| Cayman and Boxster Competition Auto Cross, Club Racing, DE, this is the place to discuss the 987 on the track | 2Likes  | |
03-26-2010, 11:37 AM
|  | Porsche Chatter | | Join Date: Oct 2009 Location: CO
Country: | | | The Cayman factory LSD dissected... Hello,
We just recently got a Cayman S LSD into the shop and took it apart for the first time. Since this is the first one of these we've seen, I figured I would take some pictures and do a little show and tell with this thing.
Here's the LSD from the outside:
Looks pretty normal for a factory LSD. Cast body, but nothing out of the ordinary. Then we take the cover off:
Here's where it gets a little interesting. Notice that it is in fact a 4 plate LSD, just like a GT3 or any of the other modern Porsche 6MT gearboxes. But, look closely. The friction discs are stacked one on top of the other. Here's the stack as it comes apart:
It goes plain plate, plain plate, friction disc, friction disc, plain plate. So, even though it's got 4 friction discs it's only using 2 of them. Reminds me of another Porsche LSD:
That's a picture of a 1970 911 LSD!!! There's also another similarity between the old LSD and the new one; no belleville washers.
This new Cayman S LSD is a zero preload LSD. In fact there's absolutely no gap inside of this thing. The stack height is pretty much exactly the same dimensions as the body and cap of the LSD. I know there's been much discussion recently about low or no preload LSDs. I'll let you guys debate the merits of those designs, but will ask one question on the subject. If a no/low preload LSD is the way to go, why did Porsche stop using it? And as a follow up to that thought, why now, roughly 25 years later have they gone back to it?
I've got more thoughts and pictures, and will follow up with another post in just a second here...  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
The main advantage of a limited slip differential is found by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely– the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use however, such as driving off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some friction available on at least one of the wheels. To see the installation of a LSD style unit Click Here | |  |  |  |  | |
03-26-2010, 11:42 AM
Country: | | | Re: The Cayman factory LSD dissected... So, the next thing I did was start to look at the internals themselves. They've gone to a new type of friction disc material. I'm not quite sure what it's made out of, but it's a new approach for sure. Maybe they are getting their friction materials from brake technologies. I don't know. If you look at the picture, not only is it some sort of fiber material (reminiscent of the 933 carbon friction discs) but it's "pucked" with the friction material attached with some sort of adhesive:
If you look closely you can see that there's wear on the plates, so it appears that it does bite marginally better than the brass being used in the GT3 LSD:
But what really stood out to me was the size of these parts. They are teeny. Like 904 LSD teeny!
Versus the old 1970 911 LSD (from a car with roughly half the horsepower of a modern Cayman S):
Versus a modern day GT3:
It just doesn't strike me as very much friction surface for locking this thing. But if you look at the ramp angles, they don't really intend this to have all that much lock:
versus the old 40/40 angles of the 911 LSD:
So what's the plan from here? Redesign it so that it works. This came out of an Interseries car that had one season of racing on it. The car owner reported that he was spinning his inside tire for pretty much the second half of the season last year and was effectively running with no LSD. Guys tracking these cars seem to be burning them up really quickly. You could restack them with the friction discs further split apart for more lock up but the ramps are still really gentle. I don't think as it stands it would be much better for a racing application, but may be just fine for a street car. Regardless the wear surfaces are really thin to start with and there's just not ever going to be a really long life out of these LSDs.
Our attitude is that there's really no reason anyone who's got one of these units should have to throw it away, so we're going to make parts for it, and at the same time improve it. And having recently gotten our hands on a PDK LSD, it's effectively the same design and same parts, so it will take care of those owners as well.
Please feel free to add your own analysis to what you are seeing and ask any questions that might come up.
Kind Regards,
Matt Monson
Guard Transmission LLC  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
The main advantage of a limited slip differential is found by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely– the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use however, such as driving off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some friction available on at least one of the wheels. To see the installation of a LSD style unit Click Here | |  |  |  |  |  |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
Derived from motorsport, PDK, available for the 911 Turbo for the first time, achieves one thing above all else: it provides the perfect balance between uncompromisingly dynamic performance and exceptional levels of comfort. It’s purely about point of view. The driver’s especially.
The optional PDK with both manual and automatic modes enables extremely fast gear changes with no interruption in the power flow. For improved acceleration and significantly lower fuel consumption – without having to dispense with the advantages of an automatic.
The driver experiences a sportier, even more dynamic drive with more agility. Depending on driving style, gear changes range from exceptionally comfortable to exceptionally sporty.
Manual gear changes are performed using the PDK’s ergonomically designed gear lever or the switches on the steering wheel: nudge forwards to change up, pull back to change down. The logic behind the optional three-spoke sports steering wheel with gearshift paddles comes from motorsport: pull to the right to shift up, pull to the left to shift down.
PDK has been specially tuned to the characteristics of the new 911 Turbo models. It has seven gears at its disposal. Gears 1 to 6 have a sports ratio, with the top speed being reached in 6th gear. The 7th gear has a long ratio and helps to reduce fuel consumption even further.
PDK is essentially two half-gearboxes in one and thus requires two clutches – designed as a double wet clutch transmission.
This double clutch provides an alternating, non positive connection between the two half-gearboxes and the engine by means of two separate input shafts (input shaft 1 is nested inside the hollowed-out input shaft 2).
The flow of power from the engine is only ever transmitted through one half-gearbox and one clutch at a time, while the next gear is preselected in the second half-gearbox. During a gear change, therefore, a conventional shift no longer takes place. Instead, one clutch simply opens and the other closes at the same time. Gear changes can therefore take place within milliseconds.
Clutch 1 controls the first half-gearbox, which contains the odd gears (1, 3, 5, 7) and reverse. Clutch 2 controls the second, which contains the even gears (2, 4, 6).
The optional Sport Chrono Package Turbo with dynamic engine mount system provides PDK with two additional functions, ‘Launch Control’ and ‘motorsport-derived gearshift strategy’.
PDK – sporty, comfortable and efficient. Characteristics that have been given some thought elsewhere too: in the specification for the new 911 Turbo models. | |  |  |  |  | |
03-26-2010, 12:01 PM
|  | Admin & Founder | | Join Date: Aug 2005 Location: Kansas
Country: | | | Re: The Cayman factory LSD dissected... Matt,
Great post, thanks for posting this stuff. It's funny you mention this because when I was at the track with Napleton we had a couple of different Caymans acting differently with their LSDs and indeed one that felt like it didn't have an LSD at all that my TBD was outperforming by a long shot. So why are these Porsche LSD's like this???  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
The main advantage of a limited slip differential is found by considering the case of a standard (or "open") differential where one wheel has no contact with the ground at all. In such a case, the contacting wheel will remain stationary, and the non-contacting wheel will rotate freely– the torque transmitted will be equal at both wheels, but will not exceed the threshold of torque needed to move the vehicle, thus the vehicle will remain stationary. In everyday use on typical roads, such a situation is very unlikely, and so a normal differential suffices. For more demanding use however, such as driving off-road, or for high performance vehicles, such a state of affairs is undesirable, and the LSD can be employed to deal with it. By limiting the velocity difference between a pair of driven wheels, useful torque can be transmitted as long as there is some friction available on at least one of the wheels. To see the installation of a LSD style unit Click Here | |  |  |  |  |  |  |  |  | | Napleton Porsche |  | Napleton Porsche of Westmont
201 E. Ogden Avenue
Westmont, IL
60559
Main: 630-725-0911
Sales: 866-245-1965
Toll-Free: 866-344-9169
Home of the Cayman Interseries Championship http://www.napletonmotorsports.com/ | |  |  |  |  | |
03-26-2010, 01:11 PM
|  | Porsche Idealist 500 post club | | Join Date: Mar 2008 Location: WA
Originally Posted by Guard Transmission It goes plain plate, plain plate, friction disc, friction disc, plain plate.
So, even though it's got 4 friction discs it's only using 2 of them... | Couldn't you just switch a plain plate and friction disc and all four friction discs would in use?
So it would be plain plate, friction disc, plain plate, friction disc, plain plate.
Porsche only claims 22%/27% lock up so would using all four friction discs double that number?
And then improving the ramp angles might make it a decent diff?
Is there room to build an LSD with larger diameter discs and plates?  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-26-2010, 01:53 PM
|  | Silver Sponsor  2,000 post club | | Join Date: Jan 2007 Location: DC
Originally Posted by K-Man S Matt,
Great post, thanks for posting this stuff. It's funny you mention this because when I was at the track with Napleton we had a couple of different Caymans acting differently with their LSDs and indeed one that felt like it didn't have an LSD at all that my TBD was outperforming by a long shot. So why are these Porsche LSD's like this??? | My guess is cost/noise and the fact that real deal diffs likely need rebuilt.
That is why we put motorsport or guard diffs in modern porsches |
03-26-2010, 02:04 PM
Country: | | | Re: The Cayman factory LSD dissected... K-man,
I think part of what we are seeing here is Porsche's continued push away from really high performance automobiles and more towards GT cars that are safe and comfortable, that still perform well, but not stellar. I don't think when they put together the specification on this LSD that they ever intended it to see the track. There's a number of street drivers who are perfectly satisfied with the performance of this differential, especially when you leave all the various electronic traction control items engaged. It's being developed as an integrated system and the practical reality is the LSD isn't expected to do as much as it once did because the brakes are automatically more involved than they were in the past.
But then you take the car to the track. And you turn off the electric babysitters so that you can really feel the car and drive it at the limit without the computers stepping in and saving your arse when you push it too far. It's just too much for this little LSD. Or in some instance they get in your way because you and the car can go closer to the edge than they will let you and they step in and pull you back, making you slower but safer. Heck, it's too much for the street GT3 LSDs which are having a catastrophical failure rate when taken to the track. Even Porsche's flagship trackday special is ill equipped for use on the track in this department. And if the new TT model (only offered with a PDK and electronic differential) is any indication they are just going to go further to the side of electronics in the road cars going forward. Technology is a double edged sword here. The cars keep getting safer and more comfortable, but at the same time we keep getting further removed from them and the real control of the driving experience. Just look at how they are advertising the newest GT3R. They are openly calling it a racecar that's easier to drive for a gentleman racer that doesn't need the skills of professional.
Porsche has been systematically making their LSDs less aggressive on all their cars for a while now. IIRC, the current GT3 is 28/40 locking versus the 40/60 they used on the 996 variant. The GT2s have used the lower locking percentages since the 996 version of that car. It stands to reason that they would go low on the Cayman as well. It makes the cars more forgiving and basically makes it harder for the street driver to catastrophically fail and do something really stupid that kills or maims people because they pushed it too far. But for the people racing and tracking the cars, it disables them. This is why there will always be a healthy aftermarket for Porsches, because people will always want to race them no matter what Porsche does with the product line.
Walter,
If you read the end of my second post, you will see that I did suggest that you could restack them in the traditional configuration. But given how the ramps are set up, I don't think it will actually double the locking percentages like it did on the old 911/915/930 ZF LSDs. You can see what those ramps look like compared to the Cayman ones. This is just a guess, but I would say that restacking it might get you to something like 32/40 but not much more.
Other than the ramps, there is the very small area of the friction surfaces. And beyond that, they are so dang thin I don't see them having a very long service life. Those friction discs have a total thickness of 1.6mm. The pads are .3mm each. And since it's got no preload and very limited ramp movement I just don't see them being able to take more than .1mm of total wear on them before they stop locking. The GT3 LSDs, which have low preload are failing in about .1mm of wear. For comparison, our LSDs will continue to lock with up to .4 or .5mm of wear on them. In practice what we see is our diffferentials will go 3-4 seasons of PCA club racing between rebuilds, compared to GT3, and now Cayman S, LSDs that last less than one whole season. So, in short, I don't think restacking them is a solution that will work for very long in a racing environment.  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-26-2010, 02:10 PM
Country: | | | Re: The Cayman factory LSD dissected... But Matt wait wait wait, just look what Porsche has to say about it: Porsche Technology Glossary
"Are you a fan of sporty driving? In your spare time, do you enjoy the occasional outing on the racetrack? Then you shouldn’t do without the new optional mechanically locking rear differential available in conjunction with 18-inch or 19-inch wheels."
"In other words, sheer driving pleasure and faster lap times."
They say its great for the track, how can they be wrong??? |
03-26-2010, 02:21 PM
Country: | | | Re: The Cayman factory LSD dissected... OK,
Now that's really funny.
I didn't mention it, but this LSD is made by GKN, just like the GT3 LSD is. While the issues with the GT3 differentials have been going on here in the states now for half a dozen years, Porsche doesn't really acknowledge an issue with them and warranty coverage of the failures is intermittent at best. I suspect it will be the same with the Caymans. Just last week I rebuilt a GT3 LSD for a customer because his dealer had denied his warranty claim and accused him of tracking the car and causing the failure through abuse. Clearly PCNA and PAG don't see eye to eye on how these cars are meant to be used.   |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-26-2010, 03:04 PM
|  | Porsche Enthusiast | | Join Date: Sep 2006 Location: Texas
Country: | | | Re: The Cayman factory LSD dissected... Nice tear-down.
I got the factory LSD in my '10 CS 6-speed, so I will definitely be interested in hearing what kind of "upgraded" rebuild you might offer, if this thing is going to fail that quickly. That's kind of disappointing, since the addition of the factory LSD was one of the things that caused me to buy a new car rather than something slightly used.  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-26-2010, 06:37 PM
|  | Porsche Purist 1,000 post club | | Join Date: Jan 2009 Location: Bahrain
Country: | | | Re: The Cayman factory LSD dissected... Part of me is happy that I skipped the factory LSD for my 2010 CS.
I really won't be too happy to rebuild it from time to time.
Plus I don't think I need LSD for the street, I barely track the car anyway.  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
__________________ Cayman S PDK
Toyota FJ Cruiser
Seadoo Jetboat Challenger 180
Yamaha Raptor 700R
Mahandra Duro 125cc |
03-26-2010, 08:52 PM
|  | Site Donor | | Join Date: Apr 2007 Location: So. Cal
Country: | | | Re: The Cayman factory LSD dissected... Great information and pictures, thank you for taking the time to post this..! |
03-26-2010, 09:56 PM
|  | Porsche Specialist 500 post club | | Join Date: Jul 2008 Location: Georgia
Country: | | | Re: The Cayman factory LSD dissected... Thanks for sharing - this is all very good to know. I will be interested to see what you come up with. Stacking friction discs against each other just doesn't make any sense to me. Could it have been assembled wrong? |
03-26-2010, 10:38 PM
|  | Porsche Purist 1,000 post club | | Join Date: Jul 2009 Location: BC
Country: | | | Re: The Cayman factory LSD dissected... When the OEM pieces start breaking down on our new Caymans is Guard likely to have a replacement designed primarily for street use?
__________________ Croctor |
03-26-2010, 11:01 PM
|  | Porsche Purist 1,000 post club | | Join Date: May 2009 Location: Ohio
Glad to hear that a GT diff will be available for the PDK users. I had 3 transmissions built by Brian Copan and he used your gears in all 3. The best one also had your diff. I received a good education from Brian on the 'quality' factory diffs.
Please let me know when a Guard diff will be available.  |  |  |  | | PDK - Porsche Doppelkupplung |  | (FAQ in Process)
__________________ Alan C.
Cincinnati
2011 Carrera GTS Basalt Black/Black - PDK, LSD, Sharkwerks Center Muffler Delete, Forgeline GA3 Center Locks, MPSS |
03-27-2010, 05:24 AM
|  | Life is a wonder.. My life that is! 3,000 post club | | Join Date: Mar 2009 Location: Amman & Jubail
Originally Posted by DrKareem Part of me is happy that I skipped the factory LSD for my 2010 CS.
Plus I don't think I need LSD for the street, I barely track the car anyway. | Doc!!! From what I know about you, I think you & I track our cars every time we drive them on the streets!  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
__________________ "Remember, it only took Marty Mcfly 88mph to travel through time in the DeLorean! I would hate for you to accidentally land in a time without petrol!" ...JB TPC Balboni... 3.7L Cayman turbo S |
03-27-2010, 08:10 AM
Originally Posted by HassaanAbdeen Doc!!! From what I know about you, I think you & I track our cars every time we drive them on the streets! | true
Toyota FJ Cruiser
Yamaha Raptor 700R
03-27-2010, 08:14 AM
Originally Posted by DrKareem true  | I doubt the OEM LSD could handle your driving!   |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-27-2010, 09:44 AM
|  | Porsche Activist | | Join Date: Jun 2008 Location: PA
Country: | | | Re: The Cayman factory LSD dissected... Great info! Thanks for sharing it. One of the reasons (among others) that I ordered an '08 instead of waiting was that I knew if I wanted an LSD that you guys made a great one. Now you're making my decision look like a good one.  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-27-2010, 12:20 PM
|  | PCA Nat'l DE Instructor 500 post club | | Join Date: Jan 2007 Location: New York
Country: | | | Re: The Cayman factory LSD dissected... Matt:
Perhaps you can show a few photos of one of your products disassembled, side-by-side with the factory unit for comparison purposes, with a brief explanation of the different features (e.g. ramp angles, clutch packs, preload, etc.) and their benefits. Maybe the "987 Club" model that I've installed: Limted Slip Differential - 987 Club - Articles
Also, I think many of us would find it helpful if you would describe briefly how you'd "tune" a LSD for different applications (e.g. street, autocross, DE, racing.)
Regards,
Croc'ed  |  |  |  | | LSD - Limited Slip Differential |  | A limited slip differential (LSD) is a modified or derived type of differential gear arrangement that allows for some difference in rotational velocity of the output shafts, but does not allow the difference in speed to increase beyond a preset amount. In an automobile, such limited slip differentials are sometimes used in place of a standard differential, where they convey certain dynamic advantages, at the expense of greater complexity.
03-27-2010, 04:46 PM
Originally Posted by Croc'ed Matt:
Perhaps you can show a few photos of one of your products disassembled, side-by-side with the factory unit for comparison purposes Also, I think many of us would find it helpful if you would describe briefly how you'd "tune" a LSD for different applications (e.g. street, autocross, DE, racing.)
Regards,
Croc'ed | Oh yes that would be great, please...?
. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
