If you've read through the existing threads on this subject (particularly this one:
http://www.planetporsche.net/cayman-...big-bucks.html but there are others) then you already know that it depends on a number of factors...
How experienced of a driver you are (smoothness at speed), what run group you'll be running in (speaks to experience and speed on the track), whether or not you've made suspension modifications to the front, and are running street or R-comp tires (substantially more grip in the front will put more strain on the system), the length of the run sessions, track configuration, and the ambient temperature on the day you're running. All of these factors seem to play a part in these failures to some extent, and you can mix and match them at will.
On the other hand, as I posted in the thread I mentioned, I've run my car (stock except for R-comp tires) in more than 25 DEs in the instructor's/advanced groups, in temperatures as high as 110 degrees, and not ever had a power steering problem. There are many other I know of who have done DEs and not had a problem. Yet, others have run one DE and had a PS steering failure.
I wish I had a definitive answer for you, but I don't think anyone really does.
