01-28-2009, 10:13 PM
2009 Cayman S wish list
I just built my new Cayman S on the Porsche website. If the dealers are a bit hungry i will actually order it. Here are my wish list options: Front air intakes painted in exterior color, The new Aerokit which includes a fixed spoiler and upgraded front spoiler, Sport Chrono, LSD (YES IT IS AN AVAILABLE OPTION!), PASM, and the new PDK . Sport leather seats and Xenon headlights with cornering lights for those twisty roads. This new puppy has 320 hp and 273 lb ft torque and now has direct fuel injection. Oh..... I so do want it.
Anyone have any suggestons or comments to make my dream car better?
DFI
01-28-2009, 10:59 PM
Re: 2009 Cayman S wish list
PCM if you want to get the lap display for Sport Chrono, have bluetooth or ipod integration, etc. What color are you thinking?
