12-16-2008, 03:44 AM
Just Placed Final order on 2009 Cayman S... check it out!
Hey guys,
Well it finally Happened, I get a call today from my local dealer here in Dubai to come in and spec out my 2009 cayman S.
Naturally I rushed over there and find below the options i chose:
Cayman S
PDK
Meteor Grey Mettalic
Leather interior in special color Terracotta
19 inch Carrera S II wheel(chose this over the turbo wheels because no one has them on there caymans, they are cheaper and i loved the look of them).
Floor mats (terracotta)
PASM
Bi-xenon lighting sytem with dynamic cornering lights(include LED's).
Sport Seats
LSD
Sport chrono Package
PCM with navigation
What do you guys think? any other necessary options you think i should have gotten??
Now the wait begins... i was told ill get her either end of march or early April!! can't Wait!!
12-16-2008, 03:58 AM
'Yellow Peril'
Re: Just Placed Final order on 2009 Cayman S... check it out!
Originally Posted by Arth
Hey guys,
What do you guys think? Any other necessary options you think I should have gotten??
The Specification Is - Spot On............
Glad to see the LSD Included!
I'll Let you Know when I am Next in Dubai - Or if you Visit London, the 'Yellow Peril' would be Pleased to Meet You...............
Cheers Karel
12-16-2008, 04:49 AM
Great spec. The color combo will be nice. I also like the wheels.
Curious- did you consider seat ventilation? From the US order guide it appears ventilation isn't available with the sport seats. I'am in a tropical climate- Malaysia and am considering the vented seats. have driven a few cars here with alcantara which looks nice but a little uncomfortable to me.
Hope the waiting goes by quickly!
12-16-2008, 06:54 AM
Was PDK required in order to get LSD?
12-16-2008, 07:09 AM
'Yellow Peril'
Unfortunately - Yes...............
Cheers Karel
12-16-2008, 07:15 AM
kareldeeley
defintely hit me up with a PM and we will meet up... hopefully ill have her by then.
Actually going to london sometime in may to visit my brother..your cayman looks awesome
zedcat
Actually no i didnt consider seat ventilation, it get quite humid here in dubai but i just didn't think it was bad enough to have to get that option.
SGF
Unfortunately yes it was a requirement... but the 19inch wheels were not.
12-16-2008, 07:47 AM
Interesting...so the rumored 19" wheel requirement for LSD on the 6 speed does appear to be a money grab (surprise!) on Porsche's part.
12-16-2008, 07:34 PM
Trouble is you have to order the heated seat option as well, which is the last thing I need.
2010 Cayman S, special build.
