far these cars are made for it.
Point being, you should be even more secure with an 09+... |
02-08-2012, 10:17 AM
| | Porsche Chatter | | Join Date: Jun 2011 Location: TX
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question I've owned 3 different Porsches spanning over 10+ years of ownership, including the 2006 Cayman S I bought last year. While I only have a year under my belt on the Cayman, my Porsche maintenance experience has been good. Typically I'll go a year or two with minor maintenance costs (basically just oil changes), and then I'll have to sink in some money for bigger ticket items (tires, wheel bearings, brakes/rotors, etc.).
Overall, my running costs average out to $1-$2K per year, but I'll often have years where I only pay for oil changes. My average will obviously blow up if I ever have to pay for an engine failure though. |
02-08-2012, 08:58 PM
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question RBTX are you including things like tires brakes in your 1-2k a year cost or is that just in engine work and such? |
02-09-2012, 10:30 AM
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question Yep - it's in my post |
02-09-2012, 11:55 AM
| | Porsche Prophet | | Join Date: Aug 2009 Location: Texas
Country: | | | Re: Information about the 09+ Cayman Reliability, Cost of Ownership, General Question I have 16.5K miles on my 09 PDK daily driver (about 30 months since delivery). It has had two oil changes (dealer) at ~$150 each and one brake fluid flush (also about $150). I have changed the cabin filter myself once (about $20), replaced the rear tires at 11.5K miles (the fronts look to have about 50% tread left).
It has been in for warranty work four times. A reload of the PDK software (occasional " PDK emergency run" message), a dead battery after sitting for two weeks, the HPFP recall, and just recently for replacement of the seals on the ends of the tubing that connects the two intake manifold (right and left) distribution boxes.
Other than the warranty actions, not much different in maintenance cost than the G35 I had prior.  |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
PDK – sporty, comfortable and efficient. Characteristics that have been given some thought elsewhere too: in the specification for the new 911 Turbo models. | |  |  |  |  | |  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
