Hi Scopacetic;
I believe Fondueski has accurately assessed your issue...furthermore, I doubt that it is coincidental that you are having similiar results on the same track, in the same corner, with the same car particularly if no preventative mods have been implemented.
The odds of being struck by lightning are mathmatically very slim however; if you are leaning against a lightning rod during a storm the mathmatics may certainly become more statistical in nature...lol
The VOS/Oil sump/Pwr.Steering issues have been amply documented by the hard chargers on this & other forums...
Originally Posted by Scopacetic;
...haven't done any of the mods. It's on a lease, so not ready to plunk down too much on mods and...
I hear this rationalization a fair bit; ironically the same folks saying this will frequently spend the same or greater amounts on a new/different set of tires/wheels etc without hesitation. Granted a new IVOS/Sump mod is not nearly as sexy as a fresh set of Champions with Sport Cups but neither is coming back smokin' & drippin' on a flatbed...
Additionally; although I understand the finance argument just remember that a car, like a house or a spouse is
always a liability up to the moment you sell them...
Once you accept that, you can free yourself mentally to play hard with a clear conscience...lol
As a track junkie & Club Racer with well over a hundred+ weekends on the track with 951s (944 Turbos) & 968s (both stock & dedicated/heavily modified/boosted) & now my '08 Cayman S, I don't ever tiptoe around potential oiling &/or hydro-locking issues. I get proactive all over them & as a result I don't need to deal with the irritating & costly consequences. This in turn greatly increases my 'Fun Factor'...
The IVOS & sump mods are fairly inexpensive depending on the labor structure at your repair facility of choice...the pair of mods with parts will typically range in the 2.0-2.5k area if you combine the sump upgrade with your next oil change. (...or slightly less than a weekend in Vegas with a budding young supermodel...).
The P/S Underdrive pulley & installation is minimal & works well for most...I also added radiant barrier heat shielding on all P/S lines/hoses from pump to the bottom of the engine bulkhead area & have had zero expansion overflow or fluid loss. To monitor same I spliced in an extension on the vent hose with a little catch bottle within viewing range near the l/h rear wheel. If that changes I'll know it's time to add a cooler...
One of our PCA Region instructor/Club Racers also has a Cayman S; got his a little while before I got mine & was having the same ingestion issues with the voluminous smoking, power loss with CEL coding & oil consumption (.75-1.0 qt. per weekend). Since installing the IVOS mod he has had none of these issues return; I installed all my mods before ever setting foot (OK, tires) on track & as a result have never had a moments trouble with the IVOS/Sump or P/S scenarios.
He is also using the X51 pan baffle setup; I am using the Mantis solution. We are both fast, aggressive drivers & run on Hoosier R6s, Kumho V710s, or similiar tires with the usual suspension improvments & reasonably aggressive alignments for dual duty cars that we drive to the track...these aren't our Club Race cars.
Another of our Clients couldn't mentally get past the argument that Porsche should pick up the tab for the mod(s) & therefore didn't make the upgrades in spite of all the aforementioned warning signs...the engine failed catastrophically a few weekends later...
The frisky folks at tracks over the U.S. & abroad have done the research & documentation for us all but they can't force anyone to make the improvements however; if you grenade your engine & dump oil all over our favorite apexes we are really gonna' be pissed 'bout that...!!! lol...
Do the mods, get it over with, & go have fun without needless worrying...there are tires waiting to be spanked!!!
Remember; rubber is evil...it must be punished...
Randall
Car #007
Yellow Run Group - Set 3 | Hart Photography & Graphics
White Run Group - Set 1 | Hart Photography & Graphics
ps: re:
...had the engine light briefly come on a couple of times. So many things can cause it, unless it is frequent, or stays on, I would not worry about it. And my dealer gave the same advice...Originally Posted by elh0102...
This is an irresponsible response from any Dealer or shop if a car is seeing any time on the track...the car should be hooked up to a
PIWIS tester at minimum to verify what if any codes have triggered as at least a courtesy inspection to help protect the Client from potential issues...
Just sayin'...sorry, I'll get off my soapbox...lol
