I picked up a set of Pagid Yellow pads and had a chance to try them at Roebling Road at last weekends PCA Coastal Empire Region event. Roebling isn't know for being harsh on brakes. Turn one is the only serious braking area.
I ran on the stock Michelin tires and Pagid pads. Nice progressive bite with consistent stopping power all the way to the turn-in point.
Next weekend they'll get a much better test. I'll be at Sebring for their annual Instructor School event. Sebring is hell on brakes. I've run their plenty of times in my 964 with 993TT brakes. I've burned up pads and cracked rotors there.
brake pad installation is a bitch
The anti-squeal shims Porsche uses have an adhesive on them. So they stick to the pads - making them a bitch to pull out.
I bought two tools to help make the job a little easier. I picked up an extra wheel mount pin and a 4mm "punch" to remove the brake pad locking pin. I also bought a pair of jack pads. A 4mm punch is a must have for the job! The extra wheel mount pin means I can keep it in the tool box and not have to fish around in the factory trunk toolkit.
People have been bitching about Porsche's hub centric wheel design for a while now. Yeah, it's not as convenient as the old fashioned wheel studs, but with the wheel mount pin it's a whole lot easier.
The jack pads are another "must have" item for your tool box. I never used a jack pad on my 964. A few years of frequent wheel changes without a jack pad have pretty much bent the hell out of the factory jack point. I won't make the same mistake on the Cayman.
