Alignment Questions
I am using the "String" method to check my current toe settings. I set strings up on both sides of the car parallel to the centerline measuring off of the wheel caps. I'm finding that the distance between the rear center cap and string is 3/8" more then the distance between front cap and string. My overall distance between both strings at each ends of the car is the same. Considering track and offset differences, does this sound about right? Next, looking at the eccentric screw on the rear toe link, the screw head is in its most outboard position. I believe that that indicates that there is no more toe-in available on that side. Is that correct? Thanks.
