| Cayman and Boxster Comparisons This sub forum is for messages specifically about comparing the Cayman or Boxster to other cars. For example how the Cayman compares to the 350Z or the Boxster to the S2000 or SLK, etc. |
05-06-2008, 06:44 PM
Nothing compares to a Cayman Drive under 100K
Guys,
In a quest to get a 4 door sedan , I tried Bmw m3 sedan( great motor, great handling , sits too high) , 335 , 135 coupe and In that also got to try audi tt, MB SLK 55 AMG for the kick of it
Once you drive all of them and come back to CS u will realize how good the CS is
The steering, Handling, Grip and the sports car planted feel of cS is just awesome. The gearbox of the CS is rifle bolt like compared to beamers which were way mushy.
I am not sure how ferraris etc feel but CS is one of the finest sports car under 100K and it is so comfortable on bad roads with PASM in Normal mode
Enjoy the CS
05-07-2008, 07:30 AM
A nice used 996Gt3 is in the low 70s, that trumps a CS. A lot of Z06 owners would disagree also.
05-07-2008, 07:50 AM
Try a new well optioned CTS with DFI, it will get rid of a lot of biases towards GM cars. The upcoming CTS-V will be nice too, but it is not out yet and seems a bit overkill to me.
Let me know what you think of it, remember, drive one with DFI, the rest will disappoint you when coming from a CS.
DFI
05-07-2008, 08:27 AM
I'm surprised there are two replies already and no one has mentioned the obvious: GT-R. It is <$100K and the only real debate is whether anything <$200K is better than the GT-R.
05-07-2008, 08:33 AM
Geek
The GT-R isn't really available. Only 2400 units are coming to the US. Good luck buying one, and I bet you'd pay $100K if you could find one for sale.
05-07-2008, 10:21 AM
Smjc_99
Well I am going to be the first to Agree SMJC_99  .The only car I would Seriously trade for is the Audi R-8 and its over 100K as well.The Cayman for the $$$$ Is the BEST car you can buy. But the fun is fixing it up to ones own personal palet Thats why I need the CC.
05-07-2008, 10:32 AM
If they gave the Cayman the power it deserves, say somewhere between 400 and 500hp, it would trump anything in my book. Of course, such a car would cost more than 70 grand.
05-07-2008, 10:50 AM
I think that as with just about anything, it depends upon what you value, and the situation in which you use your car.
The Lotus Elise I had before the CS was a more involving, more fun pure sports car for me (emphasis on 'for me') than is the Cayman S. Having driven both, it's no contest. With less than 2000 lbs of mass, the Lotus was nothing but smiles on curvy back roads and the track . The steering feel and handling in that car is nothing short of astounding.
The Lotus, however, was virtually impossible to live with on a day-to-day basis. Once we moved to LA from upstate NY and could no longer just carpool to a train station in our other car, the Lotus had to go. Too low, too small, too fragile, crappy radio, crappier AC, no storage space, virtually no low range torque, marginal build quality...it goes on and on.
For my wife and I, the 6-speed Cayman S is the perfect sports car our current situation and we absolutely love it. Terrific powertrain, sufficient low-end torque, fantastic shifter, modern interior appointments, tons of storage space...and if we care to take it out for a track day or two, it's ready. This is a car we can live with. The '99 M Coupe we had back before the Lotus was terrific, but this is so much better.
JV
JV
'07 Lapis Blue CS
'03 Land Rover Freelander 'G4'
"It's Peanut Butter Jelly Time!!"
05-07-2008, 11:37 AM
Porsche Spieler
Perhaps its just me, but I dont think you can compare a CS to a CTS!!!
________________________
DFI
05-07-2008, 06:44 PM
the old lotus exige is considered the best handling car in the world, and due to its "go-kartness" its cheaper then the cayman
05-08-2008, 12:50 PM
I dunno, I think it was Motor Trend who recently went looking for the best handling car in America, and it wasn't the Exige. I believe they had two Porsches at the top. So much depends on the venue you are talking about also. On a tight autocross course, the Exige would shine, but at the Daytona International Speedway, maybe not so much.
05-08-2008, 03:10 PM
Couldn't agree more, the CS has yet to dissapoint me.
The only car that I would think of replacing it with is the 997T, and well thats in a completely different price bracket.
05-08-2008, 03:34 PM
Originally Posted by wushuhsu
Wow, not only faster, but also more exclusive than the Cayman S!
More exclusive yes, but with most dealers marking up way above MSRP most are not selling below $100,000.
I paid $57k for my CS after negotiation, nearly half the price.
Wushuhsu, I have read a number of your recent postings, is there anything about the Cayman that you like.
3 lions
05-10-2008, 01:39 PM
The Rossion Q1 is made by its new home company in Ohio. If it is finished to the degree that they advertise, we will be hearing much much more about this new American sports car that will out perform any existing road sports car for a little under $100,000 USD. I think this car will probably replace the CS as the best value, dollar for dollar for a hi performance sports car. Ask any professional race tech how much it would cost to buy or modify a sportscar to this hi quality level of road and track performance. Many here will try to dismiss this car because of its small and limited production numbers and support system. But how else does a new American success story start but by being small, and limited and with excellent design and quality?
Rossion – Reviews
With a power to weight ratio of better than 400 HP per ton, the Q1 moves beyond just being quick. Make sure that the steering wheel is pointed straight, as response to the throttle is immediate. Get control of the wheel spin, and 60 flashes by in not more than 3.3 seconds. Hang on and keep shifting for a quarter mile pass in 11.4 seconds at over 123 mph. Compare those times with your neighbor’s Enzo, or your buddy’s Carrera GT.
Seat of the pants dyno
05-10-2008, 07:11 PM
Totally agree 1000%.Great daily driver. Great weekend track car.Killer reliability.Extensive dealer service network. Tons of storage space for an exotic.Exclusivity.Looks like it cost 3 times as much. It's a Porsche. Buy an Borla exhaust and a Softronic and you are deep into 911 territory for an extra 4 grand. After mods I will have a nicely equiped CS for about 61K(not counting 19s).What's to compare?Slam dunk in my book. Love the car.
Love the GT3 -any GT3- my dream car- used or otherwise. But IMHO a track toy not a daily.
If weekend toy or track car- give it the edge.
IMO I think the GT R looks awful.I would have doubts about long term reliability. Dealers are having to invest a fortune in equipment if they qualify to service it. Finding one at 70k is a pipe dream. Buy one if you like it but I will pass.
07 Basalt black/sand CS
3 M clear bra
corner clears
painted to color CS badge and headlamp washers
Red tails
Borla exhaust to arrive in 3 days
Future mods- Softronic- 19" BBS LMRs??
