I recently finished my
PASM CS suspension upgrade plan. My goal was to modify the car to be able to take full advantage for R compound tires for DE's while not destroying the car for street use. After all I sometimes drive the car 8-10 hours to DE's LOL
I started to drive DE's last year with a totally stock car with a track alignment and a whopping -.5 camber. after 2 DE's my first mod was a set of used tarett camber plates and another alignment to -1.8F -1.8R. what a nice improvement in turn in and cornering grip on PS-2's. I finished the season with these mods always running at the front of my group.
This year a set of 245-275 nittos on 8.5-10" Enkies and a
TPC front & Tarret rear bar made their appearance. Wow what a difference the R comps made! First time out on Pocono North the car was easily the fastest in the white group.
Lime rock next, where the car seemed to be pushing more than at Pocono. Noticed more wear on the outside edges of the tires as well. Still running at the front of the group but the car didn't feel right.
Farnbacher made me a deal I couldn't refuse on a set of damptronics so I had Precision install the coil overs, a Mantis stress bar and solid transmounts. Corner balanced, aligned & adjusted the bar settings
Lowered about 1" camber is now -3.0F -2.8R. The ride on the street is firmer but still OK. The car is completely transformed on the track. Cornering and transistion are at an entirely new level. Just a touch of understeer at the limit. Tire wear is much more even. First time out at the NNJR advance DE at ThunderBolt I ran at the front of my group (mostly white with some black & red) passing GT3's, turbo's & many fully prepped cars on Hoosier's. The only car that I couldn't catch was a 997 cup car with a red driver.
For a
PASM car this combo is killer. The only thing I'm going to change is to put the stock trans mounts back in. I don't like the additional vibration transmitted to the frame. Hopefully it won't add too many squirrels back in the rear suspension.
I'm really looking forward to driving this sweet machine without any further mods for the rest of the DE season.
See you at the Track!
PS the car also has an AWE exhaust &
SRP
