This was pretty much the only configuration of it's kind in CA, but luckily Fremont Porsche is only a 30 minute drive away!
'08 arctic silver
PASM
sport chrono plus
PCM2.1
bi-xenons
19" Carrera Sports
bose
sport exhaust
sport steering wheel
auto climate
heated seats, autodim mirror, floor mats
MSRP $75,315... I ended up at 2% above invoice and 11% below MSRP. I think I could have eeked out a bit more savings, but all in all I'm pretty happy with the deal! All the options were on my "must have" list with the exception of the
sport exhaust.... but it does give the engine a throatier growl. No weird sounds or rattles as of yet, but I should have plenty of time to observe in a relatively quiet cabin during the agonizing break-in period.
Thanks to everyone for the valuable input with made my purchase considerably more well-informed, both for configuration and pricing.
